Old 12-07-2008, 06:07 PM   #1
chevychase
chevychase's Avatar
Used $200 Air Suspension kit, is it worth it?
My cousins neighbor got this suspension in a car deal, they know NOTHING about it and couldn't see any names on any of the parts. Is it worth $200 in possible parts + an 1 1/2 drive. My 67 has been begging for an air ride system, but my budget doesn't allow one yet.
chevychase is offline   Reply With Quote
Old 12-07-2008, 06:17 PM   #2
edflores
Re: Used $200 Air Suspension kit, is it worth it?
what brand valves are those? the coil should have a name on them if they are asco's, it would be worth it. you could prolly sell those air cylinders on another web site.
edflores is offline   Reply With Quote
Old 12-07-2008, 06:18 PM   #3
Mrwlliam
Yes its worth the trip if the stuff works... I wouldnt use the air cylinders for your truck.. thats more for a import type car.
everything - those cylenders i still worth it..
Mrwlliam is offline   Reply With Quote
Old 12-07-2008, 06:38 PM   #4
chevychase
chevychase's Avatar
here are some of the names found on the parts from the guy:
joucomatic
irhaf
sirai
bussero
Old 12-07-2008, 06:45 PM   #5
edflores
sarai are ascos. very good and dependable
Old 12-07-2008, 09:24 PM   #6
joe231
joe231's Avatar
what are these?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-07-2008, 09:28 PM   #7
leftcoast66
leftcoast66's Avatar
The red compressors look like AIM, airbagit's. Wouldn't trust those at all personally. Asco's I'd trust, but the rest I'd be worried about. Not much besides valves could be used on your truck, the rest is all stuff you could sell, but even then, good luck selling AIM parts. I'd wait and buy all new quality stuff.
leftcoast66 is offline   Reply With Quote
Old 12-07-2008, 09:29 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Originally Posted by joe231 View Post
what are these?
Attachment 410192
senders for digital gauges
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-07-2008, 09:32 PM   #9
joe231
joe231's Avatar
ah, thanks
CHEVY ONLY
Old 12-07-2008, 11:40 PM   #10
72hotrodder
THE TOY STORE
72hotrodder's Avatar
those cylinders are not made to handle the weight of a truck. plus they ride like ****. so i'd say no all that stuff is pretty out dated
72hotrodder is offline   Reply With Quote
Old 12-08-2008, 01:09 AM   #11
dubdeuce80
dubdeuce80's Avatar
the shAIM controller should've given it away...
dubdeuce80 is offline   Reply With Quote
Old 12-08-2008, 02:33 AM   #12
pissonNOS
senior member
pissonNOS's Avatar
yep and those definately look like the aim compressors too
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-08-2008, 03:50 AM   #13
chevychase
chevychase's Avatar
Thanks for all the replies. I wound up picking up the system dirt cheap. I know most of the stuff isn't quality, but I'm happy with the Ascos valves and fittings. The rest I'll try to liquidate.
Old 12-08-2008, 02:06 PM   #14
edflores
air the things to the left of the air tanks, more air tanks?
im assuming they are, and with those, cylinders ride well because the air has somewhere to move. but cylinders only belong on imports.
side note on the tanks- they should have a dot number on them. is not, they arent safe to use.
Old 12-08-2008, 02:22 PM   #15
Shane
Shane's Avatar
accumulator tanks is my guess .. cylinders don't have the "give" a rubber-bladder style bag has, so when the cylinder is suddenly compressed (bumps / dips in the road) the air has somewhere to to go instead of trying to feed back into the fully pressurized tank.
Shane is offline   Reply With Quote
Old 12-08-2008, 02:33 PM   #16
edflores
can you tell how many gallons they hold? i need some for my air hoppers but i can fit anything thing too big. under my hood
Old 12-08-2008, 11:42 PM   #17
chevychase
chevychase's Avatar
I don't know how many gallons, my guess which could be way off is maybe like a gallon each. They're pretty small, about 17"x5", looks kinda like a small fire extinguisher.
Old 12-09-2008, 02:13 AM   #18
draggin86
draggin86's Avatar
go take all that garbage to the dump its all AIM stuff!
draggin86 is offline   Reply With Quote
Old 12-12-2008, 04:30 AM   #19
ENHANCED AIR RIDE
Yes those are accumulators for the cylinders. It all appears to be AIM excepot the valves. We use Asco exclusively(except for the Accuair)and have had no problems in 3 years.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 12-12-2008, 10:05 AM   #20
joe231
joe231's Avatar
if your dimensions are correct, those are a tad under 1.5 gallons each.
gets you the area of a circle, then multiply by the length of the cylinder and divide by 231 (cubic inches in a gallon). the answer is not exact due to the curved ends of the tank.
CHEVY ONLY
