Old 09-04-2009, 09:31 AM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
next up, gear vendors..
now that the rims and tires are a done deal. next on deck is gear vendors.... look to be about 3k,,,,yikes.
going to call them and ask a few questions. anyone have any input or questions on these things?
my main one is on the carrier barring. i have a 2 piece drive line. the front one will be about a foot and a few inches long after the install. then into the carrier barring. looks to be that a one piece drive line makes more sense. any down side to a one
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-04-2009, 09:37 AM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Wink Re: next up, gear vendors..
Go with the one piece, less headaches!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-04-2009, 10:13 AM   #3
mtdave2
mtdave2's Avatar
why was there 2 in the first place? to help deal with frame and body flex?
69 k10 Suburban
Old 09-04-2009, 10:18 AM   #4
jorgensensc
jorgensensc's Avatar
THe rear trailing arm setup had a lot of vertical movement, so the two pice was deemed better. A lot of Lowered (slammed) guys prefer a 2 piece also.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-04-2009, 01:06 PM   #5
mtdave2
mtdave2's Avatar
anyone who has one in there truck. where did you mount the electronics?
69 k10 Suburban
Old 09-04-2009, 02:08 PM   #6
long69
i though that i had read or heard that they had a universal set-up, but no details. i would be wondering if they did, could it go where the carrier bearing is and maye just replace it. i dont have the cashola so i havent pursued the details.
long69 is offline   Reply With Quote
Old 09-04-2009, 02:47 PM   #7
mtdave2
mtdave2's Avatar
Well that was an interesting call.
As far as the drive shaft, they keep the 2 piece. in their installs.
There are 2 different models. A truck/towing and a hot rod modle.
They differ in a few ways. The hot rod uses a softer metal for internal parts, to absorbs spikes in power. The towing model is made for long term heavy loading for rvs and heavy trucks, they also have deeper oil pan. So for our trucks they are bullet proof…or so they say.
I didn’t quite understand how you interact with the unit. Now I get it.. there is 2 switches that the driver can use. One switch you choose if you want manual, or auto shifting. The other switch is an on off switch usually mounted next to your dimmer switch on the foor.
Manual vs auto. In our trucks, if you are at a stop sign and in D. if you are in auto, and you hit the gas, the truck shifts as normal. 1st,2nd,3rd, then the unit turns on and you get the over drive.
In the manual mode. And in 1 on you column shifter. You hit the gas, when you want a shift, hit the button with your foot and you are in 1st over. Shift into 2nd and hit the foot switch you are now in 2nd, hit the foot switch, you are in 2nd over, shift to D and hit the switch you are in 3rd. and then hit the foot switch and you are in 3rd over, or over drive.
I cant see ever using the manual mode unless towing up a hill, or hot roding around town for a bit.
Install, should take about 4hrs, all the electronics can be hidden under the dash. You will need to cut a **gulp* hole, in the floor for the foot switch, and someplace you need to but a light to show when the unit is on.
All in all it sounds like something I want. Ill prob wait a few days, and pull the trigger…anyone wana help with the install? Beer and pizza!
69 k10 Suburban
Old 09-04-2009, 03:41 PM   #8
kevncar
Active Member
kevncar's Avatar
mtdave2...I picked one up a while back, but have not worked on my truck in quite sometime. If I can help with any pics or anything, i've got mine sitting in a box collecting dust that is really easy to get to.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 09-05-2009, 12:45 AM   #9
mtdave2
mtdave2's Avatar
you have a gear vender unit in a box? why dont you use it? or sell it =)....
thanks for the offer to help!
69 k10 Suburban
Old 09-05-2009, 10:02 AM   #10
gator2511
gator2511's Avatar
Talking Re: next up, gear vendors..
I've had mine in for several years now and I think you will love it. My foot switch from GV is a surface mount on the floor so the only holes in the floor are the mounting screw holes. The foot sw. then plugs into the controller which I have mounted under the dash on the firewall. My truck is a 4wd shorty and the GVOD was installed at the same time as the TH400 so I had to move the tranny mounts to the rear about 4". The front driveshaft had to be lengthened and the existing one piece shaft going to the rear had to be shortened. No problems with the one piece in mine. The more weight you put on these units the smoother they shift. The only thing I don't like is that in automatic mode the downshift to first is too rough so I mostly use it in manual mode and it downshifts great. When towing you can keep the motor nice and comfy by using whatever gear you want. (its a 6 speed now)
gator2511 is offline   Reply With Quote
Old 09-05-2009, 10:48 AM   #11
72JimmyDiesel
What about installing a 4L80E. You can pick a good used one for 4-500. A stand alone for $600 and just shorten your stock drive shaft a few inches. You get a slightly larger overdrive .75 vs .78 and a locking converter.
72JimmyDiesel is offline   Reply With Quote
Old 09-05-2009, 12:14 PM   #12
dan42
dan42's Avatar
That's a thought, but then you have speedometer issues if you want to keep a stock dash.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-05-2009, 05:23 PM   #13
Doug's68SS
You bring up the speedo issue. I am wondering the same thing what do you do when you have the electronic pick up. I see all these trucks with 700r and 4l80 how do you get the speedo to work. I was thinkg GV for that reason
Doug's68SS is offline   Reply With Quote
Old 09-05-2009, 06:17 PM   #14
mtdave2
mtdave2's Avatar
i wont ever use a 700r4 again. not worth it imho. the gv is the way to go. very light mods to your truck, faaaaaaaaaaaaaar more reliable.
the only down side is price.
nice to know about the switch, i hate makin holes in my truck
69 k10 Suburban
Old 09-07-2009, 11:58 AM   #15
mtdave2
mtdave2's Avatar
i would have thought this would have had more interest... should i even bother with an install post?
69 k10 Suburban
Old 09-07-2009, 12:16 PM   #16
Sinister
Between Trucks...
Sinister's Avatar
I'd like to see info on the install.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-07-2009, 07:43 PM   #17
jbarron
I've been running one for a couple years. They work great to cut down the rpms on the highway. Not a real gas saver since you are now using power to drive another accessory. But my 402 never gets great fuel economy, heavy foot.
My driveshaft guy said not to run a two piece with that short of a front shaft. Something about the rear shaft playing hell with that short of a front shaft. I had a one piece made so I can remove it later if I want.
I mounted the electronics in a custom console I made. I also replaced the foot switch with one mounted on the console.
It's a easy install. The electronics take as long to route and tie in as the mechanicals.
When it kicks in you will know it. Its like a good shift kit.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 09-07-2009, 07:50 PM   #18
mtdave2
mtdave2's Avatar
hum good point about the gas mileage, giving me a bit of a pause.. while it does make sence that you are using power to turn the unit, that will take some mpg, as soon as you get to the od you would be saving..alot. so the net should be lower i would think
69 k10 Suburban
Old 09-08-2009, 10:21 AM   #19
Lemield
Lemield's Avatar
I've got a GV unit in my 70 CST shortie. It works great. I put in a one piece driveshaft when I installed the GV unit. I mounted the electronics under the dash on the left side of the driver...using existing holes. Pretty simple install.
I installed it a few years ago but if I can answer any questions, please let me know.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-08-2009, 10:58 AM   #20
mtdave2
mtdave2's Avatar
what did it do for your milage?
69 k10 Suburban
Old 09-08-2009, 11:02 AM   #21
Lemield
Lemield's Avatar
Mtdave2,
I don't really know what it did for my mileage. I had 3.08 gears when I installed it and took one long trip out to Maob Utah. I got about 17mpg on the highway that trip. I recently changed to 3:73 gears but I don't have any idea what it did to my mileage. I mostly just drive it for fun anyway.
Larry
Old 09-08-2009, 03:30 PM   #22
kevncar
Active Member
kevncar's Avatar
Yeah, well...I can never find time or funds to get my truck back on the road. To many other things, like work, kidos and honey-do's. One of these days. I really envy guys that have kept thier truck running and just done upgrades as they went, but always kept them on the road. Should have done that if I had half a brain, but I went more the "frame-off" route. My mistake...but I'll get er going one of these days.
Good luck with your truck, and please so the install post...I love seeing others progress. If nothing else it's motivational for others like me.
Kevin
72 Chevelle
67 C10...454/TH400
Old 09-08-2009, 04:26 PM   #23
69GMCLonghorn
69GMCLonghorn's Avatar
Ironically, I envy guys like you that have the b*lls to do a frame off... By the way, why do they call it a "frame off"? Isn't it really a "body off"?? You don't take the frame off the body... You take the body off the frame. Ah what do I know.
69GMCLonghorn is offline   Reply With Quote
Old 09-09-2009, 01:29 AM   #24
kevncar
Active Member
kevncar's Avatar
Maybe that's my problem...I'm doing it backwards!!!!
Kevin
72 Chevelle
67 C10...454/TH400
Old 09-09-2009, 08:15 AM   #25
Shaky
Six in a row makes it go...
Shaky's Avatar
I'm interested in the GV unit. I have a long bed 2WD and wonder what to do with the two-piece drive shaft. I'm putting it behind an SM420 4-speed.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
