03-17-2009, 07:47 PM | #1 |
OPEN HEADERS... Friend or Foe?
Will open headers cause problems with your engine? I know the obvious is being noticed by the cops, but I have heard everything from loss of HP&TRQ to bending valves and blowing your engine up.
Does anyone have any advise for me? |
03-17-2009, 07:49 PM | #2 |
Re: OPEN HEADERS... Friend or Foe?
not that ive ever seen other than LOUDER THAN FUDGE INSIDE and ATTRACTS PO PO !!!
03-17-2009, 08:13 PM | #3 |
its all about the +6 inches
you may drop a couple horses, esp if you can't tune for the increase in exhaust.
The whole burning exhaust valves thing is bunk. I've never heard of breaking valves or blowing the engine. It isn't the best idea in the world (for the street) but it isn't gonna mess up the motor |
03-17-2009, 09:04 PM | #4 |
03-17-2009, 09:17 PM | #5 |
20' Daredevil (Ret)
One of my more memorable drives was in 1968 when a friend helped me install a set of Hooker headers on my '65 Corvette (327/365, yeah I wish I had that one back) near Fresno, CA. We finished the job on a Sunday morning and couldn't find anyone to weld up the collectors, and I had to be at work Monday morning in Barstow, about a 240 mile trip.
You guessed it, open headers all the way -- they dumped right in front of the footwells so you can imagine the sound inside the car. It actually wasn't too bad at a steady cruise, but got loud if you let off the gas.... and LOUD under acceleration. The engine wasn't hurt (only about a 3.5 hour drive) and most of my hearing returned, but I was only 19 and it took a while to get the grin off my face.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-17-2009, 09:20 PM | #6 |
Active Member
As long as your ears can stand it you will be fine running open headers - drag cars have been doing it forever
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
03-17-2009, 09:55 PM | #7 |
will it drop lowend torque?
03-17-2009, 10:00 PM | #8 |
probably... again, esp if you don't tune for it.
In high school I had an 81 chevy citation with the iron duke 2.5 4 cylinder, all it had on it for exhaust was a bare manifold. Drove it likle that for 6 to 9 months, mostly in the winter... not a single issue. Drove it to Cincinatti (240 mile round trip) every weekend for about 4 of those months. Again, never had an issue. |
03-17-2009, 10:02 PM | #9 |
Sierra Grande Club
I think long tube headers alone will drop low end torque, open or not.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-17-2009, 10:21 PM | #10 |
Eat My Rust
What sort of tuning is needed LHM?
03-17-2009, 10:45 PM | #11 |
usually unplugging the exhaust will make it lean out, so adding a little more fuel... sometimes just turning a screw, other times a jet chainge.
03-17-2009, 11:12 PM | #12 |
Without backpressure, yes you will loose your bottom end torque. Your whole power curve moves up the rpm scale. Most likely you will have some major flat spots, and they usually show up right at your cruzing speed
If you live in an area with a lot of hills or mountain roads, you will notice a major drop in your drivable torque. If you live in an area with flat straight roads, you will love it. One added plus, with open headers. You will get to meet people in high places, such as your local judges and police/sheriffs. Open headers aren't allowed in most racing organizations anymore (NHRA pro classes is one exception). So most tuners now tune the carbs, ignition, ect.. to a motor with mufflers. I think the local tracks (out here in LaLa Land anyways), are trying to keep dbs down to 95 or 92, measured from 10'. Not sure if they test every single vehicle, maybe just the way too loud ones. Stocker, I can relate to your story. I didn't drive your distance, but after getting my '70 Z28 running, I had to drive it to a muffler shop to weld up the collectors. As it was raining, it was hard to keep the rpms down, when the rear tires would loose traction. When I came to a stop sign, a '60s Vette was going the opposite direction, when he herd my poor attempt at leaving the stop sign without wheelspin, he just smiled and gave me a thumbs up.
'72 GMC custom camper 350/350 |
03-17-2009, 11:26 PM | #13 |
20' Daredevil (Ret)
In general, everything about an engine , including the intake and the exhaust systems, needs to work together as a unit -- in other words, all parts need to be properly 'tuned' to get the best results.
Restriction, or back pressure, does not create more torque. If it did, we'd all be running tiny exhaust pipes on our stump-pulling monsters. And a more free-flowing exhaust won't rob torque, but as has been said, it may move it up in the rpm range. At the risk of oversimplification, large-diameter short header tubes are typically used on high-rpm high-HP engines (think top fuel) -- while streetable engines needing more bottom and mid-range torque will benefit more from smaller-diameter, longer (but equal-length) headers. Assuming the entire engine package is designed to work together as a unit....
03-18-2009, 12:12 AM | #14 |
Eat My Rust
Next time I have to replace collector gaskets, I'll let ya'll know how the power feels
03-18-2009, 12:21 AM | #15 |
This helps alot guys. And it does get the cops looking. got pulled over for it tonight. told him it must have fallen of down the road. he cracked a smile and told me to "take my smart ass home and put the exhaust back on"....
03-18-2009, 12:24 AM | #16 |
Stocker, your explanation was much clearer than mine texanidiot25, I would not try to run open headers too often unless you live out in the sticks. And I hope your local law enforcement has a good sense of humor. Blasting down the road with open headers can be fun. Kinda lets you fantasize that you are in a NASCAR, just don't over do it and wear a full face helmet.
03-18-2009, 12:37 AM | #17 |
03-18-2009, 12:55 AM | #18 |
Eat My Rust
I'm on the verge of the sticks, close enough. It'd only be for a few days though, I leave for school at 6:50, and my neighbors don't mind it cranking up cold so far (very cam'd sounding, lots of rumble), so I obviously don't want to blow that out of the water too long
03-18-2009, 01:03 AM | #19 |
6:50 AM..... hmmm, if you left at 5:50 AM, I wouldn't need an alarm clock
Maybe you are your neighbor's alarm clock
03-18-2009, 01:08 AM | #20 |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-18-2009, 01:10 AM | #21 |
Eat My Rust
03-18-2009, 01:53 AM | #22 |
Just be careful about fumes, don't what to be turnin blue.
03-18-2009, 10:15 AM | #23 |
Senior Moment
I have electric cut outs on my headers so I can open them up any time I feel the need and I feel the need at least once every drive. It’s so fun to pull up next to a ricer and open them up then leave him in a VERY loud cloud of smoke I love it.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 03-18-2009 at 10:15 AM. |
03-18-2009, 03:07 PM | #24 | |
03-18-2009, 06:47 PM | #25 |
20' Daredevil (Ret)
What?
