01-04-2009, 10:41 PM | #1 |
Time to fix up Dad's old truck
Have an 1983 High Sierra, 305, 4 speed with low (SM465?), body is perfect (needs paint, but no rust/dents), probably about 60K miles on it.
Dad is getting older and about 18 months ago he threw a rock through the back windshield with the mower and the truck has been sitting since. I put a battery on it last weekend and it cranked, so it still runs, but it needs some work. Dad always used it as a work/ farm truck, but I'd like to get it really fixed up. Problems to address Starter is "clicking". The truck starts, but there was a clicking coming from starter area as if a low battery. I put a new Optima on there with full charge, so I'm going to clean/ reconnect the wires on the starter and see if that helps, and if not, I'll get a new starter for it. Gas gauge reads full when ign is off, and when you turn key on it jumps to 3 oclock. From what I found here that means bad ground to sending unit or bad sending unit. That sound right? AC does not hold charge. There is a streak of oil on the underside of the hood right over the compressor, so would this mean a compressor leak? I've retrofitted my Jeep CJ from R12 to R134, but I've got to find the leak here before I can do that to the truck. I've done some work here too on that and looks like I'll need to replace dryer/ oriface tube and adjust some other part (name escapes me at the moment). Looks like it has an R4 comprssor from the pics on autozones website. If the compressor is leaking, I figure I'd be better off just getting a new one unless these things are easy to fix. Speedo quit working several years ago, and the mechanic took the little box off (it had seized up) and screwed the cable straight into the tranny. It reads about 10mph slow. Anyone know a parts house where I can get another box? I don't have the original and I'm sure it has a speedo gear similar to my CJ's so that might be a chore. Speedo also squeaks. Not sure if it's the cable or the gauge. Guess I'll unhook the cable and see if the squeaking stops and that will tell me which it is. If it's the speedo is there a way to lubricate it? Doors sag. Can I just get new hinge pins and bushings for this? Dash is cracked badly. Do the glue on dash covers look decent? I don't want to spend $300 on a new pad, but I don't want to spend $125 on something that won't look good either. Not looking for a show truck, but want it to look nice. I want to fix the above things and get the outside painted/ trim reattached. Dad lives 5 hours from me so it will be a little bit at a time, but I'm trying to get my info straight so I know where to go when I get back to the truck. Last edited by old Rusty C10; 01-05-2009 at 12:51 AM. |
01-05-2009, 12:24 AM | #2 |
I don't think these pills work
Re: Time to fix up Dad's old truck
lots of questions the clicking could be bad connections bad cables or a bad solenoid.gas gauge you nailed it could be bad sender or bad ground. on the a/c go to the parts store and get some dye for the system it will make the leak green and easier to find, if its the compressor its easier to replace and only run about $100 new.on the speedo the cable sqeaks when its dry get some graphite and squirt it in the cable and the sqeaking will go away.on the doors as long as hinges are in good shape the pins and bushings should take care of it.and the glue on pad i have one and it looks good but not perfect but my trucks not a show truck either, and i got mine for $10 so i cant hardly gripe. hopefully this helps some and welcome to the board its a great place for info. and lets see some pics of this thing!
SQUARE84 90 SUBURBAN |
01-05-2009, 12:45 AM | #3 |
Thanks for the reply.
The AC would hold a charge for several months, but we quit charging it a few years ago because we figured out it wouldn't last. From what I've read I should change the O rings in the AC system when retrofitting. My Jeep's system didn't have Orings (flanged fittings) so I didn't have to do the Orings on that job. Are the Orings just where the hoses connect or are there others I should look for? Would it be safe to assume that the compressor is at least one place that would be leaking since there is oil all over the underside of the hood right about the compressor? This won't ever be a show truck by any means, so I'll probably go with a coverlay on the dash. |
01-05-2009, 12:53 AM | #4 |
Robert Olson Transport
welcome to the board! sounds like you have alot of the same issues we all have with these trucks.. lots of knowledge here so you should get the answers.. we would love to see pics of your truck too if you could.. again welcome
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-05-2009, 12:59 AM | #5 |
I'll get some pics next time I'm down there. It's got about 2 inches of tree sap on it at the moment. Dad's got a 95 Sierra that he inherited from my grandfather and he's been driving the 95. I don't want to watch the 83 just sit there and rot so I'm going to get it going again and fix it up.
I'll get some pics posted and let ya'll know how it progresses. |
01-05-2009, 01:42 AM | #6 |
i have an 82 chevy c10 that i seldom get to work on but i hear ya these trucks can run rings around the newer ones.. mine has half a million miles on it and still runs great
01-05-2009, 02:08 AM | #7 | |
In the Forgotten far North.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-05-2009, 10:23 AM | #8 |
Yeah, about 1990 (ish) the speedo broke, and i took it out to the GMC dealership and the guy had that off and said a new one would be $100+, but that he could put the cable straight to the transmission and it would work, but wouldn't be 100% correct, so that's what we did at the time.
I'd like to get it right, but don't have the original. If it's anything like my Jeeps, you kinda need the original one to get the right part # or you just have to guess. I don't want to guess if it's still a pricey part (which I'm sure it is). I found this site http://www.transmissioncenter.net/sp...n_______va.htm "#54RA2. If your truck tires have been switched to larger tires or you just need to speed up your speedometer this one will correct your problem. This part will speed up your speedometer reading. Cost $62.00 Qty 123 Speed Up Rate Select the Correct %Speed Up 11%Speed Up 20%Speed Up 28%Speed Up 38%Speed Up 44%Speed Up 78% Other ratios available on special order, allow 2 to 4 weeks. No refunds on special orders. The male side can be turned 180 degrees, just remove the 4 screws and turn. We can slow your speedometer down as much as 58% or speed it up as much as 200%. Cost $72.00" Kinda thought if I can figure out how much the speedo is off I can have them make me one. Anyone used one of these from that website and if so, did it work ok? |
01-05-2009, 02:58 PM | #9 |
2WD 4 Life
i took the same hunk of junk off my truck... i dont know why they put them on but i just got the correct speedo gear for my tire size and rear end gears. a guy at my local tranny shop helped me figure it out for free
Big D 1969 c10 1960 cadillac 1978 king cobra |
02-21-2009, 12:38 AM | #10 |
Well, made a little progress on the truck when I went to visit this week. Got new (well, slightly used) tires mounted, got the thing around to the front of the house, and the water pump started seeping. Starter was still making a clicky noise when starting but it did turn the engine over. Next time I'm down that way I'll take some pics.
Took it out to a shop and had a water pump put on it. Thing didn't run worth a darn on the way to the shop, but after sitting since 06 I kinda expected that. I didn't have time to get into anything further, but supposedly Dad was going to pick it up today and said he'd take it out and get the new rear glass installed early next week. Just an idea, but when Dad went by the local GM dealership and asked about getting a new rear windshield, they had a couple of plain ones out back left from people changing to sliding back glass. They GAVE him a piece of glass for the rear windshield, so if ya'll need rear glass, you might try the dealerships in your area first. |
02-21-2009, 01:05 AM | #11 |
think your starter could be going like the gear is sticking for a sec then doing its job but before you go that far change all the battery cables and starter wires make sure all the grounds are good and clean if it still does it chnge the starter start small before you go to the big stuff. wires tend to go bad where you can't see it could be a bad spot some where in the wire neve know
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside If it ain't a Chevy it's foreign http://hotridesmag.com/ |
02-21-2009, 01:06 AM | #12 |
mind my spelling kinda tired lol
02-21-2009, 10:36 AM | #13 |
Battery is a new Optima red top, cables look good on that end, but could be corroded on the starter end, or could just be bad wires. My Jeeps have made me proficient at replacing starters, so I'll probably get new wires first (because they're cheap, and it won't hurt to replace them) and if that doesn't work, replace the starter.
When I get can get pics and get them posted I'll be back on here asking about cosmetic stuff, but right now I just want to get it running again. All of this is going to go very slowly cause Dad lives 5 hours from me so I only get to work on it when I go down there to visit. I'm thinking about getting it running well and bringing it home with me. Wife would love that since she already has a problem with my old Jeeps and Jeep parts everywhere....... Last edited by Jeepwm69; 02-21-2009 at 10:36 AM. |
02-21-2009, 11:58 AM | #14 |
Happy to be here
Starter is "clicking". -It could be a bad solenoid, but check your grounds. Look at the bottom side of the cables. I have seen them look like new on top, but be split and corroded on bottom.
There is a streak of oil on the underside of hood-This is probably not the source of your freon leak. This is common, and GM says they should seep a bit of oil for lubrication. I find that to be pure BS, but GM says it true. Speedo also squeaks.Probably the cable. Lube it with graphite. Doors sag.This could be worn hinges, but probably just bushing and pins. Dash is cracked badly. Your going to get what you pay for here. If you can live with "ok" fit then the covers look "ok". If you really want GM looks, your going to have to pay the price. Check with Capt kaos and see what he can do for you.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-21-2009 at 03:09 PM. |
02-21-2009, 02:28 PM | #15 | ||||
Yeah, I've been through all that with the Jeeps before. Started replacing parts and it ended up being a cable that was partially separated inside the insulation so it was bad, and it looked ok. Batt cables are cheap so I'll just replace them. Quote:
I have R134 guages and have retrofitted one of my CJ7's to R134 with no problems, but it didn't have a leak. Once I find the leak on this truck I plan to vacuum it down and put R134 in it. I've seen the writeups on this site about what needs to be changed, and while it seems to be a bit more complicated than the Jeep, I think it's something I can handle. That I can handle. Quote:
Thanks again for all of the input thus far. Last edited by Jeepwm69; 02-21-2009 at 02:30 PM. |
03-24-2009, 08:58 PM | #16 |
Finally got some pics.
New water pump installed, rear glass put in, new plugs, and it runs like a champ. Starter is still acting funny. Probably just going to replace it. Obviously needs a cleaning in a BAD way, but only have 3 spots on the whole truck with any rust, and the only one of those that concerns me is the sill on the drivers side.... Odometer is showing 35XXX miles, but the speedo was broken for a year or two, and now the cable goes straight into the tranny (no adapter) so it reads about 20% slow give or take. Actual milage is probably around 50K if I had to guess. Dad bought this thing new in August of 1983 for around $9K Now the pics. |
03-24-2009, 09:01 PM | #17 |
Couple more pics
03-24-2009, 11:35 PM | #18 |
Garage wrench
wow, if it were in a barn I'd call it a barn find. It needs to be cleaned up and it'll be good.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
03-25-2009, 08:36 AM | #19 | |
The boxes were added after my sister decided to clean up her shed and threw out a bunch of stuff. Guess she figured the truck was there and convenient, so she just threw everything in the back of the pickup. I'll get it cleaned up next time I'm home. He did say he drove it to the post office today, so at least he's driving it. Last edited by Jeepwm69; 03-25-2009 at 08:37 AM. |
03-25-2009, 10:47 AM | #20 |
1962 C-10
Nice start. That's not a bad looking truck there.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
04-19-2009, 11:36 PM | #21 |
Went for a visit this weekend. Vacuumed it out (still need to scrub the seat and dash, but got the leaves and dead bugs out of the interior), took it to the car wash and power washed it. Almost all of the sap blew right off the sides, so it actually looks pretty good now (the hood and top of the cab have some sap that the power washer wouldn't touch; guess I'm gonna have to really scrub those areas). Found the factory GMC hubcaps and put those back on too. Changed the oil (and noticed that Dad must have had an entire new exhaust from manifold to tip put on the truck right before he parked it). Truck runs great, and looks pretty decent now, although I plan to really clean it up a little bit at a time.
NOW, couple of questions. The doors rattle like heck and won't shut all the way. Originally I thought it would be hinge pins like we had on our 95 GMC, but the doors on this truck don't seem to have any play in the hinges, and after looking at them they don't really seem to be sagging. I'm thinking maybe replace the door weather stripping and then move the door striker pin. Does that sound like the "usual" way of addressing door rattles? I need to replace the starter. Are the two bolts coming out of the bottom of the starter the mounting bolts? On my Jeep 258's the starter bolts are verticle to the ground (and the solenoid is on the inner fender, not attached to the starter). Does the starter kinda slip into place and then two mounting bolts go straight up into the motor? Last, when the truck is first started, it will idle for a second and then seems like it's loading up and will die unless I tap the gas a bit. After 30 seconds or so it idles fine. I'm familiar with motorcraft 2100's (swapped onto my Jeeps) but don't know squat about the carb on this truck. What model is it and anyone have a page with troubleshooting information on this particular carb? Thanks for the repsonses so far. I'm going back down in mid May and will post some more pics. Last edited by Jeepwm69; 04-19-2009 at 11:37 PM. |
04-19-2009, 11:47 PM | #22 |
that truck can be very nice
04-20-2009, 12:34 PM | #23 |
Yes, those are the starter bolts. Take those out and slide the starter forward about two inches, then drop it down. Its very simple. Your carb is a Quadrajet. The choke probably needs adjustment. A carb rebuild probably is not a bad idea because of the age and the time it spent sitting. If you are going to rebuild the carb, you will need the carb number to get the right carb kit.
I can still count my vehicles on two... wait three hands. |
04-20-2009, 04:41 PM | #24 | |
As for the starter, my usual strategy on easy-to-replace starters is to go to Autozone and get a cheapie with the lifetime warranty and just swap them out whenever they start acting up. I can pop a starter on and off of a Jeep in about 10 min now in the parking lot. With the solenoid right next to the exhaust manifold I imagine heat kills these things pretty quickly. Is there a better alternative as far a starters go or do ya'll all pretty much do the cheapie/ frequent swap on this engine? Also, I notice that there are a lot of "shims may be required" tags on these starters. Do they come with the starters, or do you buy them, or what? I'm guessing I should pop the starter on there now and if it doesn't sound right, shim it. Is there a particular way of knowing/measuring to determine whether or not I need shims? Thanks again for the pointers! Last edited by Jeepwm69; 04-20-2009 at 04:44 PM. |
04-22-2009, 12:16 PM | #25 |
The Qjet isn't bad to rebuild. It will probably take you two hours the first time. I did the carter on my '63 Riv and would rather do a Qjet. If you have a hot air choke, They are a pain to ge right, but with time it will come. You have tou adjust the choke cold, so it may take a few tries.
Starters are about $50 and come with a pack of shims. If the starter grinds or does not disengage you may need to remove or add. Most of the time you don't need them. Heat soak really isn't an issue if you have stock manifolds. There are issues with headers, although my Blazer has never had a problem with hooker headers. I think it depends on the style and brand. That is only my opinion though.
