Old 04-29-2009, 11:59 PM   #1
Rippin-J
OurLadyofBlessedAccelerat ion
Rippin-J's Avatar
In-truck Head Removal - need advice
Howdy all. I'm learning the ropes when it comes to diagnosing and repairing motors. I have had some trouble with one of my cylinders (only putting out 20 psi), and after doing all of the standard tests, talking to MANY people (thanks NC Goofs!) and doing some extensive research, the best guess is that there is an issue with the valves.
I need help because I would like to remove the heads WITHOUT removing the entire motor from the truck. All of the manuals I have found and read give plenty of detail about disassembling the motor, but always with the motor fully removed. Thus, there are not any notes about things to do or not to do.
I guess my hope is to save some time and some $$ by not removing the whole thing and just having to redo the top-end vs the entire motor. If fixing the valve issue makes the motor run like a champ, I will be very, very happy.
- is this poor thinking on my part?
- has anyone performed this before?
- any suggestions, advice, or things to be extremely cautious of?
- anything else I should consider?
Otherwise, I am going to just go for it and hope for the best.
Thanks!!!
_______________________________________________
1968 Chevy C-20 w/ 396
1997 HD Sportster 1200 street tracker
1994 Chevy 1500 Silverado
Rippin-J is offline   Reply With Quote
Old 04-30-2009, 12:13 AM   #2
Jim_PA
Re: In-truck Head Removal - need advice
Take a bunch of pictures with your digital camera during disassembly.
don't use the china-wall gaskets on the front and back of the intake during re-assembly--
If you don't have a book to follow on putting it back together, I recommend getting one, or just go to the Edelbrock website, and print out the instructions for installing the intake and heads.
It isn't rocket science, but it gives you piece of mind when you follow someone else's instructions.
Jim_PA is offline   Reply With Quote
Old 04-30-2009, 12:18 AM   #3
El Jay
Gone to greener pastures
I've pulled heads in frame before without any problems.
Be sure to drain the cooling system first to keep from losing to much coolant into the crankcase.
Then change the oil & filter after you are done with the heads.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-30-2009, 06:40 AM   #4
Blazer1970
Blazer1970's Avatar
Overall it is A LOT easier to R&R a head with the motor out of the truck. If you don't have a crane and an engine stand and you are (hopefully) only doing one head, it will be easier to just do it in the truck.
Blazer1970 is offline   Reply With Quote
Old 04-30-2009, 07:11 AM   #5
BluTrukker
BOHICA
BluTrukker's Avatar
I agree, try to keep as much coolant as possible out of the crankcase. Change your oil before you even test fire. Even a little coolant is hard on bearings. Also, make sure to lay rags in the valley and distributer hole while you are cleaning up to keep all the debris out of the engine. Other than that it is the same as doing it on a stand, except you will be leaning over the fender. I recommend haynes manuals if you need help. Good luck
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 04-30-2009, 07:34 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
it works the same in-frame as it does on a stand. they just do it that way so they can get better pictures for the book.
get a quality torque wrench, do not rent one as they probably have been abuse and are out of calibration
68C15 is offline   Reply With Quote
Old 04-30-2009, 08:00 AM   #7
mrein3
mrein3's Avatar
I've had the heads off my truck with the block still installed a couple of times. And my truck is a 4x4 - which leaves not much room in the back to work on those bolts back there.
I would NEVER remove an engine if I'm pretty sure I have a valve issue.
Like others have said:
Drain the coolant.
Lay rags in the valley.
Clean everything REALLY good before assembly.
When you think you've cleaned up enough, clean again.
I've used a shop vac in the valley. It works really well.
Change your oil & filter after you reassemble - before running the engine. Then take a page from the vortec intake gasket re-do book and change your oil and filter again 50 miles later. Oil is still cheap compared to a rebuild.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-30-2009, 08:44 AM   #8
Rippin-J
Rippin-J's Avatar
appreciate all of the feedback and input.
if I have isolated the problem to just one side of the motor, is it necessary to take both heads to the machine shop?
I had been advised to go ahead and get both redone at the same time.
Old 04-30-2009, 08:54 AM   #9
Rippin-J
Rippin-J's Avatar
scratch necessary ...is it recommended?
Old 04-30-2009, 09:31 AM   #10
monte0185
monte0185's Avatar
Are there alot of miles on your truck? My expeience has been when you have alot of miles and you go to rebuilding heads your going to add pressure to everything else which in turn is gonna take your bottom end out shortly afterwords. If the bottom end has been rebuilt recently then just follow the above instructions and good luck. But if it were me and I knew I had valve problems with alot of miles the I would just go ahead and pull it and rebuild the whole thing. Doing it once right is generally cheaper then doing it two or three times cheaply.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-30-2009, 01:02 PM   #11
mrein3
mrein3's Avatar
I would advise you the same way. What ever valve issue you have on the one side is probably happening or getting ready to happen on the other side. Pull them both, take them to a reputable shop, re-install, and don't look back.
While your heads are in the shop you can prep and paint your intake. Prep your valve covers if they are painted steel. When you get your heads back they should be all cleaned up. Put the prepped covers on them and paint them before installing.
When the paint is dry and you get it all back together it will look AND RUN like a million bucks.
'72 Malibu hard top
Center City, MN
Old 04-30-2009, 01:53 PM   #12
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
This is what I’ve learned on doing intakes (applies to heads too). Drain radiator as mentioned, and then drain the oil in a clean pan. Leave the plug out and put another pan to catch drips / water. Right away use rags soak all the water you can in the lifter valley.
Finally when you have everything going back together, just before you install the intake, pour some of the oil into the lifter valley to flush out any water that may have got by.
You might not want to dump it all in depending on how much crud is collected at the bottom of the pan, if the oil is clean no problem.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-30-2009, 02:46 PM   #13
Matt_ks
Matt_ks's Avatar
Ok so here is my two cents worth.....
Valves are just one of many things that could lead to a weak cylinder..
hopefully it is just a valve or two.. but here are some other things to consider
#1 Piston rings
#2 Flat Cam lobe
Now im sure that these item have been mentioned some where in this post or at some point they where brought up, i just didnt see them here in this post.
As far as doing just one head.... Dont u have the top end tore down that far you might as well do them both!!!!! A head job is only going to run you about 200-250 bucks and that is with buying the head and intake gasket from the machine shop, ( at least thats what I paid for myu Aluminim Heads and Gaskets) As everyone has already said, take your time, CLean up real well, and CHANGE THE OIL another thing to think about is stuff sum rags into the cylinders this will soak up the coolant and keep a good bit of the gunk out.
hope this helps.
Matt_ks is offline   Reply With Quote
Old 04-30-2009, 07:43 PM   #14
Rippin-J
Rippin-J's Avatar
Heck yeah, all great input. I am getting pretty excited about tearing into it ...hopefully on Sunday.
Matt_KS - to your other two suggestions, would a flat lobe on the cam result in the valve not opening and closing (ie, not moving when I turn the motor)? AND, I have considered the piston ring (and pray that isn't the problem) but was told and have read that if the compression doesn't go up after adding oil directly to the cylinder before doing the test, then it's a valve issue. I tried that a couple of times and the reading never got any better. Is there another test I can try that would specifically target the piston rings?
couple more questions:
- what is 'the valley' you all are referring to? I assume it's the valley-like area between the heads beneath the intake. never seen one freshly opened so not exactly sure where to look for (and later to add) the oil/water mentioned above.
- what parts do I need to be sure to bring with me to the shop other than the heads? pushrods, etc?
- when everything is at the shop getting serviced, should I use a garbage bag or something to keep the block wrapped in to prevent stuff from getting into the cylinders?
- finally, is there any cleaning, inspecting or servicing that I can do myself on the pistons/cylinders while the heads are off?
Thanks again everyone, very helpful.
Old 04-30-2009, 08:14 PM   #15
berencam
berencam's Avatar
Your correct on the lifter valley. I used duct tape when i did my truck to cover the valley and cylinders, I purchased a set of remaned heads for 375 so i didnt have to take them in to be worked on. You can inspect the cylinder walls for scoring. Also while your in there to tell weather or not it is a flat cam lobe, turn the engine by hand and watch the lifters in question in the lifter valley. I have pictures of the same brake down and rebuild in the truck just like you want to do, so you can see what your getting yourself into, links in my sig. Its my 1970, first or second page.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-30-2009, 08:37 PM   #16
truckdude239
truckdude239's Avatar
just replace the push rods and rocker arms cost me 20 buxe for all 16 rods and rocker arms
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-30-2009, 09:05 PM   #17
Matt_ks
Matt_ks's Avatar
Yes a flat lobe will cause the valve not to open!! If u have tried the oil in the cylider trick and the pressure didnt go up!!! then that my friend is a very good indication, that you are going to have to replace some rings, there is a couple ways of doing this, you can just fix the cylinder that is down, but heck u have it tore down this far, and rings are sold in a set so might as well do the other 7.
One other thing I forgot to mention on the cam lobe is that you may just have a collapsed lifter, this is where the hyd lifter nolonger holds its pressure and while the lifter may be riding the full travel of the lobe, because the lifter is collasped it will not open the valve!
As far as you other questions ie bagging the block yeah it wouldnt hurt it will keep it cleaner, the only thing you will need to take the the shop is the heads now even if it is a ring, or cam issue it still wouldnt hurt to have them redone cuz if it a ring issue your going to have to rebuild the rest of the motor too, kinda sounds like it may be a little wore out as it is?
A rebuild if you do it yourself can cost anywhere from 350 to when ever your pocket book says stop. but you can build a good running stout motor for about 600 bucks and be proud to say that you built that to all your buddies.
hope i havent confused u too much! but if I did then dont hesitate to hit me up on here again.!
Old 04-30-2009, 09:09 PM   #18
72blue
72blue's Avatar
before you go to the machine shop with them, take off the head in question and inspect the gasket. You may have a bad one and that could be your problem. This may have been said before, but didn't see it. I had this problem b4 and that was the fix.
Now if this is your excuse to go spending some $ then go on ahead, but if you want to do the least and keep on truckin then remove that head first, inspect it and if it looks well, then go right ahead and proceed w the other. Hope you get her runnin soon.
James
James
72blue is offline   Reply With Quote
Old 04-30-2009, 09:50 PM   #19
Hutch
Hutch's Avatar
Here is some great reference material on the subject.
David Vizzard has alot of engine books
The first one is a great book to start with it will answer alot of questions and is a step by step book.
Years ago I used one of these to rebuild an engine and I learned alot of things that I still use today.
http://www.amazon.com/s/?ie=UTF8&key...l_8141dab3aj_b
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-30-2009, 10:10 PM   #20
Hutch
Hutch's Avatar
Oops bad link
Just go to amazon.com and type in David Vizard in the search box
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 04-30-2009, 10:31 PM   #21
Average Joe
Average Joe's Avatar
This is all great advice but I would like to add if pulling the heads while still on the vehicle drain the block. You will find a small plug at the bottom center of the block abot a half inch above the oil pan flange. These can sometimes be a bear to remove but will get alot more coolant out that would otherwise go in the cylinder.
Average Joe is offline   Reply With Quote
Old 04-30-2009, 10:34 PM   #22
tim21391
tim21391's Avatar
i know its not the same but i pulled both heads off my dads 67 mustang and such and had no problems
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-30-2009, 11:01 PM   #23
brad_man_72
the boat guy
brad_man_72's Avatar
pulling the heads is a good way to find excessive cylinder wall wear and lead to a 500hp rebuild........
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-30-2009, 11:04 PM   #24
highperf4x4
Since you're pulling all the accessories off the front of the motor anyway you can take the 4 bolts out of the water pump and take it off to drain the coolant. That will get your coolant below the head line. That's how I do it when I'm pulling them in the vehicle.
As mentioned before, pull the intake first and spin the motor (take the spark plugs out and it will turn easy). If the lifters for that cylinder aren't moving as far as the others then it's the cam and you need to pull the motor and start from scratch.
If you're going to do one head, then you should do them both. If the engine is old enough that it doesn't have hardened valve seats for unleaded gas then you'll want to have them installed. If the engine is high mileage then you can expect it to smoke after you do the valve job as you've increased cylinder pressure thereby increasing "blowby"
Definitely put some clean rags in the cylinders before you start cleaning off the old head gaskets but I wouldnt' drain the oil until after you've cleaned the gasket surfaces. Whatever falls in the motor will drain out better with the oil. I'd also flush the lifter valley with deisel fuel while you have the drain plug out. Run your finger around in the valley while you're at it to see if you find any copper. Copper is in the "core" of your bearings. If you find any then your bearings are in bad shape and you should pull the engine and rebuild it.
Another thing to check while you have the heads off is the "ring ridge". Your piston rings stop about 1/4" from the top of the cylinders. If you find a pronounced "ridge" there then your cylinders are extremely worn and you should pull the motor and rebuild it.
highperf4x4 is offline   Reply With Quote
Old 04-30-2009, 11:20 PM   #25
Rippin-J
Rippin-J's Avatar
For those keeping up with the thread, here is a brief history of the motor: bought the truck 2 years ago, has never ran well at all. the truck had sat for 5 years in a garage prior to me and the motor 'was completely rebuilt before that.' No way of knowing what all was done to it or if it was broken in correctly, etc. I do know one thing, the motor and engine compartment are super clean so it's not a rusty/dirty old beater motor (at least on the outside).
I need to spend money like I need a new hole in my head, but I can't help it I love these trucks and I am dying to get mine running well!! These Carolina spring days have me aching to get out onto some country roads.
Based on everyone's input, I think I am going to push forward in getting the heads taken care of in hopes of that being the answer to my prayers. From there I can evaluate whether it'll be necessary to rebuild the entire motor ...that's something I have always wanted to do, but not until there is an absolute need for it.
If I read everyone right the major things to recall are:
- take lots of notes
- take lots of pictures
- drain the oil
- drain the coolant (rad and block)
- soak up fluid in valley
- clean (and paint) everything being removed
Weather permitting, I may tear into it this Sunday and will try to post an update as soon as I can.
Thanks a ton for eveyone's help thus far! Headed over to Amazon.com right now to see what David Vizzard is all about.
Berencam - thanks for the heads up on your thread.
