Old 03-18-2009, 03:42 PM   #1
Livrat
Member #1049
Livrat's Avatar
OEM in bed spare carrier
Factory inside bed spare tire carrier.. $45.00 shipped
Livrat is offline   Reply With Quote
Old 03-18-2009, 05:32 PM   #2
stope4
Re: OEM in bed spare carrier
I would like to be first in line on this but would like to know if these came in fleetside trucks?
stope4 is offline   Reply With Quote
Old 03-18-2009, 08:58 PM   #3
chipflyer
chipflyer's Avatar
Yes, they were a factory option. P13 - SIDE MOUNTED SPARE. It shows the proper mounting location in the Assembly manual also.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-18-2009, 11:11 PM   #4
Livrat
Member #1049
Livrat's Avatar
You are first up for it..
Yes.. Like chipflyer says it is a factory option in the fleetside trucks..
Old 03-18-2009, 11:59 PM   #5
72lb4x4
Next in line...
Send me a PM if it gets this far. I'm not sure email is getting to my new address.
72lb4x4 is offline   Reply With Quote
Old 03-19-2009, 09:38 AM   #6
stope4
I'll take it. I'll pay with PayPal if that is o.k. PM me you information and I'll get this taken care of.
Old 03-19-2009, 11:44 AM   #7
Livrat
Member #1049
Livrat's Avatar
stope4 its yours... PM sent
Old 03-20-2009, 01:18 AM   #8
stope4
Now that I bought this thing, how do you mount a tire on it?
Old 03-20-2009, 12:34 PM   #9
Livrat
Member #1049
Livrat's Avatar
SOLD.. Thank you!!
I have never seen a complete assembly to know how the factory mounted the spare, anyone have any pictures they could share??
Old 03-20-2009, 03:22 PM   #10
wesmigletz
wesmigletz's Avatar
Just curious, would one of these work in a Short Bed Fleetside? I think I saw one listed at LMC.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 03-20-2009, 06:17 PM   #11
nds1968
nds1968's Avatar
Yes it will work on a shortbed. Mine had one on each side between the tailgate and wheel well area.
You need a J-bolt, plate w/hole, and a wingnut to hold the tire in place.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 03-21-2009, 12:01 AM   #12
wesmigletz
wesmigletz's Avatar
Thank you.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 03-21-2009, 02:08 AM   #13
sleepertruck72
sleepertruck72's Avatar
Subscribed ... I sold one to eightbanger and didnt have the hardware to mount the tire... I know he is looking for the hardware. Any pics ???
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 03-21-2009, 02:55 AM   #14
leddzepp
Moderator
leddzepp's Avatar
I have one in my 3/4 ton truck too, and would love to see how the spare is mounted...
Old 03-21-2009, 06:18 AM   #15
nds1968
nds1968's Avatar
You can also take a carriage bolt instead of a J-bolt and slide it through the slotted hole.
Nate
Old 03-21-2009, 08:51 AM   #16
stope4
May be a dumb question and I think I know but just to verify, What is a j-bolt?
Old 03-21-2009, 09:30 PM   #17
chipflyer
chipflyer's Avatar
Sometime back I tried and tried to get a look at the original mounting hardware but nobody on here ever did come up with a pic. Surely someone must have an old truck with the original hardware still mounted?
Jeff
Old 03-21-2009, 10:25 PM   #18
Hart_Rod
Hart_Rod's Avatar
Doesn't it use the same hardware as the underbed spare tire carrier?
Hart_Rod is offline   Reply With Quote
Old 03-21-2009, 11:07 PM   #19
chipflyer
chipflyer's Avatar
Nope, I tried that, nothing to keep the bolt from just spinning and its way to long. I am using that special nut on mine though.
I would guess that a carriage bolt would have been used originally, but that is just a guess.
Jeff
Old 03-22-2009, 07:59 AM   #20
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: OEM in bed spare carrier
Guy's I can help on this one , the J bolt washer and wing nut for a 67 68 69 camaro work's perfect , and probably isn't way off from correct ! I put this style in my 67 and I had a 67 camaro J bolt and it fit's perfect !
they sell those cheap on ebay all the time ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-22-2009, 08:08 AM   #21
19673ontree
CAN'T FIX NOTHIN
I think that the spare in the bed on a fleetside look's classic , when I was searching for a truck if it had been a stepside I would have REQUIRED it to have the fender mounted spare , the fender mounted spare on a stepside is wayyyyyyyyyyyy cool !!
here is a pic of mine with the spare in the bed
underdash AC
Old 03-22-2009, 09:48 AM   #22
chipflyer
chipflyer's Avatar
Can you show us a pic of your setup?
Jeff
Old 03-22-2009, 07:49 PM   #23
stope4
19673ontree - are you meaning the j-bolt and wing nut for the camaro jack and tire?
Old 04-07-2009, 10:01 PM   #24
stope4
O.K. I found an original bolt for the underbed spare tire carrier. This bolt has a flat rectangle looking washer welded to the head of the bolt. This fits perfectly into the hole on this carrier. In other words it may be a match. Does anyone know what that little wing nut looks like for the underbed carrier? can you post a picture?
Old 04-10-2009, 09:54 PM   #25
stope4
Here you go guys. This bolt is exactly like the one I found with a under bed carrier. The head fits perfectly into the opening on the in-bed carrier. This auction is not me. I just happened to see it tonight and I think this is correct.
http://cgi.ebay.com/ebaymotors/NOS-1...1%7C240%3A1318
