PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 67 cheby's Dropmember build thread
Do you guys have a web site for this nwafab?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
67cheby
![]() Join Date: Sep 2008
phone # 541-791-1424 , tell him me and hartrod sent you
Do you think he would make me some of those to
nickle and dime |
![]() Join Date: Dec 2008
Hey cheby what did you end up doing w/ your bed floor particularly raising your bed sides & wheel wells.Have you redone them yet? I'm about at that point & my bed sides are new. Being a mechanic not a bodyman my nerves are frazzled just thinking about cutting into inner body panels & I only want to do it once.Any advice would be appreciated! Mac
67cheby
i am not raising mine anymore than i have .... i am just going to have to notch the bed floor , the raising the bedfloor is a huge job to do it right, like i said when i first raised the bed floor i wasnt planning on going anywhere near this low and i just wanted to cover my notch ,, so now i have a raised bed floor and a cut out, the nice thing is the raised bedfloor allowed me plenty room for my fuel cell ( which doesnt hang below my frame at all) and for all of my air ride to be underneath..... all that being said ITS A LOT OF WORK !! ask me any questions you would like i will sure try to help you
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
67cheby
heres my driveline finally, set at a 5 inch ride height, made an aluminum 1.5 inch spacer block for the CPP carrier bearing, the rear shaft of the driveshaft is the CPP shaft with a 3 inch slip joint, i am going to cut off the hoop on the top of the crossmember and raise it 1 inch , hopefully that wont get into the bottom of my cab !! then i am going to cut off the trailing arm mounts and weld this crossmember into the frame
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 05-26-2010 at 09:47 AM. |
VA72C10
![]() Join Date: Mar 2008
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Wow, nice work.
Makin good progress Mike!!!! Truck looks awesome.
67cheby
Thanks guys.. and you to MR COOL FIREWALL
Under Construction
nice work, looks sharp! Keep at it.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Rtatum540
![]() Join Date: Apr 2010
Man, ur build is awesome. The raised bed floor and streched tubs look sweet. Keep up the good work
Tot Roddin'
Wow.... that's all that will come to mind... wow!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#15 |
67cheby
thats the same thing i say when i look at your truck
#16 |
Looking at your truck , (and many others on this board) sometimes makes me wish I would have taken my truck in a different direction.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#17 |
67cheby
are you kidding me you have one of the top 5 trucks on this board , in my opinion..I love your truck just like it is
#18 |
what exactly do you have to cut to fit those core support covers?
#19 | ||
VA72C10
![]() I think you just need to get a second truck to SLAM ![]()
#20 |
He's already doing just that....
#21 |
VA72C10
#22 |
67cheby
there are some ridges that run up and down and are about 1 1/2 inches wide on either side of the radiator , you have to flatten out the last couple inches of those
#23 |
I can't believe it took me till now to subscribe to this one. You've done an awesome job man! Very impressive. Can't wait to see it together.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
#24 |
67cheby
ya ... whats the deal i have been watching yours from the start !!! GEEEZZZ go fix yourself your own dang Casadillas !!! (for those who dont know thats a line off of Napolean Dynamite)
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 05-28-2010 at 11:20 AM. |
#25 | |
![]() I have to stop looking at your build now because I'm seeing ideas that I wanted on ours and didn't even know it. Argh!!!!!!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 Last edited by es67chevy; 05-28-2010 at 11:29 AM. |
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
