Old 04-30-2008, 07:00 AM   #1
salrod00
salrod00's Avatar
Unhappy 02 silverado fuel injectors.
i just got my check engine light checked out at the local auto part store and was told that i have a bad injector. after that i took it to my buddys mechanic shop and put a diagnostic computer to it. it told me that my 2nd fuel injector is bad. it was reading 318 miss fires . my 1st injector was reading around 20 miss fires . how bad is this. can i drive it for a couple of days or does it need to be fix asap. also can a average person fix it or is it hard to mess with. i have a v6 motor and the injectors are inside of a cover not on a fuel rail.. please any advice will be appreciated
salrod00 is offline   Reply With Quote
Old 04-30-2008, 07:16 AM   #2
89 crew
Re: 02 silverado fuel injectors.
What was the code related to your problem? If you can drive it or not depends on what the computer says. If the computer can recognize there is a dead cylinder then you can drive it, if not you can't,
89 crew is offline   Reply With Quote
