Old 06-22-2008, 04:12 PM   #1
ratrod41
ratrod41's Avatar
Drive Shaft Center Support Bearing
Hi Everyone,
Has anyone ever replaced a drive shaft center support bearing on a 69 C-10?
I need to do this and need some information on how it is done.
Please help if you have any information or experience doing this.
Thank you for your help.
Jason
ratrod41 is offline   Reply With Quote
Old 06-22-2008, 04:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Drive Shaft Center Support Bearing
your absolute best bet is to take it to a drive shaft shop.
Old 06-22-2008, 08:27 PM   #3
cdowns
cdowns's Avatar
yeah after 40years of use a balance job and carrier bearing is cheap maintenance at the drive shaft shop i'd suggest new ujoints at the same time
Old 06-23-2008, 10:08 AM   #4
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I just had mine replaced,and for $125 i would not think of tackling the job. Having it balanced by someone that knows what there doing is very important.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 06-23-2008, 10:32 AM   #5
truckdude239
truckdude239's Avatar
i have replaced mine 3 times in one year next time ti goes to a drive shaft shop
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-23-2008, 03:23 PM   #6
neonlarry
neonlarry's Avatar
I do mine myself, but I have a press. They can be done without a press but not easily. If you don't have one much easier to take it to a driveline shop.
If you have the 'I' type unless you get a billet one I would advise having some tack welding done to reinforce the spot welds.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-23-2008, 04:29 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
i work in a driveline shop and would definatly not recomend doing at home, the specialized tools (vices, bearing drivers) make the job alot easier and less likely to damage the shaft. its cheaper to do it once the right way.
ballancing and new u-joints wont hurt at all.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 06-23-2008, 06:16 PM   #8
Longhorn Man
Just remember that shaft is spinning anywhere from 2500 RPM to 3500 RPM (depending on your gears) when you are rolling down the freeway.
you'd never even CONSIDER beating on the crankshaft with a hammer, so why do it to the shaft?
Old 06-28-2008, 09:20 AM   #9
ratrod41
ratrod41's Avatar
Thumbs up Re: Drive Shaft Center Support Bearing
Thanks everyone for the advice and help.
Old 06-28-2008, 09:50 AM   #10
7DEETWO
7DEETWO's Avatar
It must be the season mine just snapped the other day. Lucky for me I was only two blocks from my house and I was rolling about 5 mph. I was able to crawl home. The tow truck arrived the next day, and my mechanic Jessie hooked me up with a New Center Bearing Support and all new U-joints. The spot welds were also reinforced. I still find it hard to believe the bearing was designed with aluminum and spot welds!!!! I have to agree with everyone on this issue without the tools, and lift, it’s just not worth it to try it yourself.
I was back on the road in 24 hours.
Good Luck
7DEETWO
7DEETWO is offline   Reply With Quote
Old 06-28-2008, 10:13 AM   #11
72BLUZ
72BLUZ's Avatar
TAKE IT OUT AND DO WHAT HE SAID!!!!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 06-28-2008, 04:12 PM   #12
Longhorn Man
I'm the cheapest SOB you'll meet in many areas... but both my Longhorn and my Burb have had the shafts taken care of profesionally. New sealed U joints and a seriouse HD carrier bearing on the longhorn, spin, check for trueness, and ballanced. ($210) I just had the burb's shaft done last week, same thing except not a real H.D. carrier bearing nor sealed U-joints, inspect, spin, ballance... pulled some strings and had it out the door for $130.
Money well spent, and they'll be good for another 20+ years.
Old 06-28-2008, 05:04 PM   #13
my70chevyc10
my70chevyc10's Avatar
Talking Re: Drive Shaft Center Support Bearing
I had mine done about 6 months ago at was $175 and that included all new u-joints HD center bearing balencing they sandblasted and painted it black for me and installed a slip yoke in it to. I had them install the slip yoke because i lowered my truck almost 6in in the rear and the guy said when the suspention goes up an down the drive shaft moves forward and back. With the slip yoke only the back half of the shaft goes forward and back while the front part with the bearing stays in one place.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 06-28-2008, 05:08 PM   #14
pat123
Pat
pat123's Avatar
i did mine about a montha go and used a vice
pat123 is offline   Reply With Quote
Old 06-28-2008, 06:05 PM   #15
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Not sure of the cost but this looks like a trick setup and would last just about forever.
http://www.iedls.com/twopiece.html
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-28-2008, 09:27 PM   #16
justcuz
justcuz's Avatar
My 72 does not have a slip joint on the back half. Just in front going into the transmission. This has to shorten the life of those carrier bearings with the loading of the bearing and rubber as the rear end cycles up and down. When I get to mine it will be built like the picture above, with a slip joint behind the carrier bearing.
justcuz is offline   Reply With Quote
Old 06-28-2008, 09:38 PM   #17
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I had my 2 piece drive shaft replaced with a custom 1 piece drive shaft at Fort Worth Gear and Axle.
It was 1/4 inch shorter than the maximum length they would warranty.
Completely solved the carrier bearing problem.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 04-24-2015, 11:11 AM   #18
dmw319
Bumping an old thread. Is there not an easier way to do this than take it to a shop? Doesn't look too complicated to me, although I have never done this before on my truck. The whole unit is only $31 includes bearing and support...
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 04-24-2015, 11:45 AM   #19
leftybass209
leftybass209's Avatar
There is an easier way, you can drive it off. Just because it's easy, doesn't mean it's correct. You HAVE to send it to a driveline shop anyway to have it balanced when it's out, why risk damaging your vehicle, or someone else's?
leftybass209 is offline   Reply With Quote
Old 04-24-2015, 11:48 AM   #20
dmw319
what's a typical price for having the center support bracket installed and driveshaft balanced?
Old 04-24-2015, 12:02 PM   #21
dmw319
So far, I've got 3 quotes. 2 of which said I shouldn't need to rebalance the driveshaft, but would if needed.
Quotes were $150, $200, and $285. Just for the center support bracket/bearing assembly and balancing. Does that sound about right?
Old 04-24-2015, 12:02 PM   #22
leftybass209
We're across the country from each other so I can't speculate your prices. I called around and got quoted between 100-150. You just have to call around.
Old 04-24-2015, 12:11 PM   #23
VDOG
Grand PooBaa Member
VDOG's Avatar
The 2 times I lowered my truck I had to change my carrier bearing months later. I had a auto parts machine shop do it for me. 50 bucks both times.
I took it out, marked the way it came out and took the shaft and new bearing to them. 2 hours later it was done.
VDOG is offline   Reply With Quote
Old 04-24-2015, 12:14 PM   #24
dmw319
Yeah, I do know a good machine shop that isn't far. I will give them a call too
Old 04-24-2015, 12:21 PM   #25
Davidf
I recently replaced the center support bearing and it was very easy. I cannot fathom the need to have someone else do this very simple task. Just mark the relationship of the two driveshaft sections relative to each other. Remove the u-joint, remove the yoke bolt. Drive off the support bearing (used a chisel). Install new bearing and use bolt to press it on (ensure you have the alignment marks matched up). Install u-joint and done. No balance issues because nothing was changed.
Davidf is offline   Reply With Quote
