Old 07-14-2009, 02:45 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
bulbs
my dash is real dark while driving its like one of my bulbs for my speedo went out...but i cant see were to replace it at....so can some one help me out and tell me where the bulb is at....and im thinking about hooking up some leds for my dash lights
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 07-14-2009, 03:07 PM   #2
JohnC
JohnC's Avatar
Re: bulbs
You take the whole cluster out, and the bulbs are accessible from the back side of it.
JohnC is offline   Reply With Quote
Old 07-14-2009, 05:01 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: bulbs
John is right, get out your screwdriver and nut driver. Oh, and be careful not to break the PRND21 indicator spring.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-14-2009, 07:56 PM   #4
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: bulbs
With as much work as it is to get to the bulbs it is a good idea to replace all the bulbs while your as it.I'm betting they are all the same age.
powerdriver 1958 is offline   Reply With Quote
Old 07-14-2009, 08:27 PM   #5
blazenlo95
blazenlo95's Avatar
Re: bulbs
I plan on replacing all of mine this weekend. Anybody know what size they are?
1976 C-10 472 Cadillac Big Block
blazenlo95 is offline   Reply With Quote
Old 07-14-2009, 08:35 PM   #6
powerdriver 1958
Kid's Mechanic
Re: bulbs
GE 194's
Old 07-14-2009, 08:36 PM   #7
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: bulbs
There are 13 bulbs total They are as follows.....
High beam indicator = 1
Turn signal indicators = 2
Battery warning lamp = 1
Check Engine light = 1
4WD indicator light = 1
Seat belt light = 1
Brake warning lamp = 1
Gauge illumination = 5
Some are #194's others are #168's
THe 168 bulb is a bit brighter in candle power than the 194's are. I'd just replace them all with 168's and be done with it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-14-2009, 08:37 PM   #8
blazenlo95
blazenlo95's Avatar
Re: bulbs
GE 194's
Thank you much.
Old 07-14-2009, 08:41 PM   #9
blazenlo95
blazenlo95's Avatar
Re: bulbs
Any issue with heat from the brighter ones? Are you running the 168's? Cause if there is no melting issues it would just make sense to run the brighter ones.
Old 07-14-2009, 09:12 PM   #10
babyJay
babyJay's Avatar
Re: bulbs
I changed all mine out to L.E.D. bulbs in the 87. Do a search, there is a thread here that describes how to take the cluster apart and chrome the back side of the metal portion. This reflects more light down and off the guage face. I also did that procedure.
Jason
89 R3500 CC SRW
Old 07-14-2009, 09:48 PM   #11
BLE 'BURBAN
Re: bulbs
I found that spraying the inside WHITE worked alot better than the chrome paint did.
Old 07-14-2009, 09:55 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: bulbs
Did you do a scientific test like those clowns on Mythbusters? Seriously, was white brighter?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-14-2009, 10:30 PM   #13
joe231
joe231's Avatar
Re: bulbs
this isn't the first time i have heard white is brighter.....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-14-2009, 10:55 PM   #14
blazenlo95
blazenlo95's Avatar
Re: bulbs
And honestly it just makes sense. If we're talking about spray bomb chrome, I can see white reflecting more light than gray.
Old 07-15-2009, 01:37 AM   #15
pig rig
pig rig's Avatar
Re: bulbs
flat white will reflect more light then gloss white and a mirror
I just replaced all of my bulbs and I wish I would of put the cleaning the cluster and painting it to thought because I can hardly see my trip odometer
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 07-15-2009, 02:32 AM   #16
BLE 'BURBAN
Re: bulbs
None what-so-ever. the 168's are only about 2-3 candlepower brighter than the 194's. I'll bring home my "BULB BIBLE" from work tomorrow that lists all the wattages and candle powers of all the bulbs and give y'all a breakdown on all the bulbs used on our rides. As well as the similar ones that are a bit brighter that will still work with no problems.
Actually yeah I did, I had painted the inside of my ORIGINAL cluster with the "chrome silver" paint and noticed very little change in brightness. When I Modded my cluster (see below in my sig) I painted the replacement bezel white as well as the back side of the front cover semi gloss white and noticed a vast improvement over the chromed one.
I have since gone on to the white light L.E.D. bulbs that I got from www.v-leds.com pictured here.
http://www.v-leds.com/Exterior-LED/C...-p4481083.html
I will soon ,as funds will allow, be upgrading yet again to these installed on the inside of the front cover facing the gauges. Only in blue not white...
http://www.v-leds.com/Interior-LED/D...-p6374230.html
Old 07-17-2009, 11:56 AM   #17
Desert1957
Desert1957's Avatar
Re: bulbs
Hey guys,
I have a stupid question , will the "LED" style bulbs dim with the switch or just go out?
Desert
Desert1957 is offline   Reply With Quote
Old 07-17-2009, 12:01 PM   #18
joe231
joe231's Avatar
Re: bulbs
yes they WILL dim with your dimmer
CHEVY ONLY
Old 07-17-2009, 03:55 PM   #19
Dapper Dan
Dapper Dan's Avatar
Re: bulbs
I take it you only used these for the 5 gauge lights right?
BLE 'BURBAN "I have since gone on to the white light L.E.D. bulbs that I got from www.v-leds.com pictured here."
how would you rate them? any nighttime pictures?
Dapper Dan is offline   Reply With Quote
Old 07-17-2009, 04:15 PM   #20
babyJay
babyJay's Avatar
Re: bulbs
When I did my cluster, I replaced all bulbs with V-LEDS. Green for ullumination, and white behind indicators, etc. They are not as bright as a 168, so I put 168's back into the idiot lights, as I don't have true guages in that truck. Guess I should have used white paint inside instead of the chrome. There's always a next time or another truck that needs done though. I will try to get some pictures tonight after dusk.
Jason
89 R3500 CC SRW
Old 07-18-2009, 12:43 AM   #21
BLE 'BURBAN
Re: bulbs
I did like them alot better unfortunately I don't have any pics right now but when I do get the strip lights in blue I will take pice and show how I install them with before and after shots at night...Trouble is it doesn't get dark enough here right now to get a decent nighttime shot. Dang 18 hours of daylight!!!
Old 07-18-2009, 10:01 AM   #22
joe231
joe231's Avatar
Re: bulbs
I miss the family and I riding bikes on the trails through Anchorage in the middle of the night, people grilling at mid-night, and being able to work on the trucks in the daylight at most all hours of the night....just can't beat all that sunlight
the problem I have found with LED's is they are fairly focused, where a regular incandescent bulb will throw light out in a much wider angle so it reflects off the back of of the cluster and gives more of a glow. I tried some 1157 LED's, with 8-10 LED's in each one, in the tail light of our '66 fleet, they were disappointingly dim, the LED's all pointed towards the lens so you didn't get any reflection to light up the entire housing....I quickly changed back.... the replacement LED's made to specifically fit these trucks are a different story, there are many LED's mounted to a circuit board spread around the entire area of the lens so they do a very nice job of lighting the whole lens.....sorry if I got a bit off topic, but I'm kinda known for it
quote form WIKIpedia
"In contrast to other lighting technologies, LED light tends to be directional. This is a disadvantage for most general lighting applications, but can be an advantage for spot or flood lighting."
CHEVY ONLY
Old 07-18-2009, 10:18 AM   #23
East End K5
Re: bulbs
When you say chrome the back of the metal portion, are you saying the metal cover that goes on prior to the clear plexiglass piece when installing? Because on the 80's trucks i think they made them in plastic....reason i ask is i will also tackle this too....
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 07-18-2009, 10:44 AM   #24
joe231
joe231's Avatar
Re: bulbs
I have been thinking about this....took me back to elementary science class....
"White" Light is made up of all the colors in the spectrum, the reason we see color is an object absorbs all the colors in the spectrum except the colors of said object...so if you are looking at a red object, the object absorbs all the colors of the spectrum except red which is reflected so we see red, if the object is blue it absorbs all the colors of the spectrum except blue which is reflected so we see blue, and so on and so on...black, gray, and white are a bit different. When "white" light hits a black object all the colors are absorbed and none are reflected, so we see black, or an absence of color. when light hits a white object all the colors are reflected and none are absorbed so we see white, so gray would be a combination of the 2. half the colors would be absorbed and half would be reflected, in a perfect gray
so by this science lesson, white would be a better reflective surface as it reflects all the colors in the spectrum, so technically it reflects all the "white" light that we can see. which would be brighter than any other color......
if you doubt the science or I didn't quite explain it where it is understandable, google "why we see color" or "how we see color"
CHEVY ONLY
Old 07-18-2009, 09:24 PM   #25
BLE 'BURBAN
Re: bulbs
Paint the inside of the cluster housing (Pic 1) and the back side of the cover piece (pic 2) white and you'll get better illumination on your gauges.
