Old 05-13-2008, 04:20 AM   #1
Square84
I don't think these pills work
Square84's Avatar
Re: Static drop lowering-totally lost!
i guess thats what happens when your 16 have no job and want a low truck you do what you got to do.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 05-13-2008, 05:48 AM   #2
Square84
Square84's Avatar
How Much Drop Will Cutting One Coil On A Full Size Get You ? On The S10 One Coil Was Close To Three Inches Thats Why I Heated Mine Because I Didnt Want It That Low. I Want To Lower My Burb With Spindles But I Wanna Get About 4 Inches In Front And Spindles Only Do 3 At Most.
SQUARE84
90 SUBURBAN
Old 05-14-2008, 03:03 AM   #3
C10 the GEM
Smok'em Roast'em Shift'em
C10 the GEM's Avatar
I plan on dropping the front 5 and the rear about 7. With a c-notch. If i go with the 7" drop in the rear will i need a big c-notch?
C10 the GEM is offline   Reply With Quote
Old 05-14-2008, 03:51 AM   #4
69face
69face's Avatar
you will need at least a three inch notch to be happy
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 05-14-2008, 05:05 AM   #5
C10 the GEM
will the notch that comes in the sport truck direct kit enough?
5/7 drop
http://sporttruckdirect.com/C10_kits.html
Old 05-14-2008, 07:35 AM   #6
SCOTI
SCOTI's Avatar
5/7 drop
Yes, that notch will work w/a ~7" rear drop (flip kit on an 8-leaf HD spring pack + drop shackles).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2008, 05:43 AM   #7
C10 the GEM
do you have any pics of the process of lowering it such as your c-notch and your flip kit?
