Old 05-10-2009, 10:27 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Rear end cover Alum - who is running This one
I am looking at an LPW rearend cover - maybe a TA
Is anyone running one of these?
Does the panhard bar get in the waY
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 05-11-2009, 03:34 PM   #2
ej69c10
ej69c10's Avatar
Re: Rear end cover Alum - who is running This one
That is a awsome rearend cover.
ej69c10 is offline   Reply With Quote
Old 05-11-2009, 03:54 PM   #3
cdowns
cdowns's Avatar
i believe there's panhard clearance issues with covers like that
Old 05-11-2009, 09:25 PM   #4
lchall
Yeah, I think the standard panhard bar will have clearance issues. ECE makes a bar with a bend in it that allows you to use the aluminum covers.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 05-11-2009, 09:35 PM   #5
jbristo67
resident oilfield trash
jbristo67's Avatar
Its CPP that makes that bar and it still didnt clear
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-11-2009, 10:19 PM   #6
Bowtiefreak
Bowtiefreak's Avatar
ECE makes bars that have a bend in them for bigger alumn covers now, or you can get the bar and cover both from them.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 05-11-2009, 10:59 PM   #7
1968SWBBigBlock
Active Member
I bought one of the LPW covers today - the term no way is this sucker going to fit came to mind when I climbed under the truck- the stock rear cover leaves only 1/2-3/4" clearance - the LPW is 1.5 inchs taller than a standard rear cover - so Jegs will get another return
1968 SWB
