01-08-2009, 11:13 AM | #1 |
Tools and their uses
Might have been seen here before but I thought I'd share...
"tools and their uses" > DRILL PRESS: A tall upright machine useful for suddenly snatching > flat metal bar stock out of your hands so that it smacks you in the > chest and flings your beer across the room, denting the freshly- > painted project which you had carefully set in the corner where > nothing could get to it. > > WIRE WHEEL: Cleans paint off bolts and then throws them somewhere > under the workbench with the speed of light. Also removes > fingerprints and hard-earned calluses from fingers in about the time > it takes you to say, 'Oh sh -- ' > > ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their > holes until you die of old age. > > SKILL SAW: A portable cutting tool used to make studs too short. > > PLIERS: Used to round off bolt heads Sometimes used in the creation > of blood-blisters. > > BELT SANDER: An electric sanding tool commonly used to convert minor > touch-up jobs into major refinishing jobs. > > HACKSAW: One of a family of cutting tools built on the Ouija board > principle. It transforms human energy into a crooked, unpredictable > motion, and the more you attempt to influence its course, the more > dismal your future becomes. > > VISE-GRIPS: Generally used after pliers to completely round off bolt > heads. If nothing else is available, they can also be used to > transfer intense welding heat to the palm of your hand. > > OXYACETYLENE TORCH: Used almost entirely for lighting various > flammable objects in your shop on fire. Also handy for igniting the > grease inside the wheel hub out of which you want to remove a > bearing race. > > TABLE SAW: A large stationary power tool commonly used to launch > wood projectiles for testing wall integrity. > > HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground > after you have installed your new brake shoes, trapping the jack > handle firmly under the bumper. > > BAND SAW: A large stationary power saw primarily used by most shops > to cut good aluminum sheet into smaller pieces that more easily fit > into the trash can after you cut on the inside of the line instead > of the outside edge. > > TWO-TON ENGINE HOIST: A tool for testing the maximum tensile > strength of everything you forgot to disconnect. > > PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under > lids or for opening old-style paper-and-tin oil cans and splashing > oil on your shirt; but can also be used, as the name implies, to > strip out Phillips screw heads. > > STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used > to convert common slotted screws into non-removable screws and > butchering your palms. > > PRY BAR: A tool used to crumple the metal surrounding that clip or > bracket you needed to remove in order to replace a 50 cent part. > > HOSE CUTTER: A tool used to make hoses too short. > > HAMMER: Originally employed as a weapon of war, the hammer nowadays > is used as a kind of divining rod to locate the most expensive parts > adjacent the object we are trying to hit. > > UTILITY KNIFE: Used to open and slice through the contents of > cardboard cartons delivered to your front door; works particularly > well on contents such as seats, vinyl records, liquids in plastic > bottles, collector magazines, refund checks, and rubber or plastic > parts. Especially useful for slicing work clothes, but only while in > use. > > DAMM-IT TOOL: Any handy tool that you grab and throw across the > garage while yelling 'DAMM-IT' at the top of your lungs. It is also, > most often, the next tool that you will need. I use the damn-it tool most often.....Have a good day guys. -Bikerbomber
If all men are created Equal* does that mean we are all artifical?
01-08-2009, 11:55 AM | #2 |
its all about the +6 inches
Re: Tools and their uses
That list never gets old!
The one that is missing on the vicegrips... They can be used to stop the bleeding! Last edited by Longhorn Man; 01-08-2009 at 11:56 AM. |
01-08-2009, 04:05 PM | #3 |
RIP BigDaddyDave ~7-23-09~ You will be missed~
Its good to know that all of my tools are working properly.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
01-08-2009, 04:11 PM | #4 |
I love the DAMM-IT TOOL..lol
