Old 03-24-2008, 04:05 AM   #1
retselgerg
retselgerg's Avatar
General Tune Up Questions Please
Well summer has all but arrived and im still not running, to make this short i have bought some tune up parts, Plugs wires, Ignition Module, Cap Rotor Button, etc but a young punk like me has little experience in installing these parts (dont get me wrong im not lost when it comes to it) but their is stuff im not sure about and my father seems to have more important things to do then help me so i have decided i will just eliminate depending on someone else... so could someone please make a detailed list of things i should do, one area im rather confused on is installing the wires, i know the firing order, 18436572 but im unsure on how to translate that into installing them, are all the odd number cylinders one side?? and where is number one on the cap? info like that would be great
-G.Lester
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 03-24-2008, 04:31 AM   #2
Eichorst69
Re: General Tune Up Questions Please
Remove the #1 spark plug which is in the front on the drivers side. Place your thumb or finger over the hole and have someone bump the starter over. When it blows your finger off the hole, stop. Then turn the engine over by hand until you align the 0 or TDC with the line on the dampner. You should only have to turn the engine a few degrees one way or the other to reach it. Once you have it at 0 degrees (TDC) top dead center, remove the distributor cap to see where the rotor is pointing when the cap is on and in place. The rotor should be real close to one of the plug wire holes in the front of the cap. Now, this is where the #1 plug wire goes. Work your way in a clockwise fashion following the firing order around the cap. The drivers side of the motor are #'s 1-3-5-7 and the passenger side are 2-4-6-8 running from front to rear.
Rob
Eichorst69 is offline   Reply With Quote
Old 03-24-2008, 04:54 AM   #3
jef5150
Inline 69
jef5150's Avatar
picture...
jef5150 is offline   Reply With Quote
Old 03-24-2008, 05:15 AM   #4
sjarrett71
sjarrett71's Avatar
I would suggest only changing one at a time if they are not all off already.
I also thought there was a general maint. sticky somewhere. I will look for it and post a link if I find it.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-24-2008, 05:39 AM   #5
retselgerg
retselgerg's Avatar
ok stupid question does, the number one on the cap go to number 1 on the engine
Old 03-24-2008, 05:56 AM   #6
sjarrett71
sjarrett71's Avatar
yes
-Scott-
Old 03-24-2008, 06:32 AM   #7
ed2552
ed2552's Avatar
IF the truck runs and has its wires on it now, replace them, then pull the cap, replace the rotor, and put the new cap on and put the wires on one at a time from the old cap, that is a trick my dad taught me. Pertronix, i think, makes a HEI tune up kit for the big cap dizzys. If you have a small cap some other companies make them, MSD, Accel, but i like MSD the best, bit that's just my opinion. Don't forget to replace (or clean and re-oil, if you have K&N or like) the air filter and check the fuel filter. Be sure to gap EVERY spark plug b4 installation.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-24-2008, 06:33 AM   #8
ed2552
ed2552's Avatar
Just curious, how old are you? I bet you have one of the nicest trucks at your school.
Old 03-24-2008, 06:39 AM   #9
89 crew
Don't forget dielectric grease on both ends of the wires.
89 crew is offline   Reply With Quote
Old 03-24-2008, 06:50 AM   #10
retselgerg
retselgerg's Avatar
21, i have AC DELCO WIRES, AC DELCO R45TS plugs, MSD cap & rotor button and AC DELCO module
and lol im not in high school anymore but sometimes i drve the beast to the college ad yes its the nicest there.
Old 03-24-2008, 06:51 AM   #11
ed2552
ed2552's Avatar
And anti seize on the spark plug threads, and don't over tighten, just tighten with fingers until snug and use a wrench about a half turn more, if that, don't crank on it, my dad once over tightened one and it broke off in the head, he had to remove the whole thing, PITA.
Old 03-24-2008, 06:53 AM   #12
ed2552
ed2552's Avatar
ok, that is not too hard to do, just take your time and don't rush and u will be fine. I'm 16, btw and have had my 67 for 3 yrs
Old 03-24-2008, 06:57 AM   #13
ed2552
ed2552's Avatar
Yeah, i'm a sophomore, and i get a lot of $%^) about my tahoe, but i know it is because everyone is jealous because i have the best vehicle and i've put the most of my own money into it.
Old 03-24-2008, 07:14 AM   #14
retselgerg
retselgerg's Avatar
alot of my friends dump all there money in civics cavaliers and stuff like that,
Old 03-24-2008, 07:25 AM   #15
ed2552
ed2552's Avatar
BLAH, no one at ourr schol is that retarded, we live where it snows half the year, so no one does that, plus nobody has the time, money, or knowledge, or their parents pay for everything, and they don't rle care as long as it runs and drives. They don't even know what the warning lights mean, they drive it until it doesn't run, a friend of mine drove on a flat until the tire shredded itself, about 3 miles. He was just like, "oh, that's what felt weird, my dad will fix it." They piss me off b/c they don't care about the machines that changed the world and run our lives. They just expect it do go where it needs to go and get pissed when it doesn't work the way they want it to, and they don't care about them. Sorry i will get of my , just my rant for the day.
Old 03-25-2008, 11:48 PM   #16
chris71
chris71's Avatar
make sure to put the plug wires back in there looms so that they dont touch upagainst any manifolds or moving parts, wouldnt want you to ruin a new set of wires. the dist. cap only goes on one way if i remember correctly, there is a small nodule in the cap that lines up with a groove in the dist. body, you'll see as you play with it. i would do as sjarrett says if you are new to this, just one at a time, memorize 18436572, you'll need it down the road. the rotor is easy too, just un-screw it and screw the new one on. good luck
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
