Old 01-22-2009, 08:43 PM   #1
mikeupnorth
Driveshaft 1 pc or 2 pc?
I am working on my 67 SWB 2WD Pickup. I do not have the orig. driveshaft. It has a spot to bolt on a carrier bearing. Did all SWB 2WD Pickups have 2pc driveshafts? Since I am droping the rear 4"-6" it looks like I could remove the bracket that holds the carrier bearing and use a 1 pc driveshaft. Does this make sense or have I lost my mind?
mikeupnorth is offline   Reply With Quote
Old 01-22-2009, 08:46 PM   #2
Security guy
Security guy's Avatar
Re: Driveshaft 1 pc or 2 pc?
Use a one piece. I've got a short bed with a 700r4 and I used the original (i think) one piece that was behind the 3 speed. Less parts to wear out.
Security guy is offline   Reply With Quote
Old 01-22-2009, 09:00 PM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
one piece on my sons swb ' 67 as well.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-22-2009, 09:25 PM   #4
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I have replaced two carrier bearings inside of a year and a half. Go with the one piece drive shaft. You will be glad you did! Some will tell you that a two piece is just fine, but in my opinion, the carrier bearing will always be the weak link in the drive line.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 01-22-2009, 09:32 PM   #5
see ten
WTB this ad
see ten's Avatar
SWB 6cyl manual trucks used a one piece shaft. SWB V8 auto trucks used a two piece shaft. I swapped my two piece over to a one piece when I installed my ECE extreme drop trailing arm crossmember.
Nothing wrong with a two piece shaft if you can keep the bearing in it.
see ten is offline   Reply With Quote
Old 01-22-2009, 10:38 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a quality bearing will last 40+ years. The problem is, most of the ones on the market are not of quality. Not high quality anyways.
Old 01-22-2009, 10:52 PM   #7
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Hmmm,
My SWB 6cyl,manual came with a 2 piece.....now I need to find some shims to adjust the pinion angle after putting in new springs after I put in a 1 piece.
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-23-2009, 10:46 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
A long while ago I drove a '72 GMC with a 2 piece drive shaft for 15 years and only had to replace the carrier bearing once.
On my short bed we had to use a two piece drive shaft because of the compound 4 speed. We used the two piece out of a 3/4 ton and it looks to be pretty strong. We did have to shorten the back shaft some, though.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-23-2009, 12:34 PM   #9
70short
Talking Re: Driveshaft 1 pc or 2 pc?
I removed the carrier bearing and housing, replaced it with a one piece driveline!!!!!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-23-2009, 12:37 PM   #10
MellowYellow70
One piece shaft for like 12 years now, and I'm dropped almost 6" in the rear.
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB Gasser 364"LS and all the goodies
2001 Vette Road/Street
1990 IROCZ Vert
MellowYellow70 is offline   Reply With Quote
Old 01-23-2009, 01:17 PM   #11
Indyuke
I went with a new two piece because it was original to my truck. The carrier bearing I replaced 20,000 miles ago looked to be original, and the one that's in there now is as solid as the day I put it in. You have to be careful about how you put them in though.
Indyuke is offline   Reply With Quote
Old 01-23-2009, 01:20 PM   #12
Kayotic
Kayotic's Avatar
If you are do any suspension mods. I would say one piece because of the drivetrain alignment becomes criticle factor. Off even slightly can couse problems and coupled with todays quality parts - well, part failure is bound to happen.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-23-2009, 04:18 PM   #13
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Shortbed - 1 piece.
Longbed - 2 piece.
Just my opinion.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-23-2009, 05:05 PM   #14
Longhorn Man
a 2 piece can be benificial, esp on a truck that is slammed with a c notch or on bags... lwb or swb.
Old 01-23-2009, 05:09 PM   #15
see ten
WTB this ad
see ten's Avatar
Yep, Nathan Porter has been suggesting the use of a two piece driveshaft with his backhalf dropmember setups. It cuts down on the tunneling of the bottom of the cab for driveshaft clearance.
Old 01-23-2009, 06:00 PM   #16
Longhorn Man
yep, and it divides the drive line angle in 1/2 too (if done right).
Old 01-24-2009, 08:24 AM   #17
stope4
I have a two piece. I just replaced the original center carrier bearing about a year ago. You gotta ask the question: why did GM opt for a two peice to begin with? You think maybe they knew something?
stope4 is offline   Reply With Quote
Old 01-24-2009, 11:56 AM   #18
QKENUF4U
QKENUF4U's Avatar
had a one piece in my tubbed out and lowered 71 and IMHO its a better choice.... only thing they did was cut a bigger hole in the cross member where the shaft went thru.....
QKENUF4U is offline   Reply With Quote
Old 01-24-2009, 02:07 PM   #19
lofly'a
lofly'a's Avatar
this one will take all the abuse you can throw at a street driven ride.
Name:  swing bearing.jpg
can be purchased from Inland Empire Driveline.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 01-24-2009, 02:37 PM   #20
thelonerife
thelonerife's Avatar
how much is it?
thelonerife is offline   Reply With Quote
Old 01-24-2009, 02:42 PM   #21
69gumby
69gumby's Avatar
When replacing my carrier bearing last week I found bearings made in China for around $20.00 and bearings made in the USA for $59.00. I paid for the made in the USA version. You get what you pay for.
69 sweet long fleet, David
69gumby is offline   Reply With Quote
Old 01-24-2009, 03:32 PM   #22
Longhorn Man
Whats wrong with a 2 piece? It's not a flawed design, it's actually stronger becouse of the 2 piece.
They've been in use for may many years, and in way more aplications than you'd ever think.
Old 01-24-2009, 04:31 PM   #23
BP68
BP68's Avatar
I have a 68 swb 350/700r4 and I used a one piece lwb shaft cut down to fit with a 700r4 yolk. Also remove the carrier bearing mount and have a ECE 4/6 drop. Fits very nice and less parts to replace regardless.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 01-25-2009, 08:11 AM   #24
lofly'a
lofly'a's Avatar
price is 131.99 @summit racing.
Old 01-25-2009, 08:46 AM   #25
Andy4639
Old member
Andy4639's Avatar
lofly'a
If this is the price for the center carrier bearing then I just made my decision. I want be needing that for my truck. This last one has done fine since about 1990.
That's as much as the drive shaft work.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
