Old 05-23-2002, 05:55 PM   #1
thood
thood's Avatar
Question temp gauge question.
I am having some trouble with my temp gauge. As soon as I turn the key to the on position the needle pegs!! Am I missing a ground or something? I replaced the sending unit and that still did not fix the problem. If someone could shed a little light on this it would be very helpful. Thank you.
70 swb restored by me
I hope to drive it some day!! portland OR
70 swb restored by myself and some help from this board!!
thood is offline   Reply With Quote
Old 05-23-2002, 06:36 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The wire connected to the sending unit is probably grounded somewhere between the sending unit and the guage. Inspect the wire carefully.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-23-2002, 08:31 PM   #3
Elvis
Post
My temperature gauge use to bounce back and forth like crazy. I cleaned the wire attached to the sending unit and haven't had a problem since.
1972 Cheyenne 400BB
Elvis is offline   Reply With Quote
Old 05-23-2002, 08:55 PM   #4
conman
Post
I have same problem with my longhorn. I checked the wire, I finally bought another gauge (aftermarket) and mounted it below the dash. I think the resistor on the gauge itself is bad.
Fayette Alabama
conman is offline   Reply With Quote
Old 05-24-2002, 12:47 AM   #5
thood
thood's Avatar
Post
I checked the wire and It seems to be ok I will check agian and clean conections but I think I may have to replace gauge. thanks for the help.
Old 05-24-2002, 06:54 AM   #6
Ed ke6bnl
Wink
When you take the wire of the temp sender and touch it to ground it will show a overheat situation on the gage. What it sound like is that your wire is shorted at some place or at the sending unit. Take the wire off the sender is it still showing hot then the wire is most likey shorted to ground if not then I would go to the gage. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
Sorry 50 F1 pu
Sorry 63 Ford Econoline pu
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 05-24-2002, 02:04 PM   #7
thood
thood's Avatar
Unhappy
when I remove wire from sending unit it reads cold, as soon as I toch the wire to the sending unit it hits the peg above hot. it hits so hard I can hear it outside the cab!! new gage here I come. Thank you for the help.
70 swb restored by myself and some help from this bord!
[This message has been edited by thood (edited May 24, 2002).]
Old 05-24-2002, 07:50 PM   #8
Longhorn Man
Post
Get another sending unit then. The parts guy either gave you the wrong one, (dummy light part #) Or the parts guy's computer lied to him causing the part # problem.
Do you have it mounted on the intake, or on the driver's side head? It should be on the head.
Columbus Ohio
Old 05-25-2002, 08:54 AM   #9
robby
Semper Fidelis
robby's Avatar
Post
I have later model 305 heads and the hole is smaller than the sender I have, what sender can I use?
72 C-20 parts 70 C-10 lwb driver
69 C-10 lwb parts
72 K-5 Blazer-NEW!
Lamar,Missouri
Semper Fidelis
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 05-25-2002, 02:19 PM   #10
thood
thood's Avatar
Lightbulb
Longhornmail, The sending unit is in the head (drivers side). I have tried two diferent sending units as of now and they both work the same way. is there some way to tell between a gage unit and a light unit?
70 swb restored by myself and some help from this bord!!
Old 05-25-2002, 02:49 PM   #11
Longhorn Man
Unhappy
I'm sure there is, but I don't know what to look for.
Columbus Ohio
