01-15-2009, 05:35 PM | #1 |
How to tighten up bags for cornering?
Alright, so I've come to the conclusion that I need valves for each bag. I have valves for the front and rear, and the truck really leans when I corner because of the transfer of air between bags. So, how much will the bags resist leaning if I get valves for each? I also need a sway bar in the front, which I assume will help this problem out. I like to run low, and this causes the bags to be pretty low on pressure. What have you guys done to tighten it up? I'm not looking for corvette-like cornering, just no more leaning!
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
01-15-2009, 08:37 PM | #2 |
67-72 parts collector,…
Re: How to tighten up bags for cornering?
Just add 1 fill and 1 dump on each bag. Then install a sway bar. That should make a world of difference!
01-15-2009, 08:39 PM | #3 |
Happy to be here
First thing is get a sway bar. Get an 1 1/8" off of a 3/4 ton truck or an aftermarket unit. It WILL make a difference. Next, is get at least two more valves to isolate your front. It would be best to isolate all corners but you def want to stop air transfer up front.
I have never done it, but I have been told that trimming, or removing your cups (assuming you have front cups) will allow you to go lower. Consequently it will take more air to ride low so your bags should have more pressure and not be so squishy.
01-15-2009, 10:42 PM | #4 |
Thanks guys! I figured that is what I would have to do. As a info note, I get more looks with the truck bagged than I do with my Corvette! That is no joke...there are so many guys that come up and tell me that it reminds them of a '67-72 that they have/had. Here is a pic of it a few weeks ago here in Utah.
01-15-2009, 10:47 PM | #5 |
That's a good looking truck!
01-15-2009, 11:35 PM | #6 |
Front sway bar is a must no matter what springs or bags you use.That is one nice looking truck.
01-16-2009, 01:51 AM | #7 |
I've heard put the valves as close to the bag as possible, or directly ontop if possible, because it will keep the air from going back into the line under hard cornering rather than staying in the bag.
01-16-2009, 11:47 AM | #8 |
Epoxy Primer Friendly
Or you can install check valves at each bag to help with the weight/air transfer.
01-16-2009, 12:04 PM | #9 |
accepting donations
You have a sweet ride. Can't wait till I can bag mine.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
01-16-2009, 12:34 PM | #10 |
8 valves, 1.25" bar up front, Helwig style or late Camaro rear bar and you be grinnin from ear to ear. Cut cups and good shocks wouldn't hurt either. That's the setup I ran for some time on my 69 Burb. It held the road pretty well considering it was a 2 ton rig with a 127" wheelbase.
01-16-2009, 08:17 PM | #11 |
Thanks for the compliments on the truck! I've decided to get eight valves and definitely a sway bar. I have a lot of hp going through the truck and it would be nice to stay in the throttle around some corners instead of slamming the breaks and feeling like I'm in a '72 Cadillac.
Do you guys know if the supertrack bar from ECE is all I need back there? I've got that now, so I'm not sure if there is somehing else to go back. |
01-17-2009, 03:48 AM | #12 |
About how much power you go i would think about bigger brakes if its a lot.
01-17-2009, 04:00 AM | #13 | |
Search this forum for "Camaro Rear" or "Rear Sway" |
01-17-2009, 12:35 PM | #14 | |
If you can find it cheaper, I can fix it! |
01-17-2009, 02:03 PM | #15 |
A guy with a truck
Do you have a link? I can't seem to find them.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-17-2009 at 02:04 PM. Reason: spelling |
01-18-2009, 12:03 AM | #16 |
No. Bilstein's site doesn't have much on it. I've been playing with them for a while and I like them. I could probably answer some questions based on experience. RCD Suspensions has Bilstein build them specifically for them.
01-18-2009, 12:21 AM | #17 | |
Happy to be here
01-18-2009, 12:45 AM | #18 | |
01-18-2009, 12:25 PM | #19 |
Happy to be here
Cool. Post up the details when you can.
01-18-2009, 01:02 PM | #20 |
I sent Steve an email, he said he created a page on their site recently for the air ride shocks. He sent me this link, so this should be all the info you need.
http://www.racecardynamics.com/class...ag/airride.htm
01-18-2009, 01:37 PM | #21 |
Nice link. I did Bilsteins on my 68. The rears required using 88-98 rear shocks w/some driveway made bracketry. One of those p/n's would have been much easier.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-18-2009 at 01:39 PM. |
01-18-2009, 08:00 PM | #22 | |
01-18-2009, 08:10 PM | #23 |
Call me or any of the other authorized distributors.
01-20-2009, 11:17 AM | #24 | |
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
01-20-2009, 12:28 PM | #25 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
