Old 10-08-2009, 10:24 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Re: 1970 VA Longbed Project
Got a decent amount done but still have a long way to go...keep on having interruptions. But got around 4 hours in today. Here are a few pictures and I will post more later.
Got some A-arms from camtoys1 (mike) that he's chemically stripped. Still had a little undercoating on them but really saved me a lot of time.
Before and after
Closeup of a cleaned upper arm
Cleaned up lower A-arm...still have to take the bumpstop bracket off...
Old 10-08-2009, 10:52 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Before and after on the lowers
Tools used to remove the bumpstop bracket. Drilled out the spot welds then used the air chisel to pry it off.
Off
Old 10-08-2009, 10:53 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Got the steering linkage apart with a little persuasion...
Old 10-08-2009, 10:56 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Started priming
More priming
More
Crossmember closeup-holes drilled for the upper bag plates before paint
Painted
Upper a-arm
Extreme closeup....
Note: I put one more coat on after this...you can see it is thin on the bottom of the picture.
Old 10-08-2009, 11:11 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Started cleaning/grinding the engine down. Want to make it nice and smooth because I will be painting it to match the truck.
The numbers on the block really showed up well after wire wheeling all the old paint off.
Started here but you can see some of the slag/rough areas on the block around the oil filter
Smoothed out...going to do a little more before paint.
Should have taken more before and afters...
This corner was very rough before
Got the intake off...looks clean in there and I plan to keep it that way...
Will do a little more grinding on the block later. Didn't want to do it today with all the freshly painted parts laying around the shop floor.
Old 10-09-2009, 07:22 AM   #6
0331grunt
Now what??
0331grunt's Avatar
Looking good!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 10-09-2009, 12:55 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Ahhhh...pictures of progress.....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-09-2009, 01:17 PM   #8
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-09-2009, 02:24 PM   #9
brian69longbed
brian69longbed's Avatar
those control arms look better than new!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 10-09-2009, 02:29 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by 0331grunt View Post
Looking good!
Thanks!
I knew you needed your "fix"
Originally Posted by my67chevytruck View Post
looking good!
Thank you. Trying to catch up to you
Thanks, it took long enough...even with all the prep done it was still about 4 hours between taking off the brackets, grinding them, prepping, priming, and painting.
Old 10-09-2009, 09:17 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
NO PICTURES!
However, I picked up a 5 lug rear with 373 gears, and freshened up with new seals/bearings from mike (camtoys1)
The best part of the rear are the glock's brackets with CROSS-drilled rotors and nice big calipers.
Going to have 4 wheel cross drilled discs!!!!
Old 10-09-2009, 09:41 PM   #12
OARNGESI
OARNGESI's Avatar
So are you going five lug now
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-09-2009, 09:58 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Yep, either doing coys C5, Torque thrust, Foose nitrous 2, or the new design Boss 338's....whatever I find the best deal on
Going to sell the billet wheels to help finance the final details of the project. Doesn't make sense to have a $4K set of billet wheels and skimp on the paint and interior.
Old 10-15-2009, 09:57 AM   #14
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Originally Posted by VA72C10 View Post
NO PICTURES!
I actually got those brackets from CaptainFab on the 66 board. Rotors were cross drilled by me at home on my drill press. Took some time but looked great.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-15-2009, 10:13 AM   #15
VA72C10
VA72C10
VA72C10's Avatar
Very nice work. Good to know the rest of the story.....and now I know who to blame if I have rear brake issues
Old 10-15-2009, 10:53 AM   #16
STOCKISH
STOCKISH's Avatar
I hear ya.
--Josh
Old 10-09-2009, 10:03 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
Not sure if I mentioned this or not, but I paid for a Brother's one piece window setup from Budnikguy the other day...should be shipping my way next week.
Got a lot of nice parts coming together!!! I'm getting excited!
Old 10-10-2009, 11:05 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
Guys, I am grinning ear to ear and almost laughing I'm so happy with today's progress. And I didn't get a lot of time due to family commitments...but still got a lot done....pictures to follow...here's what I started with...
And guess why Jason added this dormer in the roof of his shop????
Old 10-10-2009, 11:28 PM   #19
brn agn
brn agn's Avatar
Lift?
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 10-11-2009, 12:16 AM   #20
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by brn agn View Post
Lift?
Winner!
Yep, he's getting a used but very nice assymetrical lift tomorrow. I will be going by to help him after Church. It is going to help a ton with setting the cab and bed back on the chassis and doing exhaust, etc....
Old 10-11-2009, 12:20 AM   #21
VA72C10
VA72C10
VA72C10's Avatar
Well, I am still smiling from a sense of accomplishment today. It was my first time messing with a rear at all and was easier than expected. I asked Jason some questions to make sure I didn't mess anything up, but it was not bad at all. Jason has really been a great help through this and I wouldn't be nearly this far without his help and help from many on this board.
I got good at taking axles out and putting them in...I put the cart before the horse so to speak and forgot to put the brake brackets on before the axles. So I pulled them again and installed them again. Second time was like 2 minutes to pull and reinstall max.
Old 10-11-2009, 12:42 AM   #22
VA72C10
VA72C10
VA72C10's Avatar
Okay, and now.....the Money shots
Old 12-12-2009, 01:17 PM   #23
Dahawk
what brake kit did you use on the rear?
Dahawk is offline   Reply With Quote
Old 10-11-2009, 12:24 AM   #24
VA72C10
VA72C10
VA72C10's Avatar
Well, here are more pictures from today's festivities
Parts I finished painting the other day after their second coat....purdy
Getting the axles out
Tape is to label drivers and passengers in case there were wear marks...Jason recommended it an I figured better safe than sorry.
Old 10-11-2009, 12:25 AM   #25
VA72C10
VA72C10
VA72C10's Avatar
Then I started cleaning it up
Found a bunch of numbers buried in the gunk
