Old member
Steve, the switch should have two nuts on it. Take one nut off and leave the other on, underneath the dash just above the brake assembly there is a bracket with a hole in it. Slide the switch with the threads up through the bracket and put the nut back on it and adjust it so that when you hit the brake pedal it lets off of the switch and you have brake lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
