Old 06-16-2008, 12:49 PM   #1
caminokid
Chevy nut
caminokid's Avatar
5 lug rear axles installed...Problem
Ok so what I did was used the 69 rear end casing and the posi. Axles went right in no problem. They are a little longer then they should be....and the problem is the drums dont sit all the way to the backing plate. I see about a 1/4 between the backing plate and the drum.
I should add these are 77 12 axles.
Heres some pics to get a better idea.
I dont know if I should get longer bolts and shim the backing plate or get the axles shorten.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-16-2008, 12:55 PM   #2
cdowns
cdowns's Avatar
Re: 5 lug rear axles installed...Problem
the later year axels are longer than the 68's you need to have them shortened if possible or get custom axels built from a place like currie or moser to use the 68housing//or get a 70 71 or 72 housing
Old 06-16-2008, 12:55 PM   #3
caminokid
Chevy nut
caminokid's Avatar
More
The axles seem to sit close in there but dont touch.
The other problem I seen...this...
I took it out to inspect it and found one of the plates was cracked. I welded it. Isnt there supposed to be something holding this together?
Old 06-16-2008, 12:58 PM   #4
Jim_PA
I ran the wider brake drums for a while without issue (I believe they are 2.5" from a late-70's truck.)
I was using 71-72 axles in my 68 housing.
Jim_PA is offline   Reply With Quote
Old 06-16-2008, 01:16 PM   #5
c10addict
c10addict's Avatar
I never heard of these axles working with bigger drums... When building my 68 I ran to the bone yard and got a set of 72 5 lug axles and learned the hard way they didn't fit... Nothing like laying in the mud fighting off bees, snakes and rusted bolts for a few hours to find out they didn't fit... That was long before I knew anout this forum!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-16-2008, 01:17 PM   #6
nightmare
nightmare's Avatar
Originally Posted by caminokid View Post
More
Those plates and springs are what makes the unit a posi. If I remember correctly, the only thing holding those in there is the center pin (the vertical bar in the top pic). Other than that, the sheer pressure from the springs does the rest.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
Old 06-16-2008, 01:18 PM   #7
Jim_PA
Yeah, the extra depth in the wider drums just fills space, you retain the 2" shoes.
Old 06-16-2008, 02:35 PM   #8
cameeks
Long Fleet Club
cameeks's Avatar
This is from the CPP web site.
Part # 6369RAC5 ---1963-69 5-lug Conversion Axle, pair --- $289.00
Well they have a copy lock here is the description page http://www.classicperform.com/Store/.../6369RAC-5.htm
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 06-16-2008, 03:38 PM   #9
royo
royo's Avatar
If your short on funds i dont see where it would hurt to shim the backing plates.
nickle and dime
royo is offline   Reply With Quote
Old 06-16-2008, 04:47 PM   #10
caminokid
Chevy nut
caminokid's Avatar
I was thinking the same and adding deeper drums. I might be ok then.
Old 06-16-2008, 04:49 PM   #11
caminokid
Chevy nut
caminokid's Avatar
Its an option if I cant get these to work short of getting them shortened.
Old 06-16-2008, 04:51 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A lot of people get away with wider drums, but you would be running a part of the axle shaft on the bearings, that was not designed to take that kind of wear, and adding leverage on top of that.
Old 06-16-2008, 04:57 PM   #13
caminokid
Chevy nut
caminokid's Avatar
I didnt think of that Andy...good call! Well maybe shortening the axles is an idea. I wish I had a better welder. I think I would try it. I will find out how much it will take.
Old 06-16-2008, 05:10 PM   #14
Longhorn Man
like I said, a lot of people get away with it.. but personally, I wouldn't do it. I've lost a wheel at 45 MPH once (actually i was passenger) and it scared the CRAP out of me.
Old 06-16-2008, 06:38 PM   #15
scottrod71
scottrod71's Avatar
I had the same problem on my '69 when I swapped over from 6 lug to 5. Easy solution is to buy them from ECE or LMC. I'm sure others carry them as well. Direct bolt-up and easy swap.
scottrod71 is offline   Reply With Quote
Old 06-16-2008, 07:19 PM   #16
LONGHAIR
I don't think you can shorten C-clip style axles. The splined section is larger diameter than the rest of the axle. The only axles that can be shortened are the ones that get bigger right behind the splined area. They cut of the needed amount, turn the larger diameter down to the correct size, then re-cut the splines.
A welder is of no use to you in this......
I don't think I would do the spacer behind the backing plate deal either. You increase the load on the bolts. Plus there would be quite a bit of effort involved in making a "decent" spacer anyway.
Andy is quite right about the axle not running in the right place on the bearing surface.
It pretty much comes down to getting the right axles or swapping the whole housing.
LONGHAIR is offline   Reply With Quote
Old 06-16-2008, 07:50 PM   #17
cparman
sharp as a marble
I agree with long horn man. Wheel brg is riding on the wrong part of the axle. I am WAAY too old for that thrill ride, or the axle grease on my brakes shoes, or the brakes grabbing and locking up on a wet street, in front of the police on the way home from my favorite watering hole, AND then trying to explain to my wife why it is not my fault that I got a ticket. ha ha
cparman is offline   Reply With Quote
Old 06-16-2008, 08:05 PM   #18
caminokid
Chevy nut
caminokid's Avatar
I think I will just get a set of axles. Its under 300.00 So that wont be so bad. Could be worse.
Old 06-16-2008, 08:17 PM   #19
Old Money
try using newer style backing plates and drums. i remember switching axles, plates , brake lines wheel cyl.and drums from 72 to 70 in one complete move. it seemed to look okay at the time. pull axles and drums, then remove plates wheel cyl. and lines at the same time while keeping them all together. i did this early one sunday morning years ago and surprised myself on how easy it really was. old money.
Old Money is offline   Reply With Quote
Old 06-16-2008, 09:28 PM   #20
caminokid
Chevy nut
caminokid's Avatar
I have the 77 backing plates on there now. The axles are just to long. Like Andy said the bearing is going to be riding in the wrong place. Better safe then sorry
Old 06-16-2008, 09:55 PM   #21
Longhorn Man
in mid 70, they went to the wider rear end, but retained the 6 lug shafts.
Old money has the wider rear, so the 5 lug shafts just slid right in.
I am shocked that people are agreeing with me, I normally get semi-flamed when I say this.
Old 06-16-2008, 11:00 PM   #22
caminokid
Chevy nut
caminokid's Avatar
well I guess its cause I have picture proof that its not working and you pointed out these are going to cause problems.
This is the first time I have done a swap like this...so really dont know. Now if I am sure about something and someone tries to steer someone wrong I will say something. But not flame.
Old 06-17-2008, 08:02 AM   #23
Jim_PA
Running the wider drums is a perfectly fine option. The bearing surface is plenty wide on the end of the shaft, and no, the axle grease doesn't run all over your brakes either
It wouldn't be my FIRST choice for how to fix the problem, but if you want to do something on-the cheap for your driver or beater, or just want to get something on the road, it's fine.
Old 06-17-2008, 09:36 AM   #24
raggedjim
raggedjim's Avatar
caminokid, where are you in Illinois?
I have a '72 5-lug rearend you can have (complete from drum to drum).
I can't vouch for how good it is and it is dirty/greasy, but if you jump in a truck and come to Murray KY you can have it.
Just a thought, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is online now   Reply With Quote
Old 06-17-2008, 10:06 AM   #25
p-low
p-low's Avatar
i thought that the only useable 5 lug axles were from 71-2 trucks of our bodystyle...do those slide right in i would imagine so....is the problem here not the fact that the donor truck is a 77? because i know the 73-87 had a wider rear by and inch and a half or so correct?
p-low is offline   Reply With Quote
