Old 12-22-2008, 03:14 PM   #1
Tony_SS
Tony_SS's Avatar
Question Guys with 15x10 Wheels - Inside Please
What backspace are you running? And what tire sizes? Pics are welcome too. Thanks!
Tony_SS is offline   Reply With Quote
Old 12-22-2008, 04:19 PM   #2
vern350
like a rock
vern350's Avatar
Re: Guys with 15x10 Wheels - Inside Please
4.5 inch backspacing with 295/50/15. I don't have these on now because of the lack of drop and the little tires make things looks out of place.
vern350 is offline   Reply With Quote
Old 12-22-2008, 07:00 PM   #3
Tony_SS
Tony_SS's Avatar
Thanks Vern - looks great to me even as-is. Anyone else?
Old 12-22-2008, 07:27 PM   #4
tractor1963
I have 15x10 with 275/60/15,4.5 BS
tractor1963 is offline   Reply With Quote
Old 12-22-2008, 07:47 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Here's a pic of my 74 before stripping it down to the frame.
15X10 4.5 spacing with 295/50's with just a drop shackle kit.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-22-2008, 08:56 PM   #6
westie 666
westie 666's Avatar
Here is mine 15x10 4.5 back space with 29x15x12.5 tyres
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 12-23-2008, 12:22 AM   #7
Nolowrider
Nolowrider's Avatar
Rear 15x10 4 inch BS, P275/60
Front 15x8 4 inch BS P245/60
But these are coming off soon.
[IMG][/IMG]
Nolowrider is offline   Reply With Quote
Old 12-23-2008, 12:53 AM   #8
f.monroe
f.monroe's Avatar
Its not a 15 inch wheel , but it is 10 inches wide with a 275/60/17 tire and a 4.5" backspace. It will give you an idea of where the wheel will ride in relation to the fenders .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-23-2008, 06:21 AM   #9
AceX
>130dB Moderator
AceX's Avatar
I'm sure alot of people are tired of seeing mine, but I'll add to the roster.
15x10 all around. Backspacing unknown. Tires are 255/60/15 in front and 275/60/15 out back. Suspension has a 2/4 drop. Thr fronts rub slightly.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 12-23-2008, 11:52 AM   #10
blazer2007
Frank
would the tires rub if lowered
blazer2007 is offline   Reply With Quote
Old 12-23-2008, 12:04 PM   #11
DomesticDisturbance
DomesticDisturbance's Avatar
so frim what im reading here, a 4.5 backspace would be the way to go with the 15x10 wheel.
76 Chevy shortbed C-10, 350 w/turbo 350 trans(under construction)
cardomain page: http://www.cardomain.com/id/DmestcDisturbnce
DomesticDisturbance is offline   Reply With Quote
Old 12-23-2008, 12:52 PM   #12
Richard D
Richard D's Avatar
Unless you lower it a lot, or have a really wide tire. I have custom 6.5 backspace 15x10, with 29x15.5 Mickey Thompsons, they fit perfect and never rub.
Richard D is offline   Reply With Quote
Old 12-23-2008, 01:03 PM   #13
BruthaMan
US Army Veteran
BruthaMan's Avatar
I'm sure not tired of seeing it! That's one beautiful truck! Perfect stance.
I do have a couple of questions:
1) Is the 2/4 all you've done? No drop springs? I ask, because this is exactly how I'd like to do mine. What brand of spindles are you using?
2) Not knowing the backspace, let's assume for a moment it's 4.5 for the purpose of my question. If it were 4.5 and wheels with a 5.25 backspace were swapped out, would that "tuck" the wheels into the fender more, or push them out past the fender?
BruthaMan is offline   Reply With Quote
Old 12-23-2008, 01:26 PM   #14
DomesticDisturbance
im probably only looking at running a 275 on the back of mine until i go bigger and better, so it shouldnt be a problem correct? and im not dropping a whole lot right off hand
oh and sorry for the thread jack
Old 12-23-2008, 01:49 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Frank
I agree with this setup. I have Billet Specialties rims and I have a set of 17" rims with the rears being 17" X 9.5" with a 4.5 backspace. Plenty of clearance on the spring.
Old 12-23-2008, 02:03 PM   #16
Tony_SS
Tony_SS's Avatar
Have any pics of that setup?
Old 12-23-2008, 02:18 PM   #17
Richard D
Richard D's Avatar
I need to get some good overall shots of the truck, but here are some to show the fit.
Still need to put wider wheel tubs in the bed after butchering it in the dark.
Old 12-23-2008, 09:35 PM   #18
AceX
>130dB Moderator
AceX's Avatar
Drop is a Belltech kit. Spindles, shackles and hangers.
Larger backspacing will push the wheels out.
Living Life @ 130dB
RIP El Jay
Old 12-23-2008, 10:43 PM   #19
f.monroe
f.monroe's Avatar
To answer the couple o questions about my wheel setup , it might rub if I lowered it a couple more inches . My 18x10's I had on the tan truck were 5.25 inches of backspace and fit real nice . The tires are 275/60/18 Nitto's . This truck was only lowered 2.5/4 . The 15x10 with a 275/60/15 will fit the same but is just shorter overall because of the wheel diameter. I ran 15x10 Convo Pros with the same size tire years ago and they had a 5" backspace . Centerline listed it as a 4 7/8" backspace and it was perfect on a 15 inch wheel .
Frank
Old 12-24-2008, 08:48 AM   #20
Tony_SS
Tony_SS's Avatar
Actually 'less' backspacing pushes the wheel out. A 15x10 with only 3.5" of bs will push the wheel out farther than one with 5" of bs.
Old 12-24-2008, 09:37 AM   #21
bigblock73
yeller
bigblock73's Avatar
You beat me to it, I was going to say the same thing.
bigblock73 is offline   Reply With Quote
Old 12-24-2008, 10:52 AM   #22
moneyeater
moneyeater's Avatar
I have 10x 15 589 eagle alloys all around with 295/50 and 265/50 Bfgs but i canīt tell you the backspacing,sorry! The papers say ET -45 mm but i canīt tell what that means!
Name:  IMGP0617 [640x480].JPG
Name:  IMGP0618 [640x480].JPG
Name:  Shopscenes3 [640x480].JPG
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
ī81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 01-08-2009, 11:53 AM   #23
JW76
JW76's Avatar
moneyeater, what size drop do you have? That looks great
JW76 is offline   Reply With Quote
Old 01-08-2009, 12:57 PM   #24
abebummy26
abebummy26's Avatar
fail*
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 01-08-2009, 01:14 PM   #25
JW76
JW76's Avatar
Thanks for the reply
