Whats on your 'to do' list?
I have some, quite a few!! Just wandering who is worse off than me. I hate previous owners! Maybe by seeing other people problems, my pockets wont feel so empty.
-Find mystery Trans problem -Trim bottom front corner of fenders -Replace missing wingnut for aircleaner -Battery holddown -Adjust rear brakes -Get custom true dual exhaust with Magnaflows -Tune carb -Finnish primer -Install door pannels, figure out the rusted screws.. -Install carpet/whole rest of interior -Shop around for good stereo place for install of everything -Gear Vendors overdrive (4.56, 35's suck on highway) ![]() -Actual paint job, undecided color |
profeshinaly unimployed
Re: Whats on your 'to do' list?
these arnt really in order
bed line my truck stacks supperswampers air lockers carb new bench seat cb radio comp cam h-pipe intake manifold lift light bar on roof new steps for my bed tow hitch winch vortech heads
"having mud flaps is like asking for a smaller trophy" |
fix front end
not in order stereo winch in a custom bummer with rock/spot lights different lift in rear, to coilovers hopefully beadlocks bed liner new seats cb radios and more powerful engine be upgrading the 350 it has or build bbc or 383 it has about 300hp now i guess And lightbar on roof And new t case.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
the pollock
finish project without angering wife or starving children...
that's my "list"
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Resident of Here
Lift front end to even out suspension
Lockers Change all fluids 33" BFG A/T
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Bloodied Knuckles
prepare to feel better about your small list...
Item #1 find another lift kit to order... Item#2 Install lift (sounds like suck a small task donnit) Item#3 Install custom winch bumper Item#4 Replace Body Mounts Item#5 Replace Mirrors Item#6 Replace Ball Joints Item#7 Replace drag link Item#8 Replace brake pads (all around) Item#9 Replace rear axle bearings (fronts done) Item#10 Replace drivers side rocker Item#11 replace rear windsheild rubber and possibly install slider Item#12 Re-upholster seat (or replace with 4point harness type) Item#13 Install new dash bezel and tac Item#14 Rewire trailer lights Item#15 Install stereo ( been putting this off forever) Item#16 Install mastershift 3 spd floorshifter(replace indy shifter) Item#17 Install 35"x12.5" Baja radial claws (thats gonna hurt$$) Item#18 Replace Headers (shackle bolts are touching the headmans) Item#19 Replace drivers side window track Item#20 Replace all ujoints in used front driveshaft+install Item#21 Install new alt bracket (billet side mt) Item#22 Replace stock lap seatbelts with either shoulder type or 4-5 point harness (still undecided) Item#23 Replace radiator (pinhole leak in mine) Item#25 Replace plug wires (want them routed cleanly) Item#26 Tune up (I think timings a lil off) Item#27 Fabricate rear tailgate spare tire cage thingy (Think pre-runner mount, but replaces tailgate) Item#28 maybe start body work lol Item#29 Build new doghouse to live in once wife sees the bill Last edited by Eturnit3; 06-02-2009 at 06:04 PM. Reason: I type faster than I think |
eturnit3 why are you going to run the mt baja claws and not the procomp xtreme all terrain i think they're almost the same design and cheaper?
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 06-02-2009 at 06:26 PM. |
Thats quite the list man. I feel a little better now. Trans problem solved (vacume of all things) , and Chevelle steering wheel installed. So thats a few off my list. BTW, I second the thought about the Claws. It seems every time Ive seen them in person on a truck, they were bald. X-AT's are
Bloodied Knuckles
Yeah I just liked the tread pattern and the price tag was only a grand, but Im not sold on em.... will look at the procomps, thanks guys...
Heres mine- First- a 10" lift. Second some 20x10 Dick cepek wheels with 38" open countrys. Third- Paint it a nice black with a coffee color on the bottom. And last give the Truck soon vroooooom vrooooom alot of vroooooom vrooooooom hahahahahahahaha the world is mine hahahaha oops got carried away.
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
i have a new to do list same as above but, save 800 for a new truck and add that stuff to both.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 06-02-2009 at 10:25 PM. |
Cradle Robber
In order
figure out why my rear driveshaft keeps falling off change my tps sensor pop the dent out of my drivers side door(that one happened after I kicked it the last time I lost my driveshaft) Put a new new passenger side door new passenger side front fender new passenger side quarter panel paint |
My`72 K2500 has a list.I divide the needs into groups of priority.
Group#1: *Tie rod ends...last wear parts to replace.Still has play *Lift kit...springs are settled bad and shocks are shot.I want higher ![]() *Tires...worn to where they affect the steering.I want taller ![]() Group#2: *Seat...either fix foam and new cover or swap-out to saddle interior that I have *Carpet *Speedo cable...so I know how far I drive *Fix fuel gauge...so I know how much fuel I`ve used Group#3: *Windshield...foggin`up *Fix surface rust above rear window *Window seals...all *Replace rockers,fix dent in left door and right fender That would get it right.I`d like to paint it,replace all the trim,rebuild the motor,swap to 4.10 axles,have radio modified into a 180w am/fm/cd/mp3/xm...
#15 |
So my truck is all one color now.. Theres another off the list. Pics to come soon.
#16 |
My list is so long that I don't even know where it ends!
1. powdercoat all brackets, rad support $ 2. rebuild PS pump and box 3. finish driver side cab corner/rocker 4. start pass side cab corner/rocker 5. start vent area rebuild 6. weld leaf perches to rear axle 7. clean/install/paint driveshafts 8. install my new SS brake lines 9. install new rear brakes 10.finish front brakes 11. upholster buddy buckets $$ 12. clean inside of doors and paint 13. buy wiring harness install $$$ 14. pay body man to finish everything and paint $$$$ 15. install body panels 17. install exhaust $$ 18. buy rear and side glass $$ 19. install gas tank and new lines 20. pay taxes and die ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 06-21-2009 at 06:46 PM. |
#17 |
Bloodied Knuckles
some pics of the #2 process would be a priceless asset...
#18 |
ask and ye shall receive...
http://www.fourwheeler.com/techartic...ild/index.html don't have one for the ps pump, the kit was only $10 so I figured "why not" ya know...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#19 |
Bloodied Knuckles
hell ya, and the pump looked like the easy part... the box was what I was worried about. Thanks again Big Mike, you are a legend here in the 4x4 dept.
#20 |
So one more will be off the list. Right now, my truck is getting true dual -exhaust, with magnaflows, h-pipe, and side exit before the wheels. Cant wait.
That stock Y pipe is a horrible design BTW! |
#21 |
I didn't write it so I don't know the difficulty yet, i've heard that those metal balls are tricky though...
#22 |
Bloodied Knuckles
Well i crossed off, rebuild new front driveline and install, but added: fight for money back in botched lift kit order from 4wheelerssupply.com... shameless rant
#23 |
Arrived on a Pale Horse
![]() ![]() Bushwacker cutout fender flares TSL Boggers Install seat belts (removed by PO) Insurance Registration (already titled) De-Bling Minor rust repair Paint (Orange) Bedliner by Line-X Stereo and 6x9's (Brackets bought from Jeff) Send center caps from re-chrome process. Already replaced both bumpers and grille/headlight trim.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#24 |
replace the rear u joints and the front axle shaft I broke last night while pulling agianst an 05 f450 powerstroke
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#25 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Between my son's baseball games and my softball, the weekend is busy.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
