#26 |
Re: New to the club
Update:
After installing the dash pad and redoing the center console in April 07, I have been troubleshooting an electrical problem since May 08. Finally got that fixed by replacing the fuse link at the battery, properly connecting the HEI, and reconnecting the gas guage wiring. Hopefully that solved the problem, I will know for sure next time I start it and it dosen't burn through any more wires. I have an int. reg. alt. that I am going to go ahead and convert just to be sure. That is it so far.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
#27 |
Re: New to the club
Went to check the wiring to the back for the fuel guage ground, and I have no brake lights. I was not able to find the ground in fuel guage wiring, but I did trace the brake light wiring. No fuse
#28 |
Tot Roddin'
Re: New to the club
We need some updated pics....
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#29 |
Re: New to the club
I am getting closer to solving the electrical problem. I converted the alt. to an internal regulated unit. Now my wiring does not get hot. Just the alt. I think it is ok for now. I installed the deluxe side markers and turn signals in the front bumber, put the license plate on and got it out and took her for drive yesterday. I put about 5 gal gas in the tank and washed all the dust from storage and got some new pictures.
Photos are the new alt, adding the deluxe side markers, and the before and after of the turn signal lamps in the front bumper.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer Last edited by 65-72 chevytoys; 09-26-2008 at 02:12 PM. Reason: added photos |
#30 |
Re: New to the club
New photos after taking it out on the road for the first time.
#31 |
Re: New to the club
a few more.
#32 |
2wd FTW!!!!
Re: New to the club
Looking good!!!!
#33 |
Old School, New Style
Re: New to the club
Well at least for you summer is NOT almost over. Take the top off and enjoy the sun.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
#34 |
go cyclones
Re: New to the club
It keeps looking better and better.
I'll second that comment, in a week we will have highs inthe sixties. |
#35 |
Future TOTM Winner
Re: New to the club
So what is the deal with your hardtop? Is the paint in pretty good shape? Did the PO smooth the texture before paint? I am digging the grey color. I like it cause if looks like it could have been something that G.M. did from the factory, but still it's different from everyone else. It's a nice touch.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#36 |
Re: New to the club
#37 |
Re: New to the club
I finally got all the wiring out from under the dash that did not come from the factory. I removed the two relays that were ignition circut and spliced everything back together. Now, the only thing that did not come from the factory is my new steering mount tachometer that I got for my birthday. I had this exact same one in my yellow pickup that my dad got me for Christmas a few years back and forgot to remove it when I sold the truck. So, I got the same one that he got for me for my blazer.
#38 |
sharp as a marble
![]() Join Date: Jan 2007
Re: New to the club
where do you live. I am in Atlantic beach?
#39 |
Re: New to the club
Down in North St. Johns Co. by I95 and CR210.
#40 |
Re: New to the club
Well now that I have pleanty of time on my hands I have been working on it again. I got the tach show above wired in and working. I thought I had the valve noise fixed but it keeps coming back more to come on that. Finally I had a full fuel gauge so I droped the tank today and found the wire was disconnected from the sending unit. The needle went from full to empty so I took it to the gas station and at $2.25 a gal put 16 gal in the aftermarket poly tank so it should be close to full, but the gauge is still on E. Back to the help boards on the valves and fuel gauge.
#41 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: New to the club
Is that one of the factory gray tops?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#42 |
Re: New to the club
No it has been sanded smooth and painted it is white under the grey paint.
#43 |
Re: New to the club
#44 |
Still livin the "dream" in '54
Re: New to the club
Love the color, can't tell you why, but I do!
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
#45 |
Re: New to the club
You should get a sway bar for those brackets, it'll make a night and day difference in that thing! It will turn and not lean while doing so! I have my 2wd and I guess if the 4X4 sells I'll hopefully be able to dedicate some time and $$$ to fixing up the 2wd and getting her on the road!
