03-04-2003, 10:08 PM | #16 |
sorry about being so slow to respond i was out for a week. Yeah i had to redrill. Just becareful to make sure you can get to the spot you put it for the hole. Everything lined up amazingly well on this one. i had to grind a little on the corner of an old thread mount to get my huge flat washers to clear. If i had it to do again i think i might drill the holes and weld on nuts on 2x2in plates onto the frame. That would have required removing the cab at the time but i had to do that anyways for some rust trearment, cab corners, cab mounts, etc. I picked up the set of seats for a mere 200 bucks. One was bent we tore it down to the frame and broke it and reset it.... kind of like a broken limb.
GL if any one would like i can help you look for a set here out of san antonio. these are out of a 99 ext cab trick door. I think they have more hieght under thm than most. On the driver side theres a big amp and under the middle seat i can fit my bio book and my physics book.... thats about 5 and a half inches gas pedals are for ppl with soft feet. heh... actually id rather have a pedal it might feel like im pushin more and i might not push so hard. lol Last edited by Jackal2k9; 03-04-2003 at 10:15 PM. |
