06-20-2008, 12:38 PM | #1 |
Camaro SS Rims on 73-87?
I found these rims in a local add, I got to thinking that these would look pretty sweet!
They are 17" but I dont know the offset. Does anyone know what the offset would be and/or if they would fit?? The ad said they came off a 1998-2002 Camaro. Thanks! |
06-20-2008, 01:15 PM | #2 |
Re: Camaro SS Rims on 73-87?
i think camaros have the 5x4 1/2 bolt pattern. could be wrong for these years, but i know its correct for the 3rd gens.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
06-20-2008, 01:16 PM | #3 |
Wrong bolt circle and bad offset...
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-20-2008, 01:42 PM | #4 |
I think it is actually 4 3/4" not 4 1/2"....Either way it won't fit a 5" patterned truck.
S-10 yes, full size truck ....no. |
06-20-2008, 01:46 PM | #5 |
the pollock
those woudl look kinda hott too bad thou...
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
06-20-2008, 03:14 PM | #6 | |
I would suppose if you converted to rear discs you could come up with something there but what about the fronts? It would open up a whole 'nother world of used rims.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
06-20-2008, 03:18 PM | #7 | |
Rg
06-20-2008, 03:36 PM | #8 |
yeah, that sounds right. been away from camaros a little too long it looks like.
06-20-2008, 04:22 PM | #9 |
They are the 5x4.75 car pattern but that's easily changed w/a little money. Rotors can have the hubs machined down to the correct dimension & then re-drilled for a car bolt pattern.
The other issue not mentioned yet is the off-set. The f-bodies use a bunch of back-spacing that won't work for these trucks. There's a way around that too. Billet adapters could be used to reduce the overall amount of back spacing (basically like making the track width wider which would require a wheel w/more BSing). So if adapters are needed, they can be purchased in the necessary width to correct the BSing & change the bolt pattern @ the same time.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-20-2008 at 04:22 PM. |
06-20-2008, 04:46 PM | #10 | |
So If I am understanding this correctly, the BS of the Camaro/Firebird (what about Corvette?) wheels would require the use of an adapter to get them centered correctly anyways, and those can be had in a 5x4-3/4 / 5x5 pattern?
Hmmm.... Quote:
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 06-20-2008 at 04:47 PM. |
06-20-2008, 04:52 PM | #11 |
So how many people actually run spacers? I was talking to a guy at the local performance shop about this and we came to the conclusion that anything that would decrease the strength of a stud would be bad news!
Think about it, all the weight of the wheel being pushed down on the end of a bolt. Then add in rolling mass, and centripedal force! Seems like asking for trouble flying down the freeway! |
06-20-2008, 05:28 PM | #12 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-20-2008 at 05:32 PM. |
06-20-2008, 05:28 PM | #13 | |
Scotti is right on. You could probably swap some suspension parts and make some of the camaro brake stuff work with some fabrication. But to do it "cheap" (which should still cost a couple hundred bucks), and since you should have plenty of room--adaptors would work. I used like 3 inch adaptors on a 3640lb, 400-500 hp Buick for five years with no problems. They were on the rears at that, and I made many many 15psi launches. I think the manufacturer was Skulte. Just make sure and get the appropriate length of ARP hardened studs to be on the safe side.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd Last edited by jdurant; 06-20-2008 at 05:30 PM. |
06-20-2008, 05:37 PM | #14 |
http://www.adaptitusa.com/index.asp?...PROD&ProdID=14
I'm lookin in to this as well, my bro has centerlines from his 80 camaro he'd give me. |
06-20-2008, 05:53 PM | #15 |
Magnificent bastard
I used a pair of aluminum 1.5" adapters on the front axle of a rockcrawler with 40" tires. Never had a problem with them.
1977 Big Block Burb |
06-20-2008, 06:12 PM | #16 |
If you are doing it to use inexpensive wheels, you're probably jumping over a dollar to save a dime. But if you really want those wheels, it's pretty easy, just cost a couple hundred to do it.
06-20-2008, 07:13 PM | #17 |
Happy to be here
To be specific these were "billet" aluminum adapters, not "cast" aluminum adapters...
06-20-2008, 07:30 PM | #18 |
Magnificent bastard
Correct.
06-20-2008, 09:32 PM | #19 | |
My TT2's not only fit my truck (w/adapters), they will also fit early GM a-bodys (chevelles, gto's, olds, buicks); f-bodies 70-81 w/o mods, 67-69's w/mini-tubs; etc . . ...... You get the picture though. With more possibilities, they'll only be easier to move.
06-22-2008, 02:19 PM | #20 |
That rims will fit in a s10 trucks but in the full size trucks won´t fit.. I saw a 72 camaro with a s10 rims....
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
06-22-2008, 03:31 PM | #21 | |
9" wheel + 1" (lip dimension) = 10" total width 10"/2 = 5" total (5" = C/L of wheel) 5" + (50mm x .03937) = 6.9685" (the off-set converted to BS in inches) Since 73-87's typically use an 8" wheel in front w/anywhere from 4-5.25" BS-ing, we'll use the medium BS number of 4.5". If you increase the wheel width by 1" evenly, that suggests 5" BS needed for a 9" wheel. Using those SS 10-spoke wheels, you could add a 5x5 to 5x4.75 billet adapter that is 2" wide. 6.96" (calculated BS) - 5" (required BS) = 1.96 (amount the wheel needs to be adjusted). A 2" adapter would be the closest to that dimension. Clear as mud?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-22-2008 at 03:33 PM. |
06-22-2008, 04:13 PM | #22 |
And that would add at least $200 to the cost.
If you are getting a good enough deal on the wheels, it's not that bad. |
06-22-2008, 04:51 PM | #23 |
Correct. You can't adapt them for free so it does need to be figured into the overall cost when deciding.
06-22-2008, 06:12 PM | #24 |
Good point. I have some adapters, and I've swapped brake drums to change to a more popular bolt pattern on another vehicle.
06-23-2008, 11:56 AM | #25 | |
Here is the reply to my email asking about BS
So the asking price for these wheels is 500. No tires- anyone think thats a decent price for a 17" rim? Tires wont be cheap either- well a lot more pricey then my rallys! |
