Old 01-16-2009, 04:31 PM   #1
rage777
rage777's Avatar
steering column choices
i have a 72 c10 longbed with what i think, if i remember what the PO told me, an '87? cougar tilt column in it. the tilt is all wonky. i would like to replace the column but i'm not sure what years from what trucks will work with it. or am i better off just trying to fix the one that's on there?
1972 Chevy C10 Long Bed
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
rage777 is offline   Reply With Quote
Old 01-16-2009, 04:54 PM   #2
bigvinnie
bigvinnie's Avatar
Re: steering column choices
you're best off going with an original 67-72 unit, or one from a chevy van up to around 1980?? will also work with minimal modification. There are more expensive aftermarket units also...
hopefully, someone will chime in with more specifics on the van columns, but the tilt versions are commonly used in these trucks.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 01-16-2009, 05:05 PM   #3
rage777
rage777's Avatar
yeah i've seen those used. wanted to make sure it's not too much of a pain to install. as far as fabricating goes. difficult to find the 72's but easily found the van column.
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
Old 01-16-2009, 08:20 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
Wow, a cougar tilt column?
Gotta get some pics for that one.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-16-2009, 08:49 PM   #5
airdale94
airdale94's Avatar
Yes I agree!
airdale94 is offline   Reply With Quote
