07-29-2009, 12:53 AM | #1 |
Locker or Limited Slip?
Anyone got a locker of any kind or limited slip in their rear diff on a 2wd? I want to install one (or have one installed) but don't know what is best for mostly street driving but occasional desert/dirt and towing use. I don't really want a lot of shakes and shimmys like a Detroit Locker but not sure if a limited slip is strong enough and will last a long time. Also, not sure if an air locker or electric locker is best since they would cost more. I have a Lock-Right in my big block Camaro and while it really locks the diff on the straights it also gives me a loose feeling in the rear sometimes and clicks loudly in the turns. Any thoughts?
07-29-2009, 06:37 AM | #2 |
Re: Locker or Limited Slip?
Detroit Truetrac®
Uses pairs of "Helical" gear sets Gears only - no clutch packs. Ideal for 4WD front axles or rear axles, as well as 2WD; light trucks, SUV’s, cars. Rugged yet smooth and quiet. Torque bias ratios of 2.5 to 3.5:1 range. |
07-29-2009, 06:57 AM | #3 |
I really liked the Auburn Gear unit in my Blazer.
07-29-2009, 07:25 AM | #4 |
I've been looking at the Powertrax on Summit but have not bought it yet. Seems like it would be good for the street as it releases in turns so it would be smoother and quieter.
69 Chevy 4x4 383 Power |
07-29-2009, 08:09 AM | #5 | |
For a 2wd, if you are going to drag it get a locker or spool. For a street driver I would go with a limited slip (the helical diffs are nice).
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
07-29-2009, 08:20 AM | #6 | |
07-29-2009, 09:29 AM | #7 |
I like eaton posi for our trucks for the street. I took my 72 GMC to the track with it too, no problems with the diff.
Also, I had a Detroit Truetrack in the front of my Jeep, and sometimes it would only spin on wheel. I wasn't too impressed with it honestly. The ARB air locker I had in the rear worked great though
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 07-29-2009 at 12:38 PM. |
07-29-2009, 11:20 AM | #8 |
All lockers have qwerks that may be objectional to some. When you get on and off the throttle you will feel it lock and unlock. Lockers have a certain amount of play built in for the teeth to lock into. This is just the way it is. On the street where both tires have near equall load to them a limited will work great and last a long time. I prefer the eaton style myself. In a 4wd that will get wheeled, a locker is a must imo.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
