Re: John's 87 S10 - Epilepsy build up
Looks really nice. Glad it is for a good cause.
wow.....looks great!!...thats awsome you guys are doin this for that kat.. i cant imagine having the equipment and know how to pull off this kind of operation..on my 15 im runnin blocks and heat shrunk coils... yall is ligit..props
I swapped out the bushing on the upper link for a 3/4" rod end, and it solved my clearance issues. The bag now has plenty of room to do it's thing. I am now satisfied with the link setup, so I welded most of it up. I need to pull the axle to finish the rest.
If you can find it cheaper, I can fix it! |
looks damn good I've been waiting to see you start on this truck. I bet those sleeve bags are gonna ride real nice BOA
Adam M STX Designs Motorcycles | Choppers | Hotrods |
Today I built what will be both a crossmember, and an air manifold. It's sitting on top of the frame, which is not where it will end up. I need to pressure test it before I weld it to the frame. The goal is to keep the tank, compressors and valves all under the stock bed floor. I am using a "manifold" to mount the valves because the tank only has 4 ports.
VA72C10
![]() Join Date: Mar 2008
That's nice man!!! Slick setup.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
The Beach Cruiser
This place is GREAT! I'm proud to be part of it.
1999 Silverado DD ![]() 1966 Panel Truck 2003 Harley Road Glide ![]() 1967 Schwinn Tandem Single Speed |
Backwoods Body
Looking good!
Are there any more parts that you need ?
What all off you guys are doing and have done is totally outstanding. Those are some mad skills you got. Looking at your work so far it is totally
![]() ![]() ![]() ![]() Click *Suscribed*
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Low & Fast!
What a cool looking manifold.. Good job.
Thanks guys.
It needs a 91-93 core support, and some 18" limit straps. I got the bag mounts and shock mounts finalized today. The manifold cross member is welded in. I just need to make some brake line brackets, and compressor mounts and the back half is ready to be torn apart for some finish work and paint. ![]() ![]()
VA72C10
Looking good!
Man your welding is NICE!!! Im guessing your using a TIG welder as nice as those welds are. If your using a MIG then your welding is truly artistic!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#15 |
It's a mix of MIG and TIG. Mostly MIG so far.
#16 |
Here is the weeks update. I got the manifold cross member welded in place, and hung some compressor mounts off of it. Then I welded in the air tank brackets now that I was sure it wouldn't interfere with the compressors. I then pulled the axle out to finish all of the welding.
![]() ![]() ![]() I started painting the frame yesterday, but Tyler is wet sanding his car in preparation for painting it next week. Dust got stuck in the paint as it was drying, so I am going to wait until he is finished with that and then sand it down and repaint the frame. The axle is also primed and ready for some semigloss on Monday. And I need to start prepping the tank for some undercoating maybe. The link bars are at a friends house getting painted silver tomorrow, so they should be ready Monday too. I can also see now in the pictures I need to figure out a way to get paint further into the notches. ![]() ![]()
#17 |
VA72C10
Keep it up. progress is looking good.
#18 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Looking great!
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#19 |
nice build sleve bag over axle rides great
#20 |
i didn't think people with epilepsy could even get a drivers license?
R.I.P. Killer 71 10/26/07 |
#21 |
Different states have different laws about it. I don't know ours, but apparently can if you go seizure free for several years.
#22 |
>130dB Moderator
There's some rules on it, but basically if a Dr. says you're good, they'll give it to you.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#23 |
Doing the finish work on the back half. Almost everything is painted. Spent a lot of time on the gas tank, it had to be sanded bare after stripping the grime off of it. The paint just kept flaking so I was forced to take it to bare metal, or it would just happen again in the future. Had to repair 5 holes in the air tank I found when doing a pressure test. There is a lot of dust in the shop because we are cutting and buffing a new paint job as well. I should be taking the driveline in to be shortened tomorrow, and aside from wiring/plumbing the back half will be complete.
#24 |
VA72C10
Nice work man. Can't wait to see it laid out.
#25 |
FINALLY! lol
