Old 12-15-2008, 11:39 PM   #1
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Sub Box Build
Okay, so a while back, the el-cheapo pioneer 8 inch sub and 40 watt amp were stolen out of my truck. I've decided to build the system that I always wanted in my truck. It's nothing over the top, just a single sub and two amps, one for the 4 speakers and 1 for the sub.
(My truck is actually a 1990 Silverado, but it's the same body style as the 73-87s.)
As anyone with a pickup truck knows, there isn't a whole lot of room behind the seat. With only a couple inches to play with, I was going to have to go with a shallow mount sub. (I chose a Kicker 12" CVT shallow mount.)
I ran painters tape all across the back wall and started laying fiberglass. This is messy as hell.
After getting a good few layers of a back and a floor of the speaker box, I cut out the internal walls of the speaker box and mounted the speaker ring. You can start to see how the speaker box will be split up. I'll have the subwoofer in the middle, the amps on one side and a small storage/glove box on the other to hold miscellaneous items such as jumper cables, tools, etc.
Stretching an old t-shirt over the sub ring for the first layer of resin. I did this for each of the three areas (sub, amp, and storage sides)
Here's the finished product after several layers of fiberglass and some bondo.
You can see how/where the amps will be mounted from behind in this picture.
After hours of sanding and more body filler and sanding and more body filler, and sanding some more, it was ready for paint.
Well, I decided not to paint it and drop it off at the local LineX dealer. $60 to coat the whole thing and it will be much more durable than any paint I could use. Here's the end result.
Here's what it looks like with the sub, amps, and storage door on it. This is just the test fitting. Everything needs to be wired and I need to find some hinges and a lock for the storage compartment door.
I can't wait to get it all wired up and hear it thump, but it's cold as hell outside, so I'll be holding off for a while.
ARAMP1 is offline   Reply With Quote
Old 12-15-2008, 11:43 PM   #2
bigblazerboy
bigblazerboy's Avatar
Re: Sub Box Build
that turned out pretty badass. i like the use of diamond plate looks sick.
bigblazerboy is offline   Reply With Quote
Old 12-15-2008, 11:43 PM   #3
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: Sub Box Build
Awesome box. Great job. But, a 90 silverado is nothing like a 73-87 body wise anyways. Two completely different bodystyles. Sorry
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 12-15-2008, 11:50 PM   #4
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
Thanks guys! It's my first fiberglass attempt and it turned out a lot better than exptected. My next project will probably be an overhead console to house CB radio among other things.
Sorry, didn't specify. It's a 4 door.
Old 12-15-2008, 11:53 PM   #5
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
I've kind of got a diamond plate theme going on in the interior.
Old 12-15-2008, 11:54 PM   #6
joe231
joe231's Avatar
Re: Sub Box Build
that is fricken' amazing!
love the way it turned out!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-15-2008, 11:57 PM   #7
vern350
like a rock
vern350's Avatar
Re: Sub Box Build
awsome job. I love the truck too....
vern350 is offline   Reply With Quote
Old 12-15-2008, 11:58 PM   #8
Dinos63
chevy only
Dinos63's Avatar
Re: Sub Box Build
that is a killer box nice work
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-16-2008, 12:06 AM   #9
lyrikz
PITbut
lyrikz's Avatar
Re: Sub Box Build
You pulled that RIGHT outta my head. Except the diamond plating. Looks exactly how i wanted mine to look. How thick is that fiberglass in the rear? Is that going to affect sound quality at all??
lyrikz is offline   Reply With Quote
Old 12-16-2008, 12:22 AM   #10
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
HAHA! Whats wrong with the diamond plate?
I think there's probably about 12 or 13 layers of fiberglass on the front and the back and I threw a few extra bits around the corners of the sub area. It's around 3/8" thick. Here's a pic of the part of the rear I cut out for mounting the amps. As far as sound quality, who knows.
Old 12-16-2008, 12:24 AM   #11
lyrikz
PITbut
lyrikz's Avatar
Re: Sub Box Build
No, you got me wrong, the diamond plate is friggin AWESOME and i wouldnt of that of that... ahaha... Your final creation trumped my vision. ahaha
Old 12-16-2008, 12:30 AM   #12
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
HAHAHA! Thanks!
Old 12-16-2008, 06:28 AM   #13
Ds86C10
2WD 4 Life
Ds86C10's Avatar
Re: Sub Box Build
Thats your first attempt at fiberglass???? looks damn good to me man!
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 12-16-2008, 09:33 AM   #14
454HO
Re: Sub Box Build
Nice work! How are you planning to trim out the cab corners? And how are you going to mount it to the rear wall of the cab, or is it just going to sit there? I would be worried about the cab sheet metal vibrating agaist the back of the sub box when that sub hits it's resonate frequency. Maybe a layer of Dynamat would prevent that. Looks like you may have used some in the pic showing the passenger side corner.
Also, I see the 6x9's in the rear doors. What are the other 2 speakers you have? The dash mounted 3.5's?
- Greg
454HO is offline   Reply With Quote
Old 12-16-2008, 09:49 AM   #15
vtwinsport
vtwinsport's Avatar
Re: Sub Box Build
That is very cool. Fantastic do it yourself solution if I ever saw one.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 12-16-2008, 09:57 AM   #16
LMDGUY
LMDGUY's Avatar
Re: Sub Box Build
very nice job.
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 12-16-2008, 10:03 AM   #17
Cherub
Cherub's Avatar
Re: Sub Box Build
that looks real good
Cherub is offline   Reply With Quote
Old 12-16-2008, 11:13 AM   #18
Tony_SS
Tony_SS's Avatar
Re: Sub Box Build
Looks great - thanks for sharing. Love the diamond plate too.
Tony_SS is offline   Reply With Quote
Old 12-16-2008, 12:55 PM   #19
badblu97
Double 6's
badblu97's Avatar
Re: Sub Box Build
Looks GREAT!! I have two of these 10s in my new body and LOVE them! The only thing I saw was is there enough airspace for the sub? (kinda late now I guess) But over all it is a beautiful setup! and with the Line-X you can take the box, throw it around, put it back in the truck and thump away!
badblu97 is offline   Reply With Quote
Old 12-16-2008, 02:03 PM   #20
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Sub Box Build
Looks good man!! Like a pro...
tvblazer78 is offline   Reply With Quote
Old 12-16-2008, 02:11 PM   #21
Hazieview
Building Dreams out of Dimes!
Re: Sub Box Build
I only have one question is that enough air space for that speaker? If so maybe I'll get me a shallow mount. Just curious.... Nice job though! Props!
Hazieview is offline   Reply With Quote
Old 12-16-2008, 03:44 PM   #22
AceX
>130dB Moderator
AceX's Avatar
Re: Sub Box Build
That looks really good. I'd have used brushed aluminum instead of diamond plate, but other than that, mine would look exactly like that. You'll want to Dynamat that back wall too.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 12-16-2008, 04:55 PM   #23
Prerunner1982
Prerunner1982's Avatar
Re: Sub Box Build
ARAMP1 glad to see you are still around. That looks awesome..
You wouldnt happen to have a long bed frame sittin around or know of one do ya?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-16-2008, 07:49 PM   #24
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
Good points. There is actually a couple layers of dynamat on the back wall/floor. The plan now is to fiberglass up some component speaker boxes for each corner and have them LineXed to match. I had to break it down into parts since one full box would not fit behind in the corners. (corner speakers will go in first and then the sub box will go in last) The el-cheapo speakers in the rear doors will be replaced by diamond plate aluminum like in the front. The sealed box volume for the speaker is 1.0-4.6 ft.^3 which there is around/just a little more than 1 ft^3.
Old 12-16-2008, 07:51 PM   #25
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: Sub Box Build
Hey, what's going on neighbor!?! Looking for a standard cab, 2wd longbed? I'll keep my eye out.
