Old 12-31-2008, 05:41 PM   #1
boobiemac
Disc brake conversion?
Just bought my first 69 GMC C1500 but it is totally stock! I would like to know the easiest way to convert the front brakes to power disc brakes? And I would like to add power steering, can i use the parts from a newer chev? Some help would be greatly appreciated! Thanks
boobiemac is offline   Reply With Quote
Old 12-31-2008, 05:53 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Disc brake conversion?
theres a couple different ways. With my sons truck, we bought a parts truck and used the '72 front xmember for disk brakes and used the rearend , ps box as well. we also used the booster/MC from the parts truck. you can use 73-87 parts as well. do a search on the board for these conversions and you will have alot of reading on your hands.
welcome to the board!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-31-2008, 05:56 PM   #3
Imacarguytoo
Welcome to the board. Yes you can use parts from a newer truck. You can use everything from a 73 to i think 91 chevy truck. Do a search there is a crapload of info on this. I am in the middle of doing this same swap on my truck. I am using everything from a 85. The search button is your friend.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 12-31-2008, 06:59 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Welcome to the BB.Not to be rude but I couldn't tell you all the ways to do this.Search the FAQ's list.It has so much info no one can remember it all.There are a bunch of ways to do these mods.Member "Krue" has indexed the FAQ's and it should be easy to find in there.
BTW You can search members and find his info there with a link IIRC.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-01-2009, 05:00 PM   #5
boobiemac
Thanks for all the good advice! I have a line on a parts truck it is a 92 GMC ext. cab, will these parts work or should I look for 87 or older?
Old 01-01-2009, 05:45 PM   #6
powerbench
powerbench's Avatar
Are you planning to do a drop suspension as well? Might just be easier to go get a set of disc drop spindles and start that way ,imho. I just did this to my 70 gmc.
powerbench is offline   Reply With Quote
Old 01-01-2009, 06:47 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by boobiemac View Post
....I have a line on a parts truck it is a 92 GMC ext. cab, will these parts work or should I look for 87 or older?
Your better off with 73-87 truck (73-91 Burb) parts or a 72 donor. If the motor is out of both, it's an easy swap to bolt the entire crossmember in.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-01-2009, 09:26 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you're gonna do it, do it right. If the control arm bushings and shafts are worn, you'll want to replace them while they're easy to access. Ditto for the upper/lower ball joints. If you decide to go with drop spindles, I can recommend Early Classic Enterprises. There are others, too. Some board members are vendors and sell the components you will need, whether it's aftermarket or OEM replacement-style.
Oh, and a big welcome from the Heart of Arkansas!
Member Nr. 2770
