Old 05-19-2002, 10:15 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post 700R4 ?
I have 27" tall tires. When cruising 75mph it runs around 3,700rpm. It should be alot lower than that. I have 3.73 gears. I am only getting 7mpg wiht it. What could be the problem? It has a 2400 stall on it and is lockup. It runs around 2,500 at 55
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 05-19-2002, 10:17 PM   #2
ColinOpseth
Post
have you corrected your speedo yet?
Webmaster: www.GMPerformance.org
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 05-19-2002, 10:24 PM   #3
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
yes I have and it is exact.
72 Chevy C/10
Old 05-19-2002, 10:27 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
My TH350 with 28-ish inch tires and a 3.07 gear does 3700 at about 95 MPH. (I have a pic of it on my digi-cam right now)
Is your ranny slipping at all?
That 2400 stall is probably killing you. You want your cruise RPM to be higher than your stall speed, or else you'll get tons of slippage.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
[This message has been edited by longhornmail (edited May 19, 2002).]
Old 05-19-2002, 10:36 PM   #5
Low69CST
Post
What kind of system do you have telling your converter when to lock up? Is it adjusted right? If it is, then you might have a bad converter. I can feel when the converter locks up on my S-10. It might now be locking up. If you have a trans. temp. gauge check it out and make sure your trans temp. is not way out of wack. You may have something slipping inside. If all that is good.....what kind of engine do you have? If its a low power engine it may not have the umph to push the truck at those low RPM's.
Thats all I can think of.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front & rear sway bars
See my truck at: http://www.geocities.com/low69cst/
Student at the University of Kentucky.
Feel free to message me on AOL, SN- SS95ZQ8
My Dad's projects:
72 Short Fleet 4x4 Chyenne Super
72 Long Fleet 4x4 Chyenne Super
Both 350 autos restored original
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-19-2002, 11:49 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Post
Is the 700 in your truck right now? If so, your'e not getting lockup on the converter. There has to be power to the lockup solenoid or you have to bypass that hydraulicly. Those are the only two ways to do it. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer New project
1995 K1500 Sub(Mommas car)
1989 VW Golf(Beater)
Will be the daughters car if she will pay her insurance! Ha!
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-20-2002, 11:54 AM   #7
Longhorn Man
Post
lockup will only knock off a couple hundred RPM, not 1500. Look at his RPM's, that is WAY off!
Columbus Ohio
Old 05-20-2002, 02:00 PM   #8
Mixup
Post
My 69 has 3.73 gears and 28" tall tires and in overdrive its 2000 rpm at 65 mph.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-20-2002, 02:04 PM   #9
Mixup
Post
By the way the lockup only drops the rpm 400. I have 12 volts going to the lockup all the time and it goes through my brake light switch so when I stop it disconnects the lockup.
1969 Z28 engine
Turbo 350
Old 05-20-2002, 06:09 PM   #10
busterwivell
Post
That's WAY OFF! I've got 255 70'x15's, 3:55 gears and with my 700R I'm doin' 2200 RPM in the Studebaker, doin' 80 MPH, and I'm calibrated correctly. With my 350 ci engine, I'm gettin' 23 MPG.
56 Studebaker 2 dr Wagon
66 Chevelle 2 dr 4 speed
71 C30 Longhorn
86 Monte Carlo SS
96 Tahoe
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-21-2002, 10:56 AM   #11
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
When I am in overdrive (or I think it is) I can pull down into 3rd and nothing happens. Is the converter maybe just locking up and not even shift into fourth? And how can I get it to shift into fourth if it isn't. When I cruise down the highway and touch the brakes ( I have the painless kit with brake switch) I can't feel the converter unlock.
72 Chevy C/10
Old 05-21-2002, 11:44 AM   #12
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
It does sound like you're not getting fourth gear there. You're not above 3/4 throttle, are you? Stock 700R4's have a lockout so they won't shift into fourth above 3/4 throttle...
Then again, that's probably not the issue...
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-21-2002, 01:00 PM   #13
ckhd
ckhd's Avatar
Post
It actually sounds right. Do the math (I wrote a program for my iPAQ to do it for me). I get that you should have 3483rpm @ 75. Are you sure the converter is locking up? If everything was locked tight, then you should be getting 80 @ 3700rpm
I also get that your rpm at 55 should be 2554. If it's right at 2500, it should be 54. That's a 2% variance, and with 2% at 80 mph, that would mean about 78mph on your speedo at 3700rpm.
It all sounds right to me. 7mpg has a lot to do with the high rpms. I think that with a good carb overhaul and/or rejetting, you could get 10. Taller tires would help with both.
All the above numbers are NON-overdrive. If you have an overdrive tranny, it's not going into overdrive.
my 2¢
Bowen
'68 K20 fleet
'69 K10 swb fleet
'72 C10 lwb step
'72 K10 Suburban
[This message has been edited by ckhd (edited May 21, 2002).]
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-21-2002, 01:06 PM   #14
ckhd
ckhd's Avatar
Post
Duh, read your post 3 posts up.
You are definately NOT getting overdrive. Your tranny gets into drive and no further. How to fix it? I don't know. Check your throttle cable. If it's not right, it could think your throttle is at 75% or more and not allow 4th. I've heard the throttle cable on the 700r4s are sensy.
Bowen
'68 K20 fleet
'69 K10 swb fleet
'72 C10 lwb step
'72 K10 Suburban
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 05-21-2002, 01:17 PM   #15
LAP
Post
How can you tell if the torque converter is locking up? Do you feel it? Does it lockup only in fourth?
I have 12 volts to it and am running about 1400 RPMS's @ 55 with 3.07
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
Slaughter, La
LAP is offline   Reply With Quote
Old 05-21-2002, 01:30 PM   #16
Low69CST
Post
Dude! your stuck in the 3rd gear. I put in your numbers except I told prestage.com to give me the transmission ratio with those numbers and I got 1.06. 3rd gear in a 700R4 is 1.00. So now we know what is happening, just need a tranny guy that can figure out why.
My Dad's projects:
Old 05-21-2002, 02:29 PM   #17
busterwivell
Post
You are NOT in overdrive. Your 700R will give you a 30% reduction in RPM when in overdrive. Specifically, that 3700 will go down to 2590. Have a reputable tranny specialist check it out for you.
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 05-21-2002, 02:39 PM   #18
Low69CST
Post
What tranny did your truck have originally? Your indicator may be off. When you take off what position do you shift to? Drive? Nuetral? What ever it is, put it in one position higher and see what it does. I think your shift indicator might be off and your in a gear lower than you think you are.
My Dad's projects:
Old 05-21-2002, 07:40 PM   #19
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
What do you guys know about the servo's in the tranny? I heard there is a 2nd and 4th gear servo. Could the 4th gear servo be bad? If wires go to it or something? And thanks alot to all of your input also
72 Chevy C/10
Old 05-22-2002, 12:15 AM   #20
cableguy0
Post
no overdrive dude.cuz with those r's u should be doing at 107 mph if u were in od
72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-22-2002, 02:05 PM   #21
Blue68
Blue68's Avatar
Post
Guys,
Go to www.700r4.com and take a look at the rmp calculator. At 75 mph you should be turning 2438 rpm with 27 inch tires, in overdrive.
If the tv cable is not adjusted properly, It will shift very badly IN ALL GEARS. In other words, the 1-2 shift can occure extremely soon (like almost immediately) or after the engine revs beyond what makes sense. It doesn't just control shifting into overdrive.
Electronics don't have anything to do with shifting into overdrive, but they do control lockup. Most trannies are not set up to lockup in any gear but overdrive. It is possible to wire it up to go into lockup in any gear. Most common way is to use a vacuum signal combined with a signal from the tranny that it is in overdrive to control the electrical signal for lockup. You can feel (but mostly hear) the lockup if you pay close attention and know roughly where you are based on gears. Best test (again assuming wired correctly) is to tap your brake at cruise speed. The lockup should disengage when you hit the brake. If it doesn't, I hope your insurance is paid up, because your destined to drive right through the guy in front of you.
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Way too much money and time..But it's a hobby.
http://home.comcast.net/~r.landrum/w...tos.html-.html
Blue68 is offline   Reply With Quote
Old 08-29-2002, 04:57 PM   #22
trinic
trinic's Avatar
About your trans, well I don't have much knowledge in them, but I got off the phone with this trans builder (cause i want to do the swap), and he told me he has a 67 c10 with the 700r4. he told me about the 4th gear lockup. he said all you needed to do for the lockup was to run 12V (he's running it to his ignition key) to the trans, and the rest of the shifting into overdrive would be done internally (no selnoid).
He said he somehow grounds something inside the valve body that'll triger 4th gear to come on. now as far as what he does to it internally (he builds transmission)for this to happen, i don't know. let
me know, and i can give you his phone # if you have question....
trini c.
trinic is offline   Reply With Quote
Old 08-29-2002, 07:57 PM   #23
72chevyLWB
Got 20's????
72chevyLWB's Avatar
I just talked to a guy last week and he said that if there was only 1 wire going into the tranny the ground was gone. He said there must be a way to ground it internally.
Old 08-30-2002, 12:13 AM   #24
sam's 72
If your converter is not locking up, if I were you I would quit driving it till I founf out the problem. The converter has got to lock up on the 700r4 if not it will burn it slef up. I agree with longhornmail, if your conerter is 2400 stalh and your driving 55 and the rpm is at 2400 to 2500 you are getting a lot of slipage, and this is going to build extra heat, and the 700r4 do not like heat, it will burn it self up this way also. So, my 2 cents is you have got to have these trannys just right, or you will be putting another one back in there.
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 08-30-2002, 07:29 AM   #25
Jwill41
Jwill41's Avatar
I finally got mine out of the shop. They put what they called a "dummy" converter in it so it does not lock up. I really like it this way. I have more control over it. In drive it is a 3 speed and in overdrive it is a 4 speed. It seems that I am only turning 300-400 more rpms at 60 mph without the lockup.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
