02-07-2009, 01:19 AM | #1 |
step cont arms or drop spindles....
Ok lets open this up for discussion. Budget minded as we all are.... what is the better option? Welding in a step on the factory control arms or drop spindles? Truck is getting a 3' z or a raised and noctched x member. 22's. It will be bagged. Pros and cons of each...... ok go.
Nate I hope to get your expt opinion on this as well. |
02-07-2009, 01:50 AM | #2 |
Texas Big Wig
Re: step cont arms or drop spindles....
Well drop spindles wont mess with your geometry at all, just lower the stance
raising the BJs will move your upper control arm up & start affecting the geometry some, not that that is a major problem, but it can be if you start moving it enough So I vote drop spindles |
02-07-2009, 02:23 AM | #3 |
As Spray Bomb mentioned, one of the drawbacks to stepping the control arms is the effect it has on the suspension geometry.
I vote drop spindles too. I think you should be able to find some for a good deal these days.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-07-2009, 02:28 AM | #4 |
Stepping your control arms doesn't actually affect the suspension geometry. Your geometry still see's all the pivots on the frame and spindle the same as they where before. I'm being technical though.
What it does do, is increase your camber gain, because you are moving your control arms up. While you still retain the same ride you had before, you are pushing the suspension farther up in it's travel. That said, Spindles are always my first choice. Always. Especially if you want to lay on big wheels.
If you can find it cheaper, I can fix it! |
02-07-2009, 08:21 PM | #5 |
Happy to be here
Spindles, for those that can't TIG. Which would be me..
02-07-2009, 09:52 PM | #6 |
<-- me too ... at least not like Twisted ... dude's an artist.
02-07-2009, 10:05 PM | #7 |
Nice. Thanks for all the input. Always good to pick ones mind before you start cutting into your truck.
02-07-2009, 11:16 PM | #8 | |
Señor Member
1) most people I've seen step control arms only do the bottoms. In this case, you're actually misaligning the pivot angles of the upper and lower arms. Definitely a geometry issue. 2) for those who step both the top and the bottom, while the 2 arms aren't misaligned with one another, they are on a different arc path than stock. Also a geometry issue. Will it work? Sure.
02-08-2009, 12:27 AM | #9 | |
At least we both agree on the solution!
02-08-2009, 02:06 AM | #10 |
The way I see it, moving the pivot up on the control arm, is similar to just cutting the coil. The angle of the arm, in relation to the pivots (bushings and ball joints) still see the same imaginary line. The only difference when stepping the control arm is that part of the arm doesn't move, but your suspension will still see the same pivots, only in a different position. The same as cutting your coils, only with a different ride quality.
I will draw a diagram to explain this if I need to.
02-08-2009, 02:23 AM | #11 | |
02-08-2009, 02:29 AM | #12 |
Okay I get what you are saying now. I agree it does effect your suspension. What XXL was saying about creating a geometry issue is more what caught my attention. But I believe that could be the same misreading again. But yes, as you said, the further the suspension is compressed, the further it is pushing it's intended design limits. So anything you can do to reduce that is good.
02-08-2009, 02:30 AM | #13 |
I think I am using the word geometry too critically, and also not thinking about the change in control arm angle effectively changing your front IC.
02-08-2009, 10:14 AM | #14 |
See this is what I wanted. To hear the experts explain it. I am no expert in susp. That being said I have owned a bagged truck and have dropped many of my own vehicles.
Now I know the answer to this next one before I ask it. The answer is to get a Dropmember. But here we go. 3 inch z'ed or raise the xmember? I have seen many done but still am looking for opinions on what is the best and most effective solution. I like the raised xmember into the frame b/c you can then center wheel. What do you think? |
02-08-2009, 11:55 AM | #15 |
It's Better With Nitro
One of the more important issues to consider when you step the control arm to move up the ball joint location is that unless you compensate for or modify the steering arm, you do, in fact, change the geometry and introduce the potential for severe bump steer. With the ball joint at a higher location and the steering arm unchanged and at the higher location, the angle of the tie-rods increase, changing the angle or geometry.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 02-08-2009 at 11:55 AM. |
02-08-2009, 12:05 PM | #16 | |
So it's possible it can alter that relationship; making something less than ideal to begin with even worse.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-08-2009 at 12:05 PM. |
02-08-2009, 01:13 PM | #17 | |
02-08-2009, 02:16 PM | #18 | |
A guy with a truck
Downside: lots of work, raised engine leading to a ton of problems, blah, blah, blah... That's what I would do, hell, that's what I did. Twice.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-09-2009, 10:19 AM | #19 | |
It's very different than cutting coils - when you cut a coil, the tie end rod still travels in the same original plane in relation to the lower control arm. However, once you change the angle plane of the steering arm in relation to the angle plane of the lower control arm, you start to introduce the potential for severe bump steer. If the steering knuckle or arm on the spindle moves up by a ball joint spacer or stepped lower control arm without an equal spacer for the tie rod attachment, the angle of the tie rod changes in relation to the lower control arm angle. That's why a dropped spindle generally has a kick in steering arm (to keep the tie rod in the same location as the stock spindle) - that's to help maintain the original steering geometry. I'm just providing my 20+ years of experience in building hot rods and race cars. You are welcome to do what you want, I'm just trying to prevent you from having an ill handling vehicle, which are no fun and can be dangerous.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 02-09-2009 at 10:21 AM. |
02-09-2009, 10:25 AM | #20 |
Happy to be here
And we appreciate your input.
02-09-2009, 10:53 AM | #21 |
Actually, I thought the spindle 'spud' being raised in relation to the steering arm is what makes drop spindles desireable vs. raising the BJ locations (stepping the a-arm). The steering remains as the OE intended.
02-09-2009, 11:44 AM | #22 |
The steering arm is generally cast at about the same vertical location as the spindle pin as a structural component to the casting in addressing the shear load required to rotate the spindle/tire/wheel assembly under steering conditions. In a dropped spindle the spindle pin is located higher, so the arm is attached higher in the casting and then drops down - for example, 2.5 inches in a 2.5-inch dropped spindle. Take a look at a stock spindle casting next to a dropped spindle casting...you'll see what I'm talking about.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
02-09-2009, 12:54 PM | #23 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I had a 62 Olds with stepped arms and it handled great! But if they would have made a dropped spindle for the car....i would have bought them!!
02-09-2009, 01:12 PM | #24 | |
02-09-2009, 06:53 PM | #25 |
See all that I am learning. Thats is why I like good questions. For my application is seems that the $300 spend would be better to get the spindles. After all from what I hear I will have my own issues with steering and other stuff with the Z.
