Old 04-09-2008, 11:41 PM   #1
67chevemall
67chevemall's Avatar
What Carb do you guys run on the 383??
I need help chosing a new carb.
I had a 600 holley for years that was ok
The Edelbrock 1406 just isn't cutting it. I don't like it.
Any pics or suggestions would be great......
I like the demon series.....
And the 4150 Holleys look good too....
anybody
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-10-2008, 12:12 AM   #2
70rs/ss
70rs/ss's Avatar
Re: What Carb do you guys run on the 383??
Just for a driver? 750 edelbrock. I plan a 750 double pumper, but mine is in a "fun" car, not my DD. What's wrong with the 1406?
70rs/ss is offline   Reply With Quote
Old 04-10-2008, 12:38 AM   #3
muscletrucks
muscletrucks's Avatar
The best carb for the torquer 383 is a Holley 670 Street Avenger. This with a dual plane intake and the numbers show you can't do any better. It hits the sweet spot. Rodney
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 04-10-2008, 12:45 AM   #4
Billla
Billla's Avatar
CFM = ((CI x RPM)/3456) x VE, if you figure 383 HP then you don't need more than 600 CFM until past 6000 RPM. You'd have to turn it to 8K to need 750 CFM.
There's nothing wrong with the 1406 - if it's not "cutting it" then it's not working, configured or tuned correctly. I agree that the Edelbrock Performers, Holley Street Avenger or Street Demons are the best choices for a daily driver.
A mechanical-secondary carb is a racing carb, not a street carb. You give up driveability and fuel economy for instant acceleration performance - if that's a good trade-off, then cool - otherwise tune what you have.
Billla is offline   Reply With Quote
Old 04-10-2008, 12:56 AM   #5
HoupPhotography
X2 ^^^
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-10-2008, 01:19 AM   #6
67chevemall
I have tried everything I can to get it to run nice again.
It has been sitting for a few years now so it is even harder.
I thought about taking it to the engine shop down the road, but hate
to leave the truck anywhere.
I think it could be the dizzy and timing more then the carb.
Just want to get the right carb on there before I take it in.
I can flat bed it to a place next town over where they would
tune it up nice, and dyno it all on a Saturday where I can "hang out"
I could tune the 1406 but I like the holleys much better.Want to go back.
I have a brand new 1406 I would trade somebody to get me going.
Your right I don't need Mech Sec. at this point.
The truck is just for Sunday runs for now.
What is the holley Vac Sec # for 650 carb?
?? spring is here and I'm still in bed: go time
Old 04-10-2008, 01:26 AM   #7
Billla
Billla's Avatar
If you must have a Holley, then the Street Avenger is your carb.
Always timing, then carb for tuning...
Old 04-10-2008, 04:08 AM   #8
muscletrucks
Like I said.......................
1943 Farmall M
Old 04-10-2008, 04:09 AM   #9
Billla
Billla's Avatar
Hey - didn't mean to not give you your props! Exactly like the man said in a prior post
Old 04-10-2008, 04:19 AM   #10
muscletrucks
No problem, your tops with me!
1943 Farmall M
Old 04-10-2008, 04:28 AM   #11
wibilly
wibilly's Avatar
i never cared for holly carbs but love my street avenger
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-10-2008, 04:35 AM   #12
BarryB
BarryB's Avatar
I am planning on putting a 750 spread bore Holley on my 383 stroker motor. I might have to jet it down some but what is the point of having a stoker if your going to putt around in it.????
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-10-2008, 11:10 PM   #13
67chevemall
I have a weiland square bore manifold. Would this be the problem with the 1406?
I took a few of your guys advice and bought the bigger thinker gasket from summit.
I put the carb on last night.
I am going out to blow out all the fuel lines and get some fuel up there.
see what happens this time.
It has been a while.
I like the looks of that avenger. thanks for that tip.
Old 04-10-2008, 11:32 PM   #14
bryanw1968
bryanw1968's Avatar
I am not a holley guy anymore but when I had my 383 I ran a 780 and it was perfect!!!
A think a 650 is just not enough carb especially when we're talking about holley's.
If you're talking a Demon it's different. They underrate their flow numbers quite a bit. My BG650 DP flows 725cfm. I attempted to run a BG750DP on my pretty punchy 355 and it was WAY too much carb. My .02 cents......
Good luck,
B
bryanw1968 is offline   Reply With Quote
Old 04-11-2008, 12:25 AM   #15
BurnoutNova
BurnoutNova's Avatar
sort of, your right about fuel economy. i'd say some machanical secondary/ double pumpers are racing carbs. the ones with no chokes, and huge acelerator pumps and/or dominators. alot of cars came with them from the factory, and the one on my nova is a out of the box 650 DP, and it runs around great on the street. no driveability probleoms at all. it does like the gas though.
BurnoutNova is offline   Reply With Quote
Old 04-11-2008, 12:40 AM   #16
Billla
Billla's Avatar
Even the ones with chokes are really racing carbs; the driveability problems of quickly-opening secondaries get covered up by a big shot from the accelerator pump.
The most common "big" carb was the Holley 780 which was a 4150 vacuum secondary carb with a secondary metering block in place of the standard plate - like a 3310 today. Even the LT-1/ZR-1 used this carb. As far as I know (and I ain't the expert ), the only factory Chevy mechanical secondary carbs were used on the 302 cross-ram and the ZL-1/L-88...not really street engines ;-)
As noted, it's really just a choice - if immediate accelleration is your bag, then that's the one area where a mechanical secondary carb will shine.
Old 04-11-2008, 12:44 AM   #17
b&a72
Active Member
b&a72's Avatar
I am running a 750 double pumper on mine as well and love it! Well before the teardown at least.
b&a72 is offline   Reply With Quote
Old 04-11-2008, 12:58 AM   #18
chevy72blu
chevy72blu's Avatar
The 4150 780's are great carbs... I had one built by a guy I know (modified bleeds, air horn/choke tower delete, etc ect) for my BBC. Suposedly they will flow 810 cfm. They are pretty sought after as corvette restoration carbs.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-11-2008, 01:04 AM   #19
Billla
Billla's Avatar
Most definitely - I have 3 of these; one LT-1 original from 1970 and two reproductions that were available directly from Holley in the early 80's. I also have the LT-1 intakes to match; 1 original with a late '69 cast date and two reproductions available from GM also in 80's.
The original stuff is going into a factory correct (but with a refit roller cam ) LT-1 I'm building...slowly...for my '69 Corvette. The others I'm just holding in trust for the right project. I love this setup for a hot 425+ HP GEN I.
Old 04-11-2008, 02:33 AM   #20
BurnoutNova
what do you mean by lt-1/zr-1? im very farmiliar with the 70-72 lt-1's but the only zr-1 ive heard of is the 90's corvette zr1
is there another?
Old 04-11-2008, 03:08 AM   #21
Billla
Billla's Avatar
what do you mean by lt-1/zr-1? im very farmiliar with the 70-72 lt-1's but the only zr-1 ive heard of is the 90's corvette zr1 is there another?
A bit OT - but yes, there is!
The original ZR-1 was a special purpose 1970 LT-1 Corvette that required mandatory options that were typically only available with the L-88/ZL-1; HD brakes (J50/56), HD suspension, HD transmission (M-22) and radio delete. It could not be ordered with power windows, power steering, A/C, rear window defrosters or wheel covers.
A ZR-2 with an LS-7 454 was planned but never released.
Old 04-11-2008, 03:44 AM   #22
piecesparts
Parts and more parts
piecesparts's Avatar
Everyone has their taste in carbs. Holley supports the vacuum secondary carbs BECAUSE that is what they sell. Edelbrock sells the mechanical secondary carbs and so does Carter. You will note the Carter AFB and Edelbrock series carbs are the EXACT same thing, just different names on the outside. Both are made by an outside company and marketed by the appropriate supplier. Demon is great in some people's eyes and others have had nothing but trouble.
I am presently running an Edelbrock Thunder carb AVS (650 CFM---not the 600 CFM size that the 1406 carbs are). The step up made the 385 engine work real well in daily driving. I had a 750 carb for a short period and suffered the problems of too much cam and not enough gearing (at that time) and deinitely too much gas for daily driving. Since then I have changed to a 3.73 gear ratio and the 650 works that real well up to about 5000 RPMs. With the OD tranny, I don't even phase that RPM and the speedo is pegged out of site. As for the mechanical secondaries--the adjustment of the carb is the game not just bolt the thing on and watch it work. I run a 385 stroked motor with a dual plane intake, Comp Cams roller valve train, 700 R4 tranny, 3.73 posi and I get 15 MPG. I don't consider it bad for a truck that can eat a Mustang and burp the waste parts out.
I personally would look at a 750 carb, IF and only IF, you had a light weight vehicle---with a low geared rear end and plenty of RPMs in your cruising. Otherwise you will experience a lot of bogging at stoplights and lousey gas mileage. Just ask any distributor (Holley, Edelbrock, Carter, or Barry Grant) and they will support this. I did ask them and they all talk the same line in figuring carb size. You wnat to keep the air velocity up in your intake or the package you pick for performance will suffer. The slightly smaller CFM rating on a heavier truck is desired.
Once again everyone has their own taste.
Old 04-11-2008, 04:10 AM   #23
Billla
Billla's Avatar
Holley makes vacuum and mechanical secondary carbs - so they sell both. I see less about "taste" around sizing and configuration - this is driven by the application. "Taste" in brands is definitely true
Definitely agree that happiness on a street carb is all about intake velocity.
Old 04-11-2008, 04:25 AM   #24
67chevemall
Well the truck is cleaned up and the 1406 is on there. I am getting new plugs cap rotor and oil/filter gas on pay day. Go from there.
The oil is draining now and the F cell is yelling for fuel.
Start it and see if I need the shop or not.
Old 04-11-2008, 04:59 AM   #25
BurnoutNova
very interesting, ive never heard of that! an LS7 corvette would have been absoulutely INSANE... if it could keep from breaking the axles, assumming it could catch traction also
i think thats kinda neat, they use rpo codes from the past on newer stuff, like the original LT-1 and LSX engine codes
