Old 09-18-2008, 11:44 AM   #1
nrb's70gmc
nrb's70gmc's Avatar
Front end rebuild
Hello everyone i am a new member to the site, and had a quick question
aside from doing a frontend alignment is it possible to do a frontend rebuild at home "in the dirt driveway haha" with standerd hand tools? Do any of the bushings/bearings require to be pressed in/out? it is a 70gmc 2wd 3/4 ton thanks
nrb's70gmc is offline   Reply With Quote
Old 09-18-2008, 01:54 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Front end rebuild
It's possible to do a dirt driveway rebuild.You will probably need to have some bushings etc pressed in/out at a shop(there's a machine shop attached to the local Carquest).You do really need some concrete pad to properly support the truck on jackstands.The lower ball joints need to be pressed in/out but the uppers bolt back in.the uppers have rivets from the factory so you will need a way to cut them out or you could drill them.You will also need a "pickle fork" or ball joint seperator.If you look in the suspension forum you should find some info.There may also be a FAQ in that section.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-18-2008, 02:05 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
As PanelDeland stated, it can be done in the driveway. If you are planning on purchasing a kit, or running MOOG products, look no further than Early Classic Enterprises (ECE). If I recall correctly their kit is around $500 but includes everything you will need.
Good luck with the rebuild!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-18-2008, 02:14 PM   #4
cdowns
cdowns's Avatar
put pieces of 3/4"plywood under the jackstands if doin it in the dirt
Old 09-18-2008, 02:31 PM   #5
nrb's70gmc
nrb's70gmc's Avatar
Thanks, guys
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
Old 09-19-2008, 08:27 PM   #6
red69ss
Burnouts are therapeutic
red69ss's Avatar
I have done exactly what cdowns suggest when I was a gravel mechanic works great
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 09-19-2008, 09:30 PM   #7
nrb's70gmc
nrb's70gmc's Avatar
thanks for all the safty tips, and as always i do use plywood, aside from that-has anyone done a frontend rebuild? i was wondering how much time it might take, and what bushings/baerings require pressed in/out PANELDELAND might have answered this, but a little more advise wont hurt anyone. Thanks again
Old 09-19-2008, 10:56 PM   #8
mole2000
mole2000's Avatar
in the exact process you describe currently ('cept on asphalt). i had to wait on some parts and things can take longer to come apart than planned. i don't think any pieces had been replaced in 38 years... also doing disc conv at the same time. mine's not a daily driver so no worries about downtime. i had the lower balljoints done at a local shop along with lower shafts for about $90, both sides, labor only.
mole2000 is offline   Reply With Quote
