Old 01-16-2008, 05:32 AM   #1
SEVENTY1
SEVENTY1's Avatar
Engine Install (getting no spark) HELP
Hey guys I am in need of your expertize. Over the weekend I dropped a 350 sbc in my 71. When it came time to start it up, the motor turns but cant get it to start up. Upon close inspection I noticed that I was not getting any spark. I've got a new distributor cap and coil, and what I noticed on the coil is that I've got the plug that goes from the distributor to coil connected. Right infront of that it shows that there is another connection end that I have nothing connected to it. Is there supposed to be another plug that maybe has current or something that need to plug up to the coil?
Any help is appreciated.
SEVENTY1 is offline   Reply With Quote
Old 01-16-2008, 05:43 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Engine Install (getting no spark) HELP
Did you use the factory resister wire in the truck harness? If so you need to cut the resistance part out of it so you get full 12 volts while cranking it. The old distributor only needed 7 or 8 volts but with a HEI it needs the full 12 volts.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-16-2008, 06:31 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You will need 12v from the Ign. to the "BAT" on the dist.
sneakysnake is offline   Reply With Quote
Old 01-16-2008, 09:47 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
His post sounds to me like he has points ignition.
try this site.
http://abbysenior.com/mechanics/ignition.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-16-2008, 10:17 AM   #5
wheels67
wheels67's Avatar
Yeah you could bypass with a direct 12volt wire from the fuse. Just check with a test light to make sure its a "Key On" circuit first.
wheels67 is offline   Reply With Quote
Old 01-16-2008, 11:05 AM   #6
cdowns
cdowns's Avatar
if points it wont spark without the proper dwell setting
Old 01-17-2008, 04:39 AM   #7
SEVENTY1
SEVENTY1's Avatar
Thanks for all the pointers. Does anyone know the color of wire I need to look for?
thanks again.
