Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-16-2009, 03:13 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Rocker replacement
Does the front fender have to come off when replacing a rocker panel?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-16-2009, 03:44 PM   #2
raggedjim
raggedjim's Avatar
Re: Rocker replacement
I have always removed the fender to do this. I don't see anyway you could do it without removing the fender... I don't even think you can remove the old rocker without removing the fender...
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 01-16-2009, 04:39 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Well, that's more work then I want to deal with right now. The rocker is basically solid. The lip that holds the door seal is rotted off in a few spots for about 6"-8" at the bottom though. I think I can just clean it up and weld in a piece of metal for the seal to hang on to.
If I disconnect the ground wire on the battery will I be O.K. to weld on the truck? Never welded before, but this will be my start.
Beat it to fit,
Old 01-16-2009, 04:45 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
How does this welder look? http://www.homedepot.com/webapp/wcs/...ctId=100039229
I figure I can upgrade it to mig later.
Beat it to fit,
Old 01-16-2009, 04:51 PM   #5
Wilson_
Wilson_'s Avatar
I have this one and I love it.
http://www.homedepot.com/webapp/wcs/...3+90401+527842
you could also find used ones for pretty good prices on craigslist
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 01-16-2009, 04:57 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
That's nice, but kind of out of my price range at the moment, plus I don't have 220 wired up here.
Beat it to fit,
Old 01-16-2009, 06:02 PM   #7
raggedjim
raggedjim's Avatar
That welders better than mine, I have a Clarke EN130 with the gas package and it works well for me.
As far as your rocker, you can cut and weld in what you like, but it still takes effort. With the grinding you will have to do to make it look nice, I wouldn't be surprised if it ends up being more work than replacing the whole rocker...
But, if it's just the lip, you might try to pop rivet in a strip of metal to replace the missing lip, the seal will probably cover it and it will get you by until you have time to fix it right.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 01-16-2009, 06:20 PM   #8
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
I did mine without removing the fenders. But, I did drill out nine billionty spots welds to do so.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 01-16-2009, 10:16 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
The rocker is basically solid, it's just the lip that holds the seal is ate up in a few spots. Anything I have to weld in would be covered by the seal and the sill plate. I think I'm going to go for it.
Beat it to fit,
Old 01-16-2009, 10:42 PM   #10
tim21391
tim21391's Avatar
i left my fender on when we cut out my old rocker but i had no spot welds left i only had the welds on the front and back... had to take front clip off to fix pillars tho
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-17-2009, 10:10 AM   #11
Larry S
Larry S's Avatar
Im sure that is a pretty good unit because its made by lincoln, but Id either get the mig gauge kit with it or get another model. The flux core wire doesnt make a quality weld. It leaves ALOT of splatter. I have the lincoln 3200hd. I got it at home depot, and it runs off 110. I think they call it a different model # now. It does a great job for small stuff. Good luck!
Larry S is offline   Reply With Quote
Old 01-17-2009, 10:18 AM   #12
Sinister
Between Trucks...
Sinister's Avatar
I'm looking at a 3200 HD on E-bay right now, will probally go for it.
Beat it to fit,
Old 01-17-2009, 10:37 AM   #13
Senator350
Senator350's Avatar
1. practice on some scrap sheet metal first. (most of my local metal suppliers sells scrap steel by the pound, which is cool to try out different thicknesses and joints)
2. to weld sheet metal, you have to do LOTS of little tacks... not really run a bead. you have to do a billion tack welds and don't weld where it's still warm. (2.1 the sheet metal gets butted, not lapped)
3. you want a MIG. you don't want to weld flux core. it's a pain in the ballsack.
4. you want .30 or .35 wire ALWAYS. don't get anything smaller... it's easier to just tune your wire speed
5. check the reviews on the regulator that comes with the welder... it's a really important part, and sometimes the manu gives you a shyte one.
Either way... don't try to weld on your truck until you are at least decent at welding.
RN U OVR
Senator350 is offline   Reply With Quote
Old 01-17-2009, 12:31 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
Whoohoo, just pulled the trigger on the 3200 HD. Can't wait til it gets here.
Beat it to fit,
Old 01-17-2009, 04:17 PM   #15
Larry S
Larry S's Avatar
Good for you.
Old 01-17-2009, 04:21 PM   #16
msgross
msgross's Avatar
This one has free shipping and usually comes with a free cart... you'll want a cart...
http://www.northerntool.com/webapp/w...Btool%2Bhobart
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-17-2009, 05:21 PM   #17
LONGHAIR
I have always used .023 wire. It takes less power/heat to melt it, therefore less has to be absorbed by the metal parts that you are welding.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-17-2009, 05:34 PM   #18
Sinister
Between Trucks...
Sinister's Avatar
What gauge is the sheet metal in these trucks?
Beat it to fit,
Old 01-17-2009, 08:39 PM   #19
msgross
msgross's Avatar
I think most stuff is about 18 GA...
The Garage:
Old 01-17-2009, 10:23 PM   #20
AusTx68
AusTx68's Avatar
When looking for a welder remember to check Craigslist. I found a Hobart Handler 210 for $500 and it was new in the box. I started using it yesterday for the first time. I created tack welds and beads on a thick piece of scrap metal. Then I tried it on sheet metal. That was tricky. I had to keep playing with the settings to keep from blowing holes in the metal. Once I was able to create tack welds on 18g sheet metal I attempted to tack butt welds. I had some trouble with burn thru and turned down the settings until I could get a good tack. I'm still not sure I have the right settings so I plan to keep playing with scrap sheet metal until I can get it right.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-19-2009, 10:35 AM   #21
raggedjim
raggedjim's Avatar
I agree, the .023 works great for me.
Roger
'70 GMC Jimmy 2wd
Old 02-12-2009, 01:05 PM   #22
truckintexas
Is this flux core .023, or are you welding with gas??
truckintexas is offline   Reply With Quote
Old 02-12-2009, 01:25 PM   #23
Sinister
Between Trucks...
Sinister's Avatar
I'm pretty sure flux core doesn't come in .023
Beat it to fit,
Old 02-12-2009, 01:43 PM   #24
Shane
Shane's Avatar
.023 user here too ....
Shane is offline   Reply With Quote
Old 02-12-2009, 06:35 PM   #25
AusTx68
AusTx68's Avatar
Same here. I finally visited a Hobart forum and found the right setting. I'm welding up a storm now
