08-28-2008, 08:46 PM | #1 |
i need help
truck keeps dying out when im driven engine shuts off right on the dime
08-28-2008, 09:00 PM | #2 |
i need help
truck keeps dying out while driven i mean shuts off
08-28-2008, 09:14 PM | #4 |
Re: i need help
08-28-2008, 09:14 PM | #5 |
Active Member
Re: i need help
Yep, we need some more info. Also, do you have an electronic distributor.
When you say shuts off. Do you lose all electrical power? Does it shut off like when you run out of fuel? If it shuts off completely, check your other electrical components like lights, horn, starter, etc. These all would give you clues as to whether it's an ignition problem, batter cable, ignition switch... |
08-28-2008, 09:19 PM | #6 |
Re: i need help
after it dies a minute later it starts right up drive for a block then it dies out again
08-28-2008, 09:27 PM | #7 |
.....I am working on it.....
Re: i need help
If it just dies like you turn off the ignition, I would guess either something in the HEI distributor or in the ignition module. Electrical short maybe? Check all of your connections at all of the ignition system.
08-28-2008, 10:53 PM | #8 |
Truck and auto performance nut
Re: i need help
fuel filter. or something else in the fuel system.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-28-2008, 11:03 PM | #9 | |
Active Member
Re: i need help
By supplying us with a just a little more information, we can maybe give you some better answers. As it is we're just guessing.. Anyway, here's another bump for you. |
08-28-2008, 11:48 PM | #10 |
Re: i need help
first off when it dies remove gas cap and see if it goes woosh if so you need a new gas cap vented this time// a second possible cause is fuel straioner in tank is filled with crud or you have a clogged up fuel filter in the carb
08-29-2008, 01:07 AM | #11 |
Re: i need help
i changed the module in the distributor
08-29-2008, 08:22 AM | #12 |
Re: i need help
If its a fuel problem, you will get some hesitation before it dies, are you experiencing that? Otherwise, I would still say its in the electrical.
08-29-2008, 07:58 PM | #13 |
Re: i need help
Very likely it is in the ignition. Fuel problems rarely if ever act this way. Start checking all the wiring connections positve and ground on the ignition. Make sure they are connected tight and no corrosion.
For further help here your going to need to provide a little bit better description of the problem and makeup of your vehicle. ie; Year, Make & model, engine size, type of distributor whether it's points or electronic, if it's an Hei, any modifications that have been done like... stock or performance upgrades, how many miles on the vehicle. Did this just start happening all of a sudden or after you worked on something. When was the last time a tune up was done? Get my drift here? Your question is far too vague for anyone here on the board to give you any kind of help or even a place to start, other than what I said about wires and connections. Good luck. God Bless, Terry |
08-30-2008, 01:32 AM | #14 |
Re: i need help
left out alot of vital info. gas or diesel?? 4cyl, 6cyl, 8 cyl??? efi or carb??? dizzy or dls??? i had an ignition module go out on my 84 sctottsdale and it just quit when hot. ive also had a fuel pump not able to keep up with demand and would die out. need more info. how long before it dies?? conditions when it dies???
72 chevy 3\4 ton 4 speed 4x4 84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories) 1999 suburban 4x4 1982 chevrolet S-10 V-8 (Thanks uncle EARL) |
09-01-2008, 03:00 AM | #15 |
Re: i need help
no hesitation at all shut off on da spot
09-03-2008, 08:02 AM | #16 |
Re: i need help
I remember my dad's 69 Camaro would die when going down the road for what seemed like no reason. After weeks of fustration ot was finally tracked down to one of the wires going down to the starter shorting out against exaust. It might be worth checking out. Good Luck.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
09-03-2008, 08:40 AM | #17 |
its all about the +6 inches
Re: i need help
2 threads merged together...
please don't double post. looking at some of the questions asked, that you can not answer.. you may as well take it to another mechanic. We are just sitting here guessing. |
09-03-2008, 09:04 AM | #18 |
Re: i need help
I had an old car do the same thing and it was a bad coil. Take it in and have it checked at a parts store.
09-03-2008, 09:15 AM | #19 |
Active Member
Re: i need help
Man, I think we've guessed just about every possible component on this truck and we still don't know anymore than when we started...
09-03-2008, 11:28 AM | #20 |
Re: i need help
My truck will die when it runs out of gas, then if I put some in it it will run fine again until I run out then it just dies again. Strange!
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 |
09-03-2008, 01:35 PM | #21 |
newly minted old timer
Re: i need help
pick up coil in the hei dist. is my wild guess. had that one happen to me.. lol. but since we have no clue if you have one or not.......
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
09-03-2008, 02:53 PM | #22 |
high-Tech Red Neck
Re: i need help
If it has a HEI, those are also prone to having the module on them go bad, they can have a situation where the module will run fine until it gets hot, then it will quit, it will then cool, and run until hot again.
Also you need to check the wiring connections going to the coil and cap.
"He used to be a pretty nice feller, now he's a welder!" |
09-03-2008, 03:34 PM | #23 |
Active Member
Re: i need help
Module has already been suggested.
We're running out of guesses and dmasta hasn't provided us with any more info. Dude, have you figured it out yet??? We're starting to repeat ourselves... |
09-03-2008, 03:37 PM | #24 |
high-Tech Red Neck
Re: i need help
Well then we should share in our collective boredom, and you should come check out the Texas chapter opening up and bring your input Kemosabe...
09-03-2008, 03:41 PM | #25 |
Built 4 Speed
Re: i need help
does it have gas in it?
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
