Old 07-19-2009, 04:47 AM   #1
HeavyD
HeavyD's Avatar
Opinions...cut the frame or no??
I know some people have had their frames chopped down to make a SWB, just wondering how many are in favor of this vs getting an original frame? I am considering cutting down my lime 71...opinions?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 07-19-2009, 07:05 AM   #2
big_al_71
big_al_71's Avatar
Re: Poll: Cut the frame or no??
I would cut it with no problem as you can find lwb all day long....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-19-2009, 07:22 AM   #3
Gene
Gene's Avatar
Cut it, SWB's are few and far between.
Gene is offline   Reply With Quote
Old 07-19-2009, 08:32 AM   #4
arm51
beer me
arm51's Avatar
ive considered cuting mine down as well but just think of it this way if you are just a hair off your toast and i just wouldnt take the risk
1969 c10 currently on hold because of a darn f**d
1986 f150
1986 silverado-my dads truck that i'm fixin up
ill keep my freedom my guns my money my religion and you can keep your CHANGE-hank williams jr
arm51 is offline   Reply With Quote
Old 07-19-2009, 09:07 AM   #5
68 short step
a tape measure is all you need to make sure you're not off
68 short step is offline   Reply With Quote
Old 07-19-2009, 09:34 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I cut the frame on my '70 project with no problems. Just follow Glocks "how to" here: http://67-72chevytrucks.com/vboard/s...d.php?t=123624 for what I consider the safest way to do it.
If you are "just a hair off" it won't hurt anything. If you have ever measured one of our bare frames you will find there are measurements that are more than a hair off from the factory. Cut it and don't look back.... Just make sure you have a qualified welder weld it back together.
LockDoc
Leon
Old 07-19-2009, 09:39 AM   #7
killer71
killer71's Avatar
cut it!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-19-2009, 09:50 AM   #8
see ten
WTB this ad
see ten's Avatar
Measure twice, cut once. Have at it!
see ten is offline   Reply With Quote
Old 07-19-2009, 11:10 AM   #9
71see10
Worthless
71see10's Avatar
Yep cut it,just take your time!!!
71see10 is offline   Reply With Quote
Old 07-19-2009, 11:36 AM   #10
Hart_Rod
Hart_Rod's Avatar
I've done both. I built the frame for my CrewCab which utilized some of the threads listed here. It was pretty straight forward. I got lucky and found a good SWB frame for my 68 50th build, so the swap was pretty simple. I did it in a weekend once the frame was painted. Sooooo, if you can find a SWB frame, swap it. If you can't, start cutting! Good luck with whatever you do, .
Hart_Rod is offline   Reply With Quote
Old 07-19-2009, 12:05 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would cut it.If you do an angle cut like "Hart Rod" showed you get more weld area.I would also put a strengthening plate inside the rail or possibly box that area.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-19-2009, 12:40 PM   #12
C/10 King
C/10 King's Avatar
Cut away, and don't look back!
Just do it!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 07-19-2009, 01:11 PM   #13
sameyrasmea72
sameyrasmea72's Avatar
I guess I am the odd ball out. I say look for a swb frame. But the may not be that easy for you where you live. I guess I am pretty spoiled there are still enough short frames aroung here. i have four extra ones right now.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 07-19-2009, 01:50 PM   #14
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Do anyone have any proven plans on where and how to cut??
prostreetC-10 is offline   Reply With Quote
Old 07-19-2009, 01:55 PM   #15
Hart_Rod
Hart_Rod's Avatar
45 degree method:
http://67-72chevytrucks.com/vboard/s...d.php?t=232149
Stepped method:
Old 07-19-2009, 02:13 PM   #16
chevjayfsd
Project 7dos
chevjayfsd's Avatar
We cut ours... Easy...
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 07-19-2009, 04:35 PM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In '69, there were approximately 54K SWB trucks. The same year, there were over 4 times as many LWB trucks. Which ones do you think still are on the road? These trucks have already assumed the Icon status in vehicles. As such, the collectors and those who are wise will already own a SWB. If you are unable to get a SWB, then follow the others who have already cut their chassis. Custom Classic Truck magazine, or maybe it was Classic Truck magazine, did a series of articles on cutting one down. I believe it was CCT and Dakota Wentz was the fabricator. He left the magazine and moved to Tulsa to take over the shop of his grandfather, Darryl Starbird. I think the series of articles is the "Get Shorty" ones.
Member Nr. 2770
Old 07-19-2009, 08:01 PM   #18
CheyenneShop
CheyenneShop's Avatar
Cut it!
I'm cutting one of mine right now, see my build thread below. It's actually a lot of fun! The best thing is you have so much help here. Good luck with whatever you decide.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 07-20-2009, 10:22 PM   #19
Jim_PA
I'm soooo ready to do this, but cutting down the bed has me scared.
Jim_PA is offline   Reply With Quote
Old 07-20-2009, 10:29 PM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Oh yeah, that's scary. Most of the long-to-short conversions usually find folks buying new (reproduction) bed sides. Either that, or find a short bed. I know where one is, in fact the whole truck is there, minus the engine/transmission. Bed was the best thing going.
Member Nr. 2770
Old 07-20-2009, 11:10 PM   #21
hchad18
hchad18's Avatar
Cut the frame and find a SWB bed.
hchad18 is offline   Reply With Quote
Old 07-20-2009, 11:15 PM   #22
Jim_PA
It's that easy, huh? You should see the swiss-cheese bondo buckets around here. I got somewhat lucky as the bed I have now came from the west. I will probably be best off selling the bed sides to buy repro short bedsides and cutting down the floor (I can probably handle cutting down a floor)
Old 07-21-2009, 06:43 AM   #23
bigsnookmaster
bigsnookmaster's Avatar
Cut it! I like the step method myself, but I'm sure if it's properly welded, it will work fine either way.Good luck
bigsnookmaster is offline   Reply With Quote
Old 07-21-2009, 07:41 AM   #24
hchad18
hchad18's Avatar
No, I know its not easy. Mine was junk also. I trashed it and got a floor from here, a bed side from there and another junk bedside from that guy that I had to put a weeks worth of work into. I think it took me two years to do that. I can appreciate the SWB bed hunt.
Old 07-21-2009, 09:05 AM   #25
mr48chev
mr48chev's Avatar
When I lived in Texas and those trucks were new I think they actually sold more short bed trucks than long beds. The rest of the country is the direct opposite and we all have about a 7 to 1 ration of longbeds to shortbeds. Texas guys bought trucks just to drive every day and notreally to haul stuff before the rest of the country did, or it seems so.
I say cut it as it will keep the original serial number intact on the frame. But do it with the stepped method as this would be the strongest from what I have seen. This is the way the truck shops around here lengthen or shorten frames on flatbeds.
What ever you do don't cut it straight down and butt weld it as that doesn't allow for a lot of weld area nor is it anywhere near as strong as the other methods.
