Problems
hi everyone i was wondering if any one can help me
well here is the problem i rebuilt a quadrajet carb from a 1974 chevy truck with a 350 or 400 engine well when i went to install the rebuilt carb it ran but it ran the engine hot till i would throw water out the radiator tube so i put the old carb back on and the tempature came down whats the deal thanks ahead of time Marc |
Gotta luv a clean shave
Could it be running lean? Did you compare the jet size from the original carb? Rochester has a rebuild site, I believe. Try Rochester Qjet on the Google search engine and see what comes up. Sorry I can't be of more help but I have never had that happen.
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up! We make house calls too...just like the old days! |
Hootis is as Hootis does...
Sounds lean - I'd throw out the rottenchester and get something else...
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
