Old 11-07-2008, 06:23 PM   #1
SCIV
SCIV's Avatar
Lightbulb '68 C10 Short-Step 6.0 + TT swap
Well, I thought I would give this a shot here. I am going to do this the lazy way since I already had a thread going elsewhere. I hope it isn't bad to link outside of here???
Anyway, I started with a bone stock 86,xxx mile 1968 short step side. Originally with a 6 and 3 OTT.
I have (with the help of friends) swapped in a 2003 LQ4 6.0L with 4L80e trans. Currently working out the parts for a twin turbo setup (ordered a custom cam this week). Once that gets here, I will start building it back up.
Eventually it will get a disc conversion with a 2.5"/4" drop, 3.73 gears with locker, and a little boost
Here is a link to the thread, and I will start to update here too:
http://www.ls1truck.com/forums/lsx-t...-6-0-swap.html
I am open to advice, comments & suggestions!
Thanks,
SCIV
SCIV is offline   Reply With Quote
Old 11-08-2008, 12:05 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: '68 C10 Short-Step 6.0 + TT swap
Welcome from NM! Great looking project.
Hart_Rod is offline   Reply With Quote
Old 12-22-2008, 06:42 PM   #3
SCIV
SCIV's Avatar
Finally an update. After much debating, I decided to change out the old oil pump for a Texas Speed ported & polished LS6 unit as well as upgrade to an LS2 timing chain. I didn't have the patience to pull the motor, so I tried to do it in the truck. That ended up taking me 2 weekends since I cut the oil tube oring on the first try.
Anyway, got that done, and also changed out the valve springs for Comp 918's with TI retainers & hardened pushrods. Starting to look like a motor again. here are some pics of the progress:
New oil pump & timing chain:
New valley plate & knock sensors:
New springs & retainers:
All buttoned up (mostly!):
And new goodies from Santa!!:
Old 12-22-2008, 06:43 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-23-2008, 12:13 PM   #5
71cadc10
71cadc10's Avatar
looking good....what's your plan with the coil packs? relocating them?
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 12-23-2008, 12:52 PM   #6
SCIV
SCIV's Avatar
Absolutely. Where? I don't know yet, but probably to the back of the block above the trans.
Old 12-23-2008, 12:59 PM   #7
LuckyHenriksen
LuckyHenriksen's Avatar
Thats sick man, I cant wait to see it with twins! I have the same swap planned for my '68. What turbos are you thinking?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-23-2008, 01:11 PM   #8
SCIV
SCIV's Avatar
Leaning towards 62 or 67mm. Eventually I will build a forged 370 for it, and really turn up the heat!
Old 12-23-2008, 01:13 PM   #9
LuckyHenriksen
Sounds like a good plan
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-23-2008, 01:15 PM   #10
LuckyHenriksen
What kind of power are looking for on the stock long block? What heads are you running?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-23-2008, 01:29 PM   #11
SCIV
SCIV's Avatar
317's with Comp 918 springs & TI retainers.
I think 600 hp or so is a good starting point.
Old 12-23-2008, 01:42 PM   #12
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-24-2008, 05:58 PM   #13
texanidiot25
Eat My Rust
texanidiot25's Avatar
This truck is going to be a beast
texanidiot25 is offline   Reply With Quote
Old 12-24-2008, 09:47 PM   #14
SCIV
SCIV's Avatar
That is the plan!!
Well, long term anyway. I am just trying to get it going by February 15th, so I can make a GM Truck track day in San Antonio. It will probably be on just motor, and the twins will start after that.
'68 Chevrolet Short Step
6.0 L + 91mm + TH400 + 9" + 4-Link
Old 12-24-2008, 09:49 PM   #15
SCOTI
SCOTI's Avatar
Subscribed. Nice work (except for cleaning the motor ).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-30-2008, 11:20 AM   #16
SCIV
SCIV's Avatar
I thought I cleaned it a little!
Here are some fuel system updates:
I am not sure on the angle of the filter, I have a 90* fitting on the way to mock it up that way to see which I like better.
Old 12-30-2008, 12:32 PM   #17
Rokcrln
Rokcrln's Avatar
Looks good! I am toying with doing a small turbo set up on my 4dr Tahoe build with a 2005 5.3l. So why is your fuel pump set up so low?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-30-2008, 03:11 PM   #18
ripdog28
ripdog28's Avatar
Love the build. I got scared for you when i seen how that fuel pump was mounted. Just looks iffy. IMO lift it up flush with the bottom of the tank or mount low right to the frame. I would not have it dangling below the bumper and frame all out in the open. it may get caught on something or hit. with the pricks today it would be easy for someone to cut it off and take it. may be fine but just gave me the shivers when i seen it.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 12-30-2008, 05:08 PM   #19
LuckyHenriksen
I agree, it looks a little flimsy. Nice setup though!
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-30-2008, 06:33 PM   #20
SCIV
SCIV's Avatar
I was worried too until I mocked it up. Those are 1/4 plate, and it is stiff as a board.
The pump has to be below the outlet of the cell, and the cell is under the bed, so that is why it is so low. It is still 3" above the bottom of the differential case, so it isn't the lowest thing on the truck.
I would have to raise the cell to inside the bed to make the pump tuck under the bumper.
Rock* ME *Hardplace
Old 12-30-2008, 07:04 PM   #21
LuckyHenriksen
is that how it is for any fuel cell?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-30-2008, 10:51 PM   #22
ripdog28
ripdog28's Avatar
You should have an Electric fuel pump mounted at the level of the tank. Some want it lower then so the fuel will flow out of the tank into the pump eliminating the pump starving. It is not needed if you keep more then 1/4 tank and the pump is not above the tank just needs to be at fuel level.
69 c-10 BBC
Old 12-31-2008, 11:01 AM   #23
SCIV
SCIV's Avatar
Maybe I took the Aeromotive directions too seriously? I have it mounted below the outlet on the cell by about 1 1/2".
So ripdog, you think I can move it up a couple inches to be at the bottom of the cell level? I just don't want to starve the engine or burnup the pump!
EDIT:
Just got off the phone with Aeromotive, and they said I can move the pump up to be even with the bottom of the cell. That will gain me 3-4" at a minimum. Thanks for catching that guys.
Old 12-31-2008, 08:10 PM   #24
SCIV
SCIV's Avatar
I will work more on the fuel system tomorrow. Here is what I started tonight:
Old 12-31-2008, 08:21 PM   #25
texanidiot25
Eat My Rust
Nice looking guages, where did you grab these?
