Cantankerous Geezer
Re: LWB frame question
The 3/4 ton frame is longer and the steel is a little heavier. Shorten by cutting out a section behind the cab where it's straight. The spring mounts are different, but can be swapped.
Keep looking for one locally. It might take a while, but they are out there. And if you find a long frame with a decent bed you could make it a long bed 1/2 ton.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
