Old 02-02-2008, 01:43 PM   #1
wibilly
wibilly's Avatar
700r4 to a 205
whats involved? is a 208 any good? this is not a serious off rd truck but driver/ tow rig 450ft/lb 406sb
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-03-2008, 12:14 AM   #2
pumpkin
pumpkin's Avatar
Re: 700r4 to a 205
You need a shorter output shaft for the trans, and move the engine ahead two inches, or the transfercase back two inches. I got mine from bowtie overdrive. I can't remember for shure, but I think it was $1700 built to handle the power with th output shaft.
pumpkin is offline   Reply With Quote
Old 02-12-2008, 12:58 AM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 700r4 to a 205
Advanced Adaptors has the adaptor for the 700R to the NP205. I would keep the 205.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 02-12-2008, 11:18 AM   #4
snj8198
snj8198's Avatar
Re: 700r4 to a 205
hi Jim. the 700/205 combo is a neat set up. the 700's 3.06 first gear helps the 205's anemic 1.94 low range. first off, what 205 input spline count and adapter bolt pattern do you have? which year tcase will determine which route is most effective for your swap. however, if i may say, if you are not roughing this rig up then the 208 that comes with the 700 will handle your small block and towing duties just fine, but it doesn't have the cool factor as the 700/205 combo. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 02-13-2008, 03:14 PM   #5
rgv72blazer
rgv72blazer's Avatar
Re: 700r4 to a 205
you could use a 2" spacer if you don't want to go through the tranny. i'm using the spacer set up on mine...but I bought my 700 already built, then added the 203 adaptor, spacer, then the NP203 to doubler But judging by your original post, I'd stay with the 208...just add a clocking ring and SYE kit.
rgv72blazer is offline   Reply With Quote
Old 02-18-2008, 10:08 AM   #6
wibilly
wibilly's Avatar
Re: 700r4 to a 205
i would rather keep my 205. i looked on advance adapter's web sight and seen there kit. is this all i need? anybody used it? they said somthing in the instructions about pan mods. is this just a matter of cutting off a corner and fabing up a new corner for the pan? what about drive shaft lengths? i think i read somthing once about using a spacer instead of a shaft, witch is more cost efective?
Old 02-22-2008, 06:23 AM   #7
rgv72blazer
Re: 700r4 to a 205
spacer's cheaper. the thing that sucks about the AA output shaft is that you gotta tear the tranny down to bare housing
ProjectPOR...'72 Blazer 350/700R4/203-LoMax Via NWFdoubler/ 60-70/44s
DD.TowRig...06 LBZ CCSB 285s
HomeSweetHome
Old 02-28-2008, 10:21 PM   #8
wibilly
wibilly's Avatar
Re: 700r4 to a 205
i do plan on tearing the tranny down for a rebuild/upgrade. one of the main reasons for doing this is the education on auto trannys. does anyone know if the th350 output shaft can be installed in the 700r?
