Old 09-18-2008, 02:32 PM   #1
Ackattack
Ackattack's Avatar
Howe dual piston calipers?
I originally was going to use a big brake kit on my project truck, but now I'm thinking of using a stock style disc brake setup so that I can still run a 15" drag tire/wheel combo on the front.
I remember reading about the Howe dual piston caliper that is supposed to be a replacement type part for our stock calipers, seen here:
http://store.summitracing.com/partde...4846904+400309
Is any one running these, and what is their opinion of them.
I'm going to be running drilled/slotted rotors (to match the back ones) along with Hawk HPS pads, so I'm thinking I really won't need a big brake kit with the upgraded calipers and pads.
Ackattack is offline   Reply With Quote
Old 09-18-2008, 03:07 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Howe dual piston calipers?
I'm curious to hear too. Looks like a nice alternitive to the stock single piston, plus according to Howe web site, they are only 5 lbs.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-18-2008, 08:01 PM   #3
67dragtruck
67dragtruck's Avatar
That looks nice. I'm very interested in this.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 09-18-2008, 09:09 PM   #4
71BB_LWB
Thread Killer!
71BB_LWB's Avatar
Make sure they are for our width rotors. The truck rotors are wider than the car rotors.
(I'm talking width not diameter)
Since it does not specify I would guess it's for a car.
Dan
71 Cheyenne SWB LS1 and auto.
http://67-72chevytrucks.com/vboard/s...d.php?t=256470
_____________________________________
If it's worth doing, it's worth doing twice...
Don't Mistake Honesty for Negativity...
71BB_LWB is offline   Reply With Quote
Old 09-18-2008, 10:44 PM   #5
chevy_mike
chevy_mike's Avatar
Actually looking at Howe's site, they make two different sized rotor thickness and three different piston sizes.
Based on the link to Summit, the one listing is for a 1.25" rotor thickness and has 2.25" pistons.
Old 09-21-2008, 03:54 PM   #6
Brad
Out of the carpool lane.
Brad's Avatar
Bump and interested also.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-21-2008, 03:58 PM   #7
Ackattack
Ackattack's Avatar
Well I ordered a set of them, so hopefully I'll know how they fit by next week. However, it will be awhile before I get to test drive them.
I decided to go this route over a big brake kit is I can run some 15" skinnys for drag racing.
Old 09-28-2008, 12:25 PM   #8
Brad
Brad's Avatar
Here's another thread I unearthed: http://67-72chevytrucks.com/vboard/s...d.php?t=248113
Old 09-28-2008, 06:47 PM   #9
chevy_mike
chevy_mike's Avatar
Any word yet? Very interested to hear how they work.
Old 09-28-2008, 08:59 PM   #10
Ackattack
Ackattack's Avatar
Re: How dual piston calipers?
I just got them on. Physically they fit. However, I have two little issues to over come.
First, the brake line coming into the back of it doesn't use a banjo fitting. It looks like it is some sort of NPT fitting. So I have to get an adapter that goes from NPT to AN (I'm using a set of stainless steel brake lines from ECE and when you take off the banjo fitting, it has a AN fitting on it). Shouldn't be a big problem.
The next problems is the holes in the calper where the caliper pins go though are largers, so the caliper can essentially rattle around. I'm going to have to find some sort of bushing to fix that....I'll let you all know what I come up with.
Here is a pic....trying to upload a video so some of you can see what I mean about the bushing.
Old 09-28-2008, 09:50 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
maybe it takes the same bushings as the original ones. basically each caliper has 2 small and 2 large fat Orings.
68C15 is offline   Reply With Quote
Old 09-28-2008, 09:56 PM   #12
Ackattack
Ackattack's Avatar
I also got new stock bushings and orings....no worky
Old 09-28-2008, 11:18 PM   #13
Bowtie468
Bowtie468's Avatar
That looks like an easy fix. I think i'll go the same route. Do you have access to a machine shop?
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 09-28-2008, 11:42 PM   #14
chevy_mike
chevy_mike's Avatar
Man, that makes me wonder what pins are suppose to be used. I was under the impression that most non metric GM calipers used the same mounting pins. I wonder if Howe has some different pins.
Looks good and report back after you get the little problems taken care of. Be interesting to see if they make an improvement.
Good work.
Old 09-29-2008, 12:18 AM   #15
Ackattack
Ackattack's Avatar
I did a little checking, and Howe does make some pins that have the bushings included in the pin. I'm going to call them tomorrow and see what is up.
I went back and compared this one to the stocker, and there isn't an internal groove for an o-ring like the stockers have.
Old 09-29-2008, 12:41 AM   #16
chevychase
chevychase's Avatar
Sweet find on the pistons! Where did you get the brake line adapter and let us know on the pins.
chevychase is offline   Reply With Quote
Old 09-29-2008, 02:27 PM   #17
38chevyhotrod
38chevyhotrod's Avatar
That looks to be a good replacement caliper for the stock ones, I am curious how they approve the brake power. Keep us updated.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 09-29-2008, 02:29 PM   #18
Ackattack
Ackattack's Avatar
So I called Howe, pretty much you have to use their caliper pins....summit sells them too; part number 337B.
The hole for the brake line is 1/8" NPT. So I don't think your stock rubber brake lines will work either.
Old 09-29-2008, 05:56 PM   #19
67dragtruck
That's awesome. I'm going to have to add a set of these to my parts list for Summit. I would think they would improve braking significantly. I hate the stock type rubber lines anyway. Great find, thanks for the info.
Tom
Old 09-29-2008, 07:52 PM   #20
Ackattack
Ackattack's Avatar
Tom
I can't take credit for finding them. I saw someone else mention them on here awhile ago. I might be the first person to actually try them.
Maybe after I get all the kinks worked out I can write up a FAQ install on the subject.
Old 10-01-2008, 06:35 AM   #21
chris71
chris71's Avatar
good idea, maybe with a list of all the parts and their part numbers. i too am excited to hear how much these will help with better braking
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 10-10-2008, 02:09 PM   #22
Ackattack
Ackattack's Avatar
I got the Howe caliper bolts. They have the spacer built into them, so I thought this would fix the rattling around. Well they're the same diameter as stock, so the calipers still rattle around.
So I called Howe again, and explained it to them. They said this is the way it's supposed to be. Keep in mind Howe is a circle track racing company, so in racing they don't care about the rattling around noise, but the movements is supposed to be there, and they will work normally.
BTW, there caliper bolts were cheaper than the ones I got from NAPA so I guess I'll keep them.
As for the rattling around, since there isn't a groove for an o-ring, I may put a different sized o-ring, or maybe a few wraps of tape, along with some grease to keep everything moving freely.
So it looks like it's a fairly straight forward swap. And with the better brake pads and better caliper, I'm sure this will perform nearly as well as other "big brake" kits yet allow you to run 15" wheels and keep your stock rotors (if you want....I went with drilled/slotted).
Old 10-10-2008, 02:52 PM   #23
whatnow123
whatnow123's Avatar
I think from the video that they are a little looser than what would be called acceptable. I'd get the Howe Rep on the phone, send them the link to the video and have them watch it.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 10-10-2008, 03:06 PM   #24
Brad
Brad's Avatar
I wouldn't roll like that. There's got to be a better solution. If the rep can't help, perhaps Grainger or Mcmaster-Carr?
Old 10-14-2008, 12:35 PM   #25
Ackattack
Ackattack's Avatar
I installed the calipers today. Basically I used some electric tape and wrapped the pins to take up a little space. I also greased the pins so they will still slide easily.
Oh, I'm not sure that these will fit with the stock wheels. I had one wheel on and it was hitting the brake caliper. When I spun it, it looked like maybe the wheel was bent, so I don't know. You may have to run a then spacer to get the stock wheels to fit. They fit fine behind a set of 20s though
I can't say how the brakes work right now since the truck is a ways from being on the road. I also won't be able to say how they compare to stock, since I've never driven this truck, and there are so many things modified (including 3/4 ton brake booster, camaro rear discs, stainless steel braded hoses, and Hawk HPS pads)
I'll work on an FAQ write up sometime when I get a chance with a list of the parts and what I've learned.
