Re: Honest Abe's Shop Truck build
ok, cool deal. As Woody stated, I've never done a truck like this, so i'm working/learning as i go. That explains the loop over the diff that someone was asking about. I had initially planned on doing a wishbone 3-link and was going to use that as the center mount of the wishbone... then after locating the axle under the truck and trying to hook up the driveshaft, i noticed there was no slip in the carrier bearing and went to plan B.
after looking at the thread posted, that is a very SMALL obstacle that will be really easy to over come. Plans for sectioning the engine crossmember are already in the works, we're just trying to get the truck rolling for a show at the beginning of october to more/less debut the truck and new shop. so, laying crossmember/control arms won't take much of the shock value out. Then the truck's next appearance will be laying body with a few other goodies in the plans. Can't get any better, right? again, thanks for the comments and helpful hints!! |
****Updates****
Fab work is complete in the rear. Parts are torn down and getting sprayed tonight. Just gotta finish the wiring and a few small odds and ends.... So here are the pics already... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1971 Chevy C10 LWB Shop Truck 1984 Chevy C30 Dually LWB Tow Pig 1985 Chevy K5 Blazer |
Heres the tool Box I picked up for it for 30 bucks.
![]() ![]() ![]() And I little gift from my buddies bar. ![]()
Texas Big Wig
Oh, one more thing
I drilled a hole on the inside edge of my A-arm cup so it wouldnt hold water, dont know if you thought of that or not ![]() Last edited by Spray-Bomb; 09-24-2008 at 12:37 PM. |
Haha yea already done. lol. After it was finished we realized it would be a good idea.
Texas Big Wig
Ok, sounds good
One thing I wonder though The way your rear end is set up, it looks as though it would allow any articulation from side to side ??? |
thats what the track bar/diagonal link is for. it holds the suspension itself square. its pretty stout. those pictures of the bridge work with the wood... thats actually over head in case you can't tell.
Texas Big Wig
I wasnt worried about side to side, as I saw the track bar
Im saying that since all your pivot points are made to move vertically that it doesnt leave much room for articulation, such as if you had one bag inflated & the other one dumped The way your system looks to me, is that you would be fine doing FB, but FBSS might bind Example, but in an extreme ![]() |
nice "stacks of coins"
Looking good bro! I like the way you did your notch! what wheels are you going to run?
#14 | ||
Being ladder bars you dont get much articulation anyways. And I always ride about an inch off the ground and I NEVER pulls "sides". So it doesnt concern me in the least. The truck is built to be super low and ride super smooth and thats what it will do. Its not out to be a show stopper although it will draw quite a bit of attention. Thanks for the interest tho.
#15 |
soon to be bagged64sub
Nice work.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
#17 |
yep, i wasn't sure what you were asking. Thats what I thought you were asking then as i read further... I thought you were talking side/side movement. but yeah, minimal articulation in the axle, but its not a goal. My daily driver has a triangulated 4-link with bags on the lower bars and a levered shock setup. It gets MORE then enough articulation and has 8 valves... but i honestly couldn't tell you the last time i hit sides.
thanks for the continued positive comments! |
#19 |
In the final stages of completion. Hope to have it on the ground my late tonight.... Heres the current progress....
#20 |
#21 |
Texas Big Wig
Again, I dont really know because Im not there
But you do realize that the way you have your pna hard bar, that whatever flex there is in the two bushings for the trailing arms is how much your rear will move side to side, as there is nothing holding it to the frame other than those 2 bushings Cant wait to see it on the ground |
#22 |
I'm diggin your shop-truck project.
Do you plan to leave the tool box on top of the rails like that? I like the idea of the box for hiding your req'd air stuff & for actual storage any truck needs but think it would look better flush w/the top of the bed sides. Again.... nice job.
#23 | |
"Oh well, it's a driver."
Perfect - I especially like the manatee bumper sticker!
![]() When you pull up at a light in that old thing, and then lay it out...the looks on people's faces should just be priceless.
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#24 |
Its not necessarily a "pan hard" but a track locator. It keeps the 2 ladder pars parallel and will not let them sway keeping all 4 corners of the mount at 90degree angles.
#25 |
he's right... I don't like panhard bars as they will pull the axle one way or another when airing up/down. this is a different way of doing it will still performing the same general function.
Think of it this way... if you were to make a box, with no diagonal links from corner to corner, it will shift from side to side and won't remain square, right? If you take one bar and attach it from one corner to the other, it no longer will shift, it will stay square. right? That is how this setup functions. the 2 front ladder bar mounts and the axle mounts are your out side corners of the "box" and the diagonal link between opposing corners is what keeps it square... or, keeps the axle square under the truck. |
