Old 06-13-2009, 11:12 AM   #1
BBEEP
Junior Member
BBEEP's Avatar
52 GMC Envoy Burb meld/build
After 4 years of other projects, I'm finally going to start on my 52 GMC Burb. I picked up my 2002 GMC Envoy yesterday. Haven't seen my idea done with an AD. Basically I'm going to cut off the Envoy shell, leaving the entire floor with seats, firewall, most of the dash, etc. Then remove the shell of the 52, 'channel' it over the Envoy chassis, leaving the drivetrain and all the accessories intact. The install will slip the 52 down so that the body is lowered, while the chassis has stock travel. Later I can bag the stock suspension and lay frame. The Envoy comes stock with a 300 hp inline motor that can be chipped, and all wheel, 4 wheel drive. The plan is to have it driving by next spring. Has anyone out there attempted going in this direction?
BBEEP is offline   Reply With Quote
Old 06-13-2009, 11:56 AM   #2
dennis57
dennis57's Avatar
Re: 52 GMC Envoy Burb meld/build
From what little I know about these trucks this will definitely be one of a kind. I can’t wait to see this project.
dennis57 is offline   Reply With Quote
Old 06-13-2009, 01:59 PM   #3
Lextech
Lextech's Avatar
Sounds like a cool project. Is the track width close enough to allow it to be lowered? Is the dash narrow enough to allow it to fit inside the body?
Jeff
Lextech is offline   Reply With Quote
Old 06-13-2009, 02:58 PM   #4
1MADTEXAN
The only other project that ambitious I know of was when a professional rod shop skinned a '68 or '69 Charger body onto a late model Charger.
I'm willing to bet yours will be one of the 1st, if not the 1st, of its kind.
1MADTEXAN is offline   Reply With Quote
Old 06-13-2009, 08:17 PM   #5
OrrieG
OrrieG's Avatar
Will you have enough head room channeling the 52 over the stock ride height Envoy. It looks to me that the seats in the Envoy and such sit pretty high. I'd take lots of measurements before cutting up either one. Also need to check relationship of seats/doors/ firewall too. Could be a cool build.
Old 06-13-2009, 10:38 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
Your a visionary and a mad man.... I envy your thought process and idea.
I think you could wear out a couple of tape mesures for sure..
Keep us posted.
on a side note how did the short bus work out???
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-14-2009, 12:14 AM   #7
BBEEP
Junior Member
BBEEP's Avatar
Jeff
So far I believe the track is very similar. I did the 50 GMC bus and lengthened the frame 6 inches, used a commercial rearend and it worked. I expect to channel it, run stock suspension travel until I'm ready to bag it. The dash is wider by several inches. So far, if I move the two outside a/c vents and the headlight switches, I should be able to make adjustments to the fit.
Old 06-14-2009, 12:17 AM   #8
BBEEP
Junior Member
BBEEP's Avatar
I expect the firewall to sit further under the hood than the AD. The seats actually sit higher in the Envoy. I have Explorer seats in my 48 Panel that still leave lots of room.
Old 06-14-2009, 12:24 AM   #9
BBEEP
Junior Member
BBEEP's Avatar
Keep us posted.
The bus is coming along, thanks. mad man you say, ha ha ha ha ha!
Old 06-14-2009, 09:01 AM   #10
andrewt2
andrewt2's Avatar
subscribing for the ride, this looks like a cool project.
andrewt2 is offline   Reply With Quote
Old 06-14-2009, 09:27 AM   #11
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Cant wait to see this! I like the idea of the modern frame and drive train with the old school style.
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 06-14-2009, 08:26 PM   #12
BBEEP
Junior Member
BBEEP's Avatar
Wink Re: 52 GMC Envoy Burb meld/build
Originally Posted by Slowlearn View Post
love that bus. If that picked me up every day I never would have ditched. Well maybe, hardly ever...
Your username is Slowlearn and you want to ride the short bus?
(no offense intended)
Old 06-15-2009, 01:22 AM   #13
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I wanna know what happens. Subscribing!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
1951 Chevy 2 ton flat bed
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
2008 Chevy Silverado short box 4x4
nickp51chevy is offline   Reply With Quote
Old 06-16-2009, 07:57 AM   #14
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Definetly one to watch!!
ChuckDriver is offline   Reply With Quote
Old 06-21-2009, 12:29 PM   #15
BBEEP
Junior Member
BBEEP's Avatar
Took some measurements last night. I think its going to work even better than I thought. The measurement from the center of the front hub to the steering wheel position and the front seat is the same! Even the door jamb lines up. Can't wait to get started cuttin! Of course will post lots of pics. I've learned from experience that you guys (and me) like lots of pics!
Old 06-21-2009, 10:02 PM   #16
renegade6
Subscribing
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 06-21-2009, 10:12 PM   #17
Skirkpat
Skirkpat's Avatar
good luck!!! should be cool.
Skirkpat is offline   Reply With Quote
Old 06-21-2009, 10:42 PM   #18
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Signing on for the Ride, I like your Concept........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 06-28-2009, 03:41 AM   #19
57ExtCab
Defenently Sounds like a real Plan.
I LOVE these kinds of BUILDS on YOUR DIME.
GO CRAZY, MAN GO 4 IT.
Then again the Wife could be RIGHT
"Just cause I Drink alot of Bud that does'nt make me WISER"
57ExtCab is offline   Reply With Quote
Old 07-07-2009, 12:39 AM   #20
red71c10
The Red Menace
red71c10's Avatar
OK J.M. I came over from the 67-72 board to check it out. Pretty cool concept! I'll be looking forward to seeing your progress on it!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-07-2009, 06:05 PM   #21
nuke1
nuke1's Avatar
great build this will be. just one thought tho. i have done a couple things like this before, just make sure that you strenghten the floor of the envoy up enough so it does not sag. in other words build a small frame structure for it that will be permanent. after it is done you will have something to be proud of.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 07-07-2009, 10:49 PM   #22
57ExtCab
Does the "Envoy" Have a reg frame beneath. Not Unibody?
Will you be welding Burb side panels to "Envoys" rockers and such.
Or I can just wait till you post picsJust setting up late STOKED on this build and have to ask
Sometimes a guy needs to be told just shut the F up.
Old 07-08-2009, 11:56 AM   #23
BBEEP
Junior Member
BBEEP's Avatar
The Envoy is full BOXED frame. Heavier duty than the 52. I will consider using the stock inner quarters from the Envoy. Still working on the measurements. As far as the floor saggin, with the full frame and 'crash tested' floor, I think its stronger than the original wood floor of the burb--but thanks, I will keep that in mind. Gotta love this site and forum!
Old 07-08-2009, 02:08 PM   #24
57ExtCab
Thumbs up Re: 52 GMC Envoy Burb meld/build
What is the general width of this "Envoy" Dash Board? Rocker to rocker? What is your thought about "Envoy's Firewall to Burb's windsheild."
Old 07-08-2009, 02:32 PM   #25
BBEEP
Junior Member
BBEEP's Avatar
Its about 5 inches wider than the 52. I'll pull the a/c vents & put them somewhere else.
For the height I might have to section the firewall slightly. Nearest the Envoy windshield is the same height as the burb, however its about 6 inches further forward. Where the 52 windshield will sit the Envoy is about 5 inches higher, so the front edge can go under the hood. I'll post pics of how I figure that one out!
Lot of thoughts at this point. I sure appreciate all the input.
suburban
