Old 03-31-2009, 08:14 PM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
Oil filter seal keeps blowing out. HELP!!!
My 72 keeps blowing the oil filter seal. It is a stock 402 with 93,928 orig miles. Luckily it has only done this in the driveway & run for at the most 20 - 30 sec at a time. What could be causing this. I figure some thing is clogged up some where. It also broke the part the oil filter screws on to(sorry no pics). Any help would be appreciated.
Shane
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 03-31-2009, 08:18 PM   #2
Chevymann1968
Chevymann1968's Avatar
Re: Oil filter seal keeps blowing out. HELP!!!
Well not trying to stupid or rude but your not putting it to tight and breaking the seal???
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 03-31-2009, 08:21 PM   #3
chas350
Do you have an oil pressure guage? If so, did you notice the pressure while it was running? Are you sure it is the correct oil filter? I had a filter screw on even though the threads were one size bigger then blow off when it started.
The wrong filter could be the problem if the flow is interrupted, the pressure could build with nowhere for it to go, causing a seal blow out.
good luck
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 03-31-2009, 08:24 PM   #4
chas350
Chevyman has a point, if the old filter was installed without oil on the seal and over tightened, the old seal can stick to the filter boss and can go un-noticed with the new filter and seal going over this and leaking like a sieve.
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 03-31-2009, 08:58 PM   #5
shaneschevys
I am only putting it on hand tight. The old seal is the first thing I checked for. It has good oil pressure till it blows the seal. As far as the filter goes first filter was a fram ph5 #2 filter was a acdelco pf1218
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 03-31-2009, 09:23 PM   #6
Chevymann1968
The only reason i asked is because i did it before but if it has good oil pressure then i dont know????
The engine didnt sound like that it was tapping or anything???
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Old 03-31-2009, 09:25 PM   #7
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I run a Napa Gold on mine. I took advise from the board (search oil filters) and was very happy with the results
The 72 BB calls for
Part Number: 1061
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=11/27
Burst Pressure-PSI: 285
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.444 3.100 0.260
Which seems to be the same Part # cross over as what you are using.
Couple of questions. Did this happen right after an oil change?
How much oil is in the motor? (not trying to sound stupid we have all misread a stick probably at some point.)
Hand tight plus a quarter turn? I may go a bit snugger but I have never had one leak.
Just some thoughts and questions
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 03-31-2009, 09:39 PM   #8
shaneschevys
The 72 BB calls for
Part Number: 1061
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Gasket Diameters
I didn't change the oil.
Hand tight + some on the 2nd filter
I put 5 quarts in the engine.
I am afraid one of the main bearings is trying to spin & blocking the oil passage causing it to build pressure. There is no metallic in the oil. Is this possible?
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 03-31-2009, 09:40 PM   #9
beautimus
beautimus's Avatar
if the oil filter adapter broke on you that would be my first suspect.
can you give us some more background on this engine? have you recently changed camshafts, is it newly rebuilt etc.
without more to go on, my next suspicion is that the relief on the oil pump is stuck. you would have to verify that by hooking up a mechanical gauge to check and see how high the oil pressure is going at speed. it its getting up to 75 or 80 psi, that will cause a multitude of leaks.
is it by any chance a new oil pump?
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 03-31-2009, 09:49 PM   #10
bhoeger70
bhoeger70's Avatar
there is a pressure relief valve under the filter, if this were to be stuck in the closed position I belive it could cause this.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 03-31-2009, 10:12 PM   #11
shaneschevys
I checked the relief. It moves freely.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 04-01-2009, 11:31 PM   #12
72BLUZ
72BLUZ's Avatar
i would check the valve cover breater, and maybe change to a diff filter. even try flushing the engine of any debris that could be restricting the oil
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 04-01-2009, 11:50 PM   #13
6packed
OL' YELLER
6packed's Avatar
Here's a little trick that I learned a few years back from an old time machanic, (I had the same problem) 1. drain the oil
2. replace with 1 gallon of Diesel Fuel, 3. run engine for 20 seconds, 4. drain diesel & repeat one more time, 5. install new filter & oil, 6. run engine for 5 minutes, 7. drain again, 8. Install NEW filter & Oil & your done, This seems like a lot of trouble, But Believe me, I've done this 2 times now and works nicely, & it helps break down any sludge build up.
Good Luck
CALLING IT QUITS - LETS MAKE A DEAL
1967 GMC - Ol' Yeller - 305 V6 cid
1967 GMC 4x4 - Ol' Black'er - 292cid ( project)
1967 Chevy Ol' ???? -Parting out
1971 GMC - Ol' Grey'er (parting out) - 350cid
1969 GMC - Ol' Red'er (parting out)
1970 Chevy - Ol' Primer (parting out)
& counting
1995 Blazer
6packed is offline   Reply With Quote
Old 04-02-2009, 01:31 AM   #14
So.Cal.Super
It'll Buff Out!
Good Luck
I know this isn't funny 6packed but when you said sludge build up, all those Castrol commercials came to mind.
Shane I'm a bit confused, maybe I am reading it wrong but you said
"I didn't change the oil.
I put 5 quarts in the engine."
So you did change the oil and then this happened for the first time?
Man Card Rules
Old 04-02-2009, 06:58 AM   #15
truckdude239
truckdude239's Avatar
just buy an oil system cleaner why put diesel fuel inside a motor where to its not maded to be?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-02-2009, 07:57 AM   #16
beautimus
beautimus's Avatar
the little valve under the oil filter is a filter bypass, its there to keep from starving the engine in case the filter becomes too restricted. the pressure relief is in side the pump. if it gets hung up in the closed position, you will over pressure the engine. the weakest link will fail first. how much pressure are you getting?
Old 04-02-2009, 08:26 AM   #17
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I wouldn't run a flamable liquid in high temp, high pressure situations, in any circumstances. Not to mention what it will do to your bearings in just 20 or 30 seconds.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-02-2009, 09:44 AM   #18
b-rad
Good Luck
i have done this before and it does work on a ENG with a lot of sludge build up
b-rad is offline   Reply With Quote
Old 04-02-2009, 09:56 AM   #19
68gmsee
Active Member
68gmsee's Avatar
I've used Phram filters for many years without any problems.
Could be a combination of things, but I'd start by replacing the oil filter adapter plate. Threads may be screwed up and filter could be working itself loose. They're fairly cheap.
68gmsee is offline   Reply With Quote
Old 04-02-2009, 10:50 AM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
This note is only a comment, since we're talking about flushing sludge from an engine.....
When I worked at Sears Auto Center in the mid-70's, we had an engine flush procedure that was not my concoction. If my memory serves me, it was a quart of Risolone, and some kerosene. There may have been something else, but I don't remember what. I was not a fan of the idea, but there were a lot of older engines at the time that were sludged up. Todays' oils are better but failure to maintain an engine, even with the improved oils, won't prevent the sludge if you're doing short hops and not bringing your engine up to temp and eliminating all of the condensation that can form.
As to sludge, my old solid-lifter '56 Merc had it out the wazoo. At that time, it seems that the school of thought was non-detergent oil in solid lifter engines and only the hydraulic lifter engines needed detergent in the oil. I don't buy that for now, but I comprehend the idea.
Member Nr. 2770
Old 04-02-2009, 11:19 AM   #21
Boog
laying low
Boog's Avatar
Since you say the oil filter adapter is now broken that will be the first thing to replace then a new AC filter. The adapters are not expensive. What weight oil are you using? After replacing the adapter get it started again and check for leaks and test the oil pressure just so you'll know.
It's probably nothing more than a worn out adapter allowing the filter to lose it's seal under pressure. It's a good thing it didn't happen while running down the hiway.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-02-2009, 11:24 AM   #22
shaneschevys
After talking to a friend of my dads that is what he said. I have a new pump ordered. So hopefully that will fix it. I only have the stock guage & it is now stuck in the middle with the engine shut off.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 04-02-2009, 02:24 PM   #23
tim21391
tim21391's Avatar
i use fram ph5 on my 402 with no problem
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-02-2009, 11:14 PM   #24
72blue
72blue's Avatar
sounds like it has been over pressured.
James
72blue is offline   Reply With Quote
Old 04-02-2009, 11:50 PM   #25
spinning wheels
spinning wheels's Avatar
Just throwing this out.
Have you checked for any clogged PCV valves? Could be your breathers are clogged causing pressure buildup in the crankcase.
As for removing sludge buildup. You can use motor flush made by Gunk. Another option is using a quart of ATF and running the motor for about 5 minutes, about the same as Gunk's motor flush. ATF acts much like a solvent and helps removes sludge. Some mechanics have claimed that engine flushing systems, that shops charge an arm and a leg, are worthless and can do more harm than good.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
