Old 06-26-2008, 11:40 AM   #1
kwmech
AC work (that time of year)
Well to the point, putting a 400 small block in my 69 GMC 1 ton flat bed with a serpentine kit which uses the smaller AC compressor. I want to clean up the rest of the engine compartment and get rid of the POA system. I seem to recall about 3-4,5? years ago an article in here---YES I SEARCHED-- about pulling the box apart and installing an OLDS? evaporator and using a receiver/dryer along with an expansion valve and 134a. Anybody recall this? I even printed it out but have lost it.
Old 06-26-2008, 11:58 AM   #2
GSFMECH
On the road
GSFMECH's Avatar
Re: AC work (that time of year)
There was a good one in the FAQ as I recall.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 06-26-2008, 01:03 PM   #3
kwmech
Got a link? I couldn't find it--- I looked for just about an hour
Old 06-26-2008, 01:04 PM   #4
mrein3
mrein3's Avatar
Keep the POA:
http://www.autoacforum.com/messagevi...AR_MSGDBTABLE=
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-26-2008, 03:22 PM   #5
neonlarry
neonlarry's Avatar
Here are a couple of old links:
http://67-72chevytrucks.com/vboard/s...d.php?t=113552
http://67-72chevytrucks.com/vboard/s...d.php?t=112463
Also you do know you can get R12 compressors for a serp setup.
Mine came off a 96 9C1 Caprice.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-26-2008, 03:27 PM   #6
GSFMECH
On the road
GSFMECH's Avatar
The post by bobbyk is the one I remember and neon larry has posted a link to it above. That was a good thread.
Mike
Old 06-26-2008, 08:16 PM   #7
Chevyman680063
Chevyman680063's Avatar
Thankfully I didn't have that problem when I installed my new A/C in my '63 a couple months ago. It was a nice, clean install.
Chevyman680063 is offline   Reply With Quote
Old 06-26-2008, 08:20 PM   #8
neonlarry
neonlarry's Avatar
