Old 06-13-2009, 11:06 PM   #1
SeanPaintsFlames
SeanPaintsFlames's Avatar
6 lug/ 5 lug?
This 65 GMC I just picked up has the factory 6 lug drums in the front, but it's had a rearend switched into it from who-knows-what with 5 lug drums. What's the cheapest way to make them match? I'm looking at 5 lug disc brake conversions, but they're more than I want to drop into this truck. Are there 5 lug drums that fit for the front?
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 06-13-2009, 11:26 PM   #2
daverod
SSN 706
daverod's Avatar
Re: 6 lug/ 5 lug?
Search craigs list for a 70-80 1/2 beater for $100- $250 and swap out the whole front cross member. If you lucky you can use the power steering and power brakes also.
daverod is offline   Reply With Quote
Old 06-13-2009, 11:27 PM   #3
joe231
joe231's Avatar
Re: 6 lug/ 5 lug?
you don't even have to swap the whole cross-member, just the A-arms out to have 5 lug discs.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-13-2009, 11:38 PM   #4
daverod
SSN 706
daverod's Avatar
Re: 6 lug/ 5 lug?
Da, what was I thinking. That would even be easier.
Old 06-13-2009, 11:45 PM   #5
SeanPaintsFlames
Re: 6 lug/ 5 lug?
Excellent! Thanks!
What if I wanted to keep the drums? Is there a known drum that fits but has a 5 lug pattern?
Old 06-13-2009, 11:50 PM   #6
joe231
joe231's Avatar
Re: 6 lug/ 5 lug?
I don't think so, you would have to find a drum hub that was five lug and fit your spindle, but when Chevy went to 5 lug on the trucks (5 x 5 pattern) they went to disc brakes on the front...not to mention the 6 lug drums are pretty narrow.
you might be able to drill your hub and machine down a rear 5 lug drum...but by the time you did all that work a disc swap would have been cheaper and much less work...
CHEVY ONLY
Old 06-14-2009, 12:12 AM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Re: 6 lug/ 5 lug?
Be sure to check the bolt pattern first, just in case its 5x4.75''.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-14-2009, 12:18 AM   #8
daverod
SSN 706
daverod's Avatar
Re: 6 lug/ 5 lug?
What the diff between 5x5 and 5x4.75 I know .25 but is it the distance between the studs?
Old 06-14-2009, 12:22 AM   #9
protrash64
protrash64's Avatar
Re: 6 lug/ 5 lug?
Yes, its a smaller bolt circle.....Ive seen some trucks sportin' passenger car rears in them. Just never know, thats why I mentioned it.
Old 06-14-2009, 12:28 AM   #10
daverod
SSN 706
daverod's Avatar
Re: 6 lug/ 5 lug?
It true you never know what you'll find. I found a mouse nest with 4 babies in it my car today.
Old 06-14-2009, 02:07 PM   #11
SeanPaintsFlames
Re: 6 lug/ 5 lug?
gross. What did you do with them?
Old 06-14-2009, 02:53 PM   #12
daverod
SSN 706
daverod's Avatar
Re: 6 lug/ 5 lug?
Well at first I gently removed the nest from my car. Then I carefully placed it on the soft ground. Then with the utmost care:
Old 06-16-2009, 02:52 PM   #13
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Re: 6 lug/ 5 lug?
Haha. If you want five lug just switch the front end out from a parts yard. If you want matching 6 lug, find one at the yard and pull the axle. I prefer the 6 lug though, just because that's all I've ever had and have became a pro at finding wheels for them.
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 06-16-2009, 03:12 PM   #14
198plus
198plus's Avatar
Re: 6 lug/ 5 lug?
This is what I'm doing on my 65.............
You can use (72-87) truck spindles. You just change the upper and lower balljoints to same year as "new" spindles (72-87). Also you will need the outer tie rod ends to match the spindles AND a special sleeve to adjust the toe-in. Take your old tie rods and flip outside to inside, add the adapter sleeves and new outer ends.
Note: 71-80 1/2 ton trucks are more likely to have the heavy duty (1 1/4 inch thick) rotors that are most desirable for this conversion.
Link to tie rod adjusting sleeve:
http://www.classicperform.com/Store/1960_1972_Chev..
198plus is offline   Reply With Quote
Old 06-16-2009, 05:20 PM   #15
SeanPaintsFlames
Re: 6 lug/ 5 lug?
See, I'd much rather get all new parts than have to deal with a junkyard. I've seen the drop spindles, which I could do, but then I'd have to get the calipers, caliper brackets?, pads, hoses.. and I guess a bunch of miscellaneous hardware. I'm much more of an ebay-kit sorta guy.
I do like the idea of just changing the axles, though. That shouldn't be too expensive, I imagine.
Old 06-16-2009, 07:08 PM   #16
SCOTI
SCOTI's Avatar
Re: 6 lug/ 5 lug?
If you're a 'kit' kinda' guy, board supporting vendors GMC Pauls & ClassisHeartbeat offer disc brake swap kits as do major players ECE & CPP.
For the rears, ECE & CPP definitely offer 5-lug axle swap pkg's or try Moser Engineering for axles & use your local parts place for the drums (71-72 truck drums). I did the Moser route on my 68 & it was about $300 (in '00 dollars).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-16-2009, 10:51 PM   #17
TwiggyTheDrummer
Re: 6 lug/ 5 lug?
Yeah I'd just do the axle swap. Much easier, just find a matching 6-lug from the same year or a new truck.
Old 06-16-2009, 10:56 PM   #18
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: 6 lug/ 5 lug?
First off what lug pattern do you want. 6 or 5 lug. If 6 lug. I bought my front kit from performanceonline.com it came with 73-87 2 1/2 drop spindle, caliper, rotor, pads, hoses, everything to mount it. You can use the same control arms that you have as well, because the kit comes with ball joints to fit the spindle and tierod ends as well. You can also get the kit to fit the 71-72 spindle, it comes with the correct ball joints for it. Every kit that comes with 6 lug comes with custom rotors to fit the spindle. If you want 5 lug, since you already have the rear end. Make sure you know which bolt pattern you have. All the companys that sell the disc conversion sell either the 5x5 or 5x4.5. These kits run anywhere from 600-700 for a basic kit. You will pay close to $100 for shipping since these are heavy Items. As far as the rear end if you dont know how to change all the stuff, get a pro very easy to destroy a rear end if not right! Also I would try to stay away from classicperformance if possible, a lot of people have been having problems with them and they have very bad customer service. Check with a lot of vendors on here since they give forum discounts!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-16-2009, 11:00 PM   #19
ruffrida2005
Re: 6 lug/ 5 lug?
I should have said if you want the 5 lug 5x5 best thing to do is buy a parts truck for a couple hundred and swap the whole front end except the crossmember, Most people perfer 73-87. getting a donor truck you can save a lot of money since the frames are the same you can reuse all the brake lines MC/PB. Swap out the steering as well! And sorry for the long novels!
Paul
Old 06-16-2009, 11:07 PM   #20
198plus
198plus's Avatar
Re: 6 lug/ 5 lug?
Isn't that front end ..........1.5" wider ??????
Old 06-16-2009, 11:21 PM   #21
Captainfab
60-66 Nut
Re: 6 lug/ 5 lug?
I've never checked the track width on the front, but I do know that the rear differential is 1.5" wider. If the front is indeed wider it wouldn't be as much of an issue as the rear differential. However that can be taken care of with different backspacing wheels. Lots of people use the '73-'87 front suspensions and I haven't heard of any width issues.
Old 06-16-2009, 11:31 PM   #22
ruffrida2005
Re: 6 lug/ 5 lug?
I haven't heard anything about the front being wider at all. As for the back I believe 71 the rear end got 1.5" wider. Not an isue as long as you know what you have and get the correct BackSpacing front and rear.
Paul
Old 06-16-2009, 11:35 PM   #23
SCOTI
SCOTI's Avatar
Re: 6 lug/ 5 lug?
Not quite. The crossmembers & all attached hardware interchange. Even if you don't swap c.members, all disc brake spindles (disc brake conversions using GM 1/2 ton spec'd parts) will widen the track width ~1.00" unless you purchase the spindles that are specifically made not to (CPP's 'modular' spindle).
Swapping axles won't interfere w/the R&P which is where most mishaps occur (just keep from disturbing the internals during the swap).
SeanPaintsFlames . . .... For the axle swap: Pop the rear cover & drain the fluid, remove the retaining pin, push the axles in slightly, plop the c-clips out, slide the old 6-lug axles out, slide the new 5-lug axles in, re-install the c-clips, tug the axles out slightly to ensure the c-clips are seated, re-install the retaining pin, re-install the rear cover, add fluid.
You could do some further maint work & replace the axle seals but it's not mandatory. The benefit of doing the aftermarket axle swap is the replacement axles are of higher quality vs. the originals & they don't have 35+ years of wear @ the bearing surfaces.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2009, 11:44 PM   #24
ruffrida2005
Re: 6 lug/ 5 lug?
I forgot CPP made those modular spindles!
Paul
Old 06-17-2009, 12:01 AM   #25
joe231
joe231's Avatar
Re: 6 lug/ 5 lug?
That is all good info, but I think he is wanting to convert the rear back to six lug from a previous five lug swap
Do they make 6 lug axles to fit 5 lug diffs?
CHEVY ONLY
