Re: Project "cheapskate 65"
Well, I finally have had some time to work on my frame and made a little progress. I got the trailing arms and brackets built and welded up. I also got the bag brackets and cross member built and tacked on to make sure everything will work as planned. The only problem I see so far is with the shocks. It has so much lift in the rear I don't know if I am going to be able to find shocks to work for the full lift/drop amount.(Suggestions??) I want to mount them on the back side of the axle if possible. I still need to mock up a wishbone and figure out a cross member and height for the carrier bearing since I Z'd the frame 4". So much to do and so little time!
![]() Join Date: Mar 2008
nice work i like.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
nice job. I wouldn't worry about finding a shock. Just go to the monroe website and download their pdf application chart. They have shocks with more travel than you will ever need.
are you droping your body mounts?
frame is looking great! |
#5 | |
Thanks, Yes, I am dropping the body mounts but am unsure how much until I set the cab and sheet metal back on to do a test fit. (probably 1" if I had to guess) |
Well, I got a little more done to my truck frame. I made my shock brackets and tacked them on. As soon as i find a TH 350 transmission I can figure my pinion angle and get everything welded up. I also got my wishbone welded up but still need to put a grease zerk on the slider. I also need some bump stops for the rear. Getting closer to being done(i think
very nice work!!!
Cool.
Looking good. I like all of the plates welded over the frame welds.
here, just not logged in
Looks good......In post #26 i see that the 2link bracket that is welded to the frame is pointing at the rear axle. All the ones i have seen point to the ground.Why did you do it this way?
It'd be alot cooler if you did
why not add some adjustable rod end to the lower bars? It all looks good, but you could have a functioning four link for a minimal amount of effort. Everything else looks killer.
he couldn't use the sliding wish bone, it would have to be modified also
Thanks for all the compliments. As for the 2 link brackets when i built them i figured that since the stock mounts were pointing back i would make mine the same way.
#14 | |
My motto is cheap and easy! |
#15 |
True Addiction
Looks Great, Keep up the good work. Simple is never a bad thing
#16 |
///Relaxed Atmosphere
looking good
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
#17 |
it looks really good, you are making it very hard for me not to z the front of mine. i like how you did the rear rails too, it makes it way easier. thanks for the info and keep up the good work.
Build Thread - Papa's truck build up |
#18 | |
Thanks for the compliment! The z was not as hard as i had myself thinking it would be. Measured and leveled a million times before i cut! The rear was done like that for two reasons. #1 to be able to build my own notch(cheaper than buying one!!) #2 to give me room to put the gas tank. |
#19 |
Looks really good. I like the sliding wishbone. I dropped my cab mounts a inch and it lays just about flat. I have never bolted the cab down tight to know for sure though.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
#20 |
Well, I have made a little progress! I cut the pinch weld off the rockers so it would lay flat. Got my tranny tunnel built and my engine/trans mocked up and it seems to have plenty of firewall clearance. Need to find some headers to work with my angle plug heads.)Suggestions are welcome!!) Next step is gas tank(fuel cell??) was going to use a 69 camaro gas tank but its to wide. and then start plumbing brakes and fuel lines and then paint frame.
#21 |
Looks really good man. You did a really good job on the tranny tunnel. I am ready for some more progress pics
#22 |
A Blazer gas tank would probably work if you want the stock route? If not, RCI cells are cheap, and not bad for the price.
If you can find it cheaper, I can fix it! |
#23 |
RCI's are great, but watch out w/ the welds. They don't have much overlap so are kinda weak. Had the whole back underside around where the sump is crack. Summit paid to have it welded up thankfully. Also local welding guy we took it to said he had seen a bunch of them, and also look out for cracks around the mounts. Just a heads up. Although since its been welded up, haven't had a single issue for 4 years of driving.
#24 |
We did a fuel cell in my buddies hardbody and it also has cracked in a spot. Sucks to do all that work then have more problems with it later on.
#25 |
The RCI tanks need to be supported across the bottom or they will crack. I think they should send mounting instructions, because I have sen a lot of them fail because of being mounted wrong. Mounted the right way and they hold up for years.
