Old 08-25-2009, 01:48 PM   #1
chuckthetruck
chuckthetruck's Avatar
Tank 2 problems
Just a simple question about my 87 Sierra 1500 i just got home...i filled up the 2nd tank (which has not been used in at least 5 years) for the trip home but could never get the truck to start with the selector on that tank. Any suggestions would went wrong...is there a 2nd fuel pump? Any help is appreciated.
chuckthetruck is offline   Reply With Quote
Old 08-25-2009, 03:03 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Tank 2 problems
Fuel injected would have pumps in both tanks. It could also be cloged in the switching valve for that tank...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-25-2009, 03:07 PM   #3
chuckthetruck
Re: Tank 2 problems
Chuck
Pretty easy fix...other then i have to drop the FULL tank..maybe syphen (spelling) the gas out into the other tank..
Old 08-25-2009, 04:05 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Tank 2 problems
first thing you want to do is make sure the switch in the dash to switch tanks has power to both locations after that check to see if there is poweer to the right pump... if there is power there then the pump is fubar R&R that... the switchover valve also needs to be checked for power.. autozone has them
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 08-26-2009, 02:34 PM   #5
92470
Re: Tank 2 problems
I have the same problem on my 87' V10 and am planning on repairing it this weekend. I posted a previous question about this on how to troubleshoot, and the answer I got helped me out a bunch. When you turn your ignition key on, you should hear the fuel pump "hum" on the side that you have your selector switch switched to (LH or RH). My left works, my right doesn't. When I switch my selector switch to right and turn on my key, no hum. When on the left, it hums. I.e right fuel pump is out. I know the selector valve on the frame is working, because when I turn the key, I hear it click. I bought a new AC Delco valve just to check, and when I hooked it up, it clicked and performed just the same, so I'm planning on taking it back because it was $140, but I figure I'll wait just to be sure until I have the pump replaced. While I have the tank out to replace the pump, I'm also replacing the sending unit just in case. I hope this helps you fix your problem. If my advice is not correct, someone please correct me. Good luck!
92470 is offline   Reply With Quote
Old 08-26-2009, 02:49 PM   #6
bumslie75
bumslie75's Avatar
Re: Tank 2 problems
I have the same problem is it the right tank or the left for you
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 08-26-2009, 03:24 PM   #7
chuckthetruck
Re: Tank 2 problems
right tank
Old 08-26-2009, 04:03 PM   #8
bumslie75
bumslie75's Avatar
Re: Tank 2 problems
ya its my right tank too
Old 08-26-2009, 05:04 PM   #9
nlped
nlped's Avatar
Re: Tank 2 problems
Me Too!!! Stupid right tank!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-26-2009, 05:11 PM   #10
orbot
orbot's Avatar
Re: Tank 2 problems
Is the switch pluged??
There is a plug on the firewall, see if its conected....
Can you hear the selector valve when you press the switch??
orbot is offline   Reply With Quote
Old 08-27-2009, 05:05 AM   #11
hatzie
Moderator
hatzie's Avatar
Re: Tank 2 problems
Unbolt, lift and, slide the bed back about 1ft onto some 4x4 timbers. 2 guys can do it. You can see the sender in the gap between the cab and bed you just can't reach it without moving the bed. Much easier than pulling a full tank.
